Solved Malware infested and crudware
Discussion in 'Malware and Virus Removal Archive' started by elcajongunsfan, 2014/10/22.
  1. 2014/10/24
    elcajongunsfan Lifetime Subscriber
    elcajongunsfan Well-Known Member Thread Starter
    Both were deleted..
  2. 2014/10/24
    OK, give me a sec...
    Download attached fixlist.txt file and save it to the Desktop.
    NOTE. It's important that both files, FRST and fixlist.txt are in the same location or the fix will not work.
    NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system
    Run FRST(FRST64) and press the Fix button just once and wait.
    The tool will make a log on the Desktop (Fixlog.txt). Please post it to your reply.
  5. 2014/10/24
    Fix result of Farbar Recovery Tool (FRST written by Farbar) (x86) Version: 23-10-2014
    Ran by User at 2014-10-24 19:40:21 Run:2
    Running from C:\Users\User\Desktop
    Loaded Profile: User (Available profiles: User)
    Boot Mode: Normal
    Content of fixlist:
    2014-10-15 17:04 - 2014-10-24 18:51 - 00000000 ____D () C:\Program Files\FLV Toolbar
    Reg: reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{86869ABB-D06B-4FD3-85B8-337B9ECC6E89} "
    Reg: reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\gorillaprice "
    Reg: reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PureLeads "
    Reg: reg delete "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\StormAlerts "
    Task: {7BA4D651-A4BD-4E02-AF17-6F927EFAE7FC} - System32\Tasks\istcleaner Task => C:\Users\User\AppData\Roaming\UpdateServ\ISTCleaner.exe
    Task: {F90F141D-A832-4006-8D2B-3B28DA51DE3C} - System32\Tasks\TidyNetwork Update => C:\Users\User\AppData\Local\TidyNetwork\petnupdate.exe
    C:\Program Files\FLV Toolbar => Moved successfully.
    ========= reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{86869ABB-D06B-4FD3-85B8-337B9ECC6E89}" =========
    Permanently delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{86869ABB-D06B-4FD3-85B8-337B9ECC6E89} (Yes/No)? The operation completed successfully.
    ========= End of Reg: =========
    ========= reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\gorillaprice" =========
    Permanently delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\gorillaprice (Yes/No)? The operation completed successfully.
    ========= reg delete "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PureLeads" =========
    Permanently delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PureLeads (Yes/No)? The operation completed successfully.
    ========= reg delete "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\StormAlerts" =========
    Permanently delete the registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\StormAlerts (Yes/No)? The operation completed successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{7BA4D651-A4BD-4E02-AF17-6F927EFAE7FC}" => Key deleted successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{7BA4D651-A4BD-4E02-AF17-6F927EFAE7FC}" => Key deleted successfully.
    C:\Windows\System32\Tasks\istcleaner Task => Moved successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\istcleaner Task" => Key deleted successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{F90F141D-A832-4006-8D2B-3B28DA51DE3C}" => Key deleted successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{F90F141D-A832-4006-8D2B-3B28DA51DE3C}" => Key deleted successfully.
    C:\Windows\System32\Tasks\TidyNetwork Update => Moved successfully.
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\TidyNetwork Update" => Key deleted successfully.
    "C:\Users\User\AppData\Roaming\UpdateServ" => File/Directory not found.
    "C:\Users\User\AppData\Local\TidyNetwork" => File/Directory not found.
    ==== End of Fixlog ====
  6. 2014/10/24
    Very good :0
    How is computer doing?
    Last scans...
    [​IMG] Download Security Check from here or here and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    NOTE 1. If one of your security applications (e.g., third-party firewall) requests permission to allow DIG.EXE access the Internet, allow it to do so.
    NOTE 2. SecurityCheck may produce some false warning(s), so leave the results reading to me.
    NOTE 3. If you receive UNSUPPORTED OPERATING SYSTEM! ABORTED! message restart computer and Security Check should run
    [​IMG] Please download Farbar Service Scanner (FSS) and run it on the computer with the issue.
    • Make sure the following options are checked:
      • Internet Services
      • Windows Firewall
      • System Restore
      • Security Center
      • Windows Update
      • Windows Defender
      • Other Services
    • Press "Scan ".
    • It will create a log (FSS.txt) in the same directory the tool is run.
    • Please copy and paste the log to your reply.
    [​IMG] Download Temp File Cleaner (TFC)
    Alternate download: http://www.itxassociates.com/OT-Tools/TFC.exe
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    [​IMG] Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Internet Explorer users - Click on this link to open ESET OnlineScan.
    • For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
      • Click on ESET Smart Installer to download the ESET Smart Installer. Save it to your desktop.
      • Double click on the [img=http://www.bleepstatic.com/fhost/uploads/0/esetsmartinstaller_enu.png] icon on your desktop.
    • Check "YES, I accept the Terms of Use. "
    • Click the Start button.
    • Accept any security warnings from your browser.[/*]
    • Check "Enable detection of potentially unwanted applications ".
    • Click Advanced settings and make sure all 4 boxes are checkmarked (two of them are already checkmarked by default).
      Do NOT checkmark "Use custom proxy settings "
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, click List Threats[/*]
    • Click Export, and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • Click the Back button.
    • Click the Finish button.
  7. 2014/10/24
    Here are the first two.. TFC did not require a reboot. I'll do the NOD32 ( I have subscriptions on five computers) after I paste these logs
    Computer is running good.. What was most noticeable was the faster start up. No pop ups so far
    Results of screen317's Security Check version 0.99.89
    Windows 7 Service Pack 1 x86 (UAC is enabled)
    Internet Explorer 11
    ``````````````Antivirus/Firewall Check:``````````````
    Windows Firewall Enabled!
    Norton Internet Security
    WMI entry may not exist for antivirus; attempting automatic update.
    `````````Anti-malware/Other Utilities Check:`````````
    Java 7 Update 25
    Java version out of Date!
    Adobe Reader XI
    Mozilla Firefox (33.0)
    Google Chrome 32.0.1700.76
    Google Chrome 38.0.2125.104
    ````````Process Check: objlist.exe by Laurent````````
    Kaspersky Lab Kaspersky Security Scan 2.0 kss.exe
    `````````````````System Health check`````````````````
    Total Fragmentation on Drive C: 6%
    ````````````````````End of Log``````````````````````
    Farbar Service Scanner Version: 21-07-2014
    Ran by User (administrator) on 24-10-2014 at 19:55:54
    Running from "C:\Users\User\Desktop "
    Microsoft Windows 7 Professional Service Pack 1 (X86)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo.com is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Action Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Windows Defender:
    Other Services:
    File Check:
    C:\Windows\system32\nsisvc.dll => File is digitally signed
    C:\Windows\system32\Drivers\nsiproxy.sys => File is digitally signed
    C:\Windows\system32\dhcpcore.dll => File is digitally signed
    C:\Windows\system32\Drivers\afd.sys => File is digitally signed
    C:\Windows\system32\Drivers\tdx.sys => File is digitally signed
    C:\Windows\system32\Drivers\tcpip.sys => File is digitally signed
    C:\Windows\system32\dnsrslvr.dll => File is digitally signed
    C:\Windows\system32\mpssvc.dll => File is digitally signed
    C:\Windows\system32\bfe.dll => File is digitally signed
    C:\Windows\system32\Drivers\mpsdrv.sys => File is digitally signed
    C:\Windows\system32\SDRSVC.dll => File is digitally signed
    C:\Windows\system32\vssvc.exe => File is digitally signed
    C:\Windows\system32\wscsvc.dll => File is digitally signed
    C:\Windows\system32\wbem\WMIsvc.dll => File is digitally signed
    C:\Windows\system32\wuaueng.dll => File is digitally signed
    C:\Windows\system32\qmgr.dll => File is digitally signed
    C:\Windows\system32\es.dll => File is digitally signed
    C:\Windows\system32\cryptsvc.dll => File is digitally signed
    C:\Program Files\Windows Defender\MpSvc.dll => File is digitally signed
    C:\Windows\system32\ipnathlp.dll => File is digitally signed
    C:\Windows\system32\iphlpsvc.dll => File is digitally signed
    C:\Windows\system32\svchost.exe => File is digitally signed
    C:\Windows\system32\rpcss.dll => File is digitally signed
    **** End of log ****
  8. 2014/10/24
    You're reading my mind. Nod32 is at 99% completed so I'll post in a couple of minutes. When I interviewed the owner about how things came to happen, she said her Son came to live with her and d/l ed all this garbage when I told her it appeared all the malware was installed about Feb-April earlier this year.
  10. 2014/10/24
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\tbicon.exe.vir a variant of Win32/Toolbar.SearchSuite.U potentially unwanted application
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\Uninstall.exe.vir a variant of Win32/Toolbar.SearchSuite.U potentially unwanted application
    C:\Qoobox\Quarantine\C\ProgramData\ClickaFoorSale\SUcjdScRlkFrVT.dll.vir a variant of Win32/AdWare.MultiPlug.BN application
    C:\Qoobox\Quarantine\C\ProgramData\ClickaFoorSale\SUcjdScRlkFrVT.exe.vir a variant of Win32/AdWare.MultiPlug.BN application
    C:\Qoobox\Quarantine\C\ProgramData\DOcaToTeXTCooNveratt\xnAW.dll.vir a variant of Win32/AdWare.MultiPlug.N application
    C:\Qoobox\Quarantine\C\ProgramData\DOcaToTeXTCooNveratt\xnAW.exe.vir a variant of Win32/AdWare.MultiPlug.K.gen application
    C:\Qoobox\Quarantine\C\ProgramData\EaisyTuoshiop\zX_oXWG.dll.vir a variant of Win32/AdWare.MultiPlug.N application
    C:\Qoobox\Quarantine\C\ProgramData\EaisyTuoshiop\zX_oXWG.exe.vir a variant of Win32/AdWare.MultiPlug.K.gen application
    C:\Qoobox\Quarantine\C\ProgramData\PrinceCoeupon\yAhaR3wkRKdjiz.dll.vir a variant of Win32/AdWare.MultiPlug.BN application
    C:\Qoobox\Quarantine\C\ProgramData\PrinceCoeupon\yAhaR3wkRKdjiz.exe.vir a variant of Win32/AdWare.MultiPlug.BN application
    C:\Qoobox\Quarantine\C\Users\User\AppData\Local\4649\a26552.exe.vir a variant of Win32/Amonetize.BR potentially unwanted application
    C:\Qoobox\Quarantine\C\Users\User\AppData\Local\fabulous_07281835\fabulous_07281835.exe.vir a variant of Win32/Skintrim.NH.Gen trojan
    C:\Qoobox\Quarantine\C\Users\User\AppData\Roaming\SaveSense\UpdateProc\UpdateTask.exe.vir a variant of Win32/DealPly.S potentially unwanted application
    C:\Qoobox\Quarantine\C\Users\User\AppData\Roaming\VOPackage\Uninstall.exe.vir Win32/VOPackage.B potentially unwanted application
    C:\Qoobox\Quarantine\C\Users\User\AppData\Roaming\VOPackage\VOPackage.exe.vir Win32/VOPackage.B potentially unwanted application
    C:\Qoobox\Quarantine\C\Users\User\AppData\Roaming\VOPackage\VOsrv.exe.vir a variant of Win32/VOPackage.A potentially unwanted application
    C:\Users\All Users\FLV.com FLV Downloader\ytd_installer.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application
    C:\Users\User\AppData\Local\StormAlerts\StormAlertsApp.exe a variant of MSIL/Adware.StrongVault.A application
    C:\Users\User\AppData\Roaming\InstallX Search Protect for Yahoo\searchprotector.exe a variant of Win32/InstallIQ.A potentially unwanted application
    C:\Users\User\AppData\Roaming\InstallX Search Protect for Yahoo\searchprotector.zip a variant of Win32/InstallIQ.A potentially unwanted application
    C:\Users\User\Downloads\flashplayerpro-setup.exe Win32/DownloadAdmin.G potentially unwanted application
    C:\Users\User\Downloads\flashplayerpro_Setup (1).exe a variant of Win32/AdWare.iBryte.AD application
    C:\Users\User\Downloads\flashplayerpro_Setup (2).exe a variant of Win32/AdWare.iBryte.AD application
    C:\Users\User\Downloads\flashplayerpro_Setup (3).exe a variant of Win32/AdWare.iBryte.AD application
    C:\Users\User\Downloads\flashplayerpro_Setup (4).exe a variant of Win32/AdWare.iBryte.AE application
    C:\Users\User\Downloads\flashplayerpro_Setup.exe a variant of Win32/AdWare.iBryte.AD application
    C:\Users\User\Downloads\Flash_Player_Pro_Setup.exe a variant of Win32/AdWare.iBryte.V.gen application
    C:\Users\User\Downloads\flv_installer (1).exe a variant of Win32/SquareNet.A potentially unwanted application
    C:\Users\User\Downloads\flv_installer.exe a variant of Win32/SquareNet.A potentially unwanted application
    C:\Users\User\Downloads\itunes (1).exe a variant of Win32/DomaIQ.AU potentially unwanted application
    C:\Users\User\Downloads\itunes.exe a variant of Win32/DomaIQ.AU potentially unwanted application
    C:\Users\User\Downloads\Media_Player_Setup.exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome (1).exe a variant of Win32/AdWare.iBryte.Q application
    C:\Users\User\Downloads\Player-Chrome (10).exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome (2).exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome (3).exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome (4).exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome (5).exe a variant of Win32/AdWare.iBryte.V.gen application
    C:\Users\User\Downloads\Player-Chrome (6).exe a variant of Win32/AdWare.iBryte.V.gen application
    C:\Users\User\Downloads\Player-Chrome (7).exe a variant of Win32/AdWare.iBryte.V.gen application
    C:\Users\User\Downloads\Player-Chrome (8).exe a variant of Win32/AdWare.iBryte.V.gen application
    C:\Users\User\Downloads\Player-Chrome (9).exe a variant of Win32/AdWare.iBryte.S application
    C:\Users\User\Downloads\Player-Chrome.exe a variant of Win32/AdWare.iBryte.Q application
    C:\Users\User\Downloads\Setup (2).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\Setup (3).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\Setup (4).exe a variant of Win32/FirseriaInstaller.M potentially unwanted application
    C:\Users\User\Downloads\Setup (5).exe a variant of Win32/FirseriaInstaller.M potentially unwanted application
    C:\Users\User\Downloads\Setup.exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\setup.exe (1).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\setup.exe (2).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\setup.exe (3).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\setup.exe (4).exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\setup.exe.exe a variant of Win32/AirAdInstaller.A potentially unwanted application
    C:\Users\User\Downloads\Setup_OSU (1).exe multiple threats
    C:\Users\User\Downloads\Setup_OSU.exe multiple threats
    C:\Users\User\Downloads\SoftwareUpdater.exe a variant of Win32/Packed.VMDetector.J potentially unwanted application
    C:\Users\User\Downloads\VideoPerformerSetup.exe a variant of Win32/InstallBrain.BO.gen potentially unwanted application
    C:\Windows\assembly\GAC_MSIL\Interop.SHDocVw\1.1.0.0__84542ff99aed6a4d\Interop.SHDocVw.dll a variant of Win32/Toolbar.Linkury.G potentially unwanted application
    C:\Windows\Installer\817e1.msi multiple threats
    C:\Windows\System32\hfnapi.dll a variant of Win32/RiskWare.NetFilter.B application
    C:\Windows\System32\plsapp.dll a variant of Win32/AdWare.Sendori.A application
    C:\AdwCleaner\Quarantine\C\Program Files\Application Updater\ApplicationUpdater.exe.vir a variant of Win32/Toolbar.Widgi.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\IMGUpdater\IMGUpdater.exe.vir Win32/Toolbar.Iminent.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Umbrella\Umbrella207.exe.vir a variant of Win32/Toolbar.Iminent.J potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Conduit\Community Alerts\Alert.dll.vir Win32/Toolbar.Conduit.Y potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\FindRight\FindRightUninstall.exe.vir Win32/BrowseFox.C potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Free Games 111\AddonsFramework.Typelib.dll.vir a variant of Win32/Toolbar.Besttoolbars.I potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Free Games 111\AddonsFramework.Typelib64.dll.vir Win64/Toolbar.Besttoolbars.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Free Games 111\BackgroundHost.exe.vir a variant of Win32/Toolbar.Besttoolbars.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Free Games 111\BackgroundHost64.exe.vir a variant of Win64/Toolbar.Besttoolbars.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Free Games 111\ScriptHost64.dll.vir a variant of Win32/Toolbar.Besttoolbars.J potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Iminent\Minibar.InternetExplorer.BHOx86.dll.vir a variant of Win32/Toolbar.Iminent.E potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Iminent\inst\Bootstrapper\IminentUninstall.exe.vir Win32/Toolbar.Iminent.C potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Linkey\Helper.dll.vir a variant of Win32/Toolbar.SearchSuite.P potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Linkey\Uninstall.exe.vir a variant of Win32/Toolbar.SearchSuite.U potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Linkey\ChromeExtension\ChromeExtension.crx.vir Win32/AztecMedia.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Linkey\IEExtension\iedll.dll.vir a variant of Win32/Toolbar.SearchSuite.U potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Linkey\IEExtension\iedll64.dll.vir a variant of Win32/Toolbar.SearchSuite.U potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Optimizer Pro\OptimizerPro.exe.vir Win32/SpeedingUpMyPC.O application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Optimizer Pro\OptProCrash.dll.vir a variant of Win32/SProtector.E potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Optimizer Pro\OptProCrashSvc.dll.vir a variant of Win32/SProtector.J potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Optimizer Pro\OptProLauncher.exe.vir a variant of Win32/AdWare.SpeedingUpMyPC.D application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Optimizer Pro\OptProSmartScan.exe.vir a variant of Win32/Adware.SpeedingUpMyPC.C application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Software Updater\SoftwareUpdater.exe.vir a variant of Win32/AirAdInstaller.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Software Updater\Uninstall.exe.vir Win32/AirAdInstaller.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Uninstaller\Uninstall.exe.vir a variant of MSIL/DomaIQ.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\AnyProtectScannerSetup.exe.vir Win32/AnyProtect.F potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\genienext\nengine.dll.vir Win32/NextLive.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Google\Chrome\User Data\Default\Extensions\jciibccebcogmkmcbehleciidbhbbgie\1.0_0\manifest.json.vir JS/Adware.Adpeak.C application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie2.1.37.zip.vir a variant of Win32/Mobogenie.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie\DaemonProcess.exe.vir a variant of Win32/Mobogenie.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie\Mobogenie.exe.vir a variant of Win32/Mobogenie.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie\MUServer.apk.vir a variant of Android/Mobserv.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie\nengine.dll.vir Win32/NextLive.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\Mobogenie\Version\OldVersion\Mobogenie\New_UpdateMoboGenie.exe.vir a variant of Win32/Mobogenie.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\SaveSense\SaveSenseIE.dll.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\SaveSense\SaveSenseUpdateVer.exe.vir a variant of Win32/DealPly.M potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\SwvUpdater\Updater.exe.vir a variant of Win32/Amonetize.AM potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Local\WeatherAlerts\DesktopWeatherAlertsApp.exe.vir a variant of MSIL/Adware.StrongVault.A application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Users\User\AppData\Roaming\newnext.me\nengine.dll.vir Win32/NextLive.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Windows\system32\hfpapi.dll.vir a variant of Win32/RiskWare.NetFilter.B application cleaned by deleting - quarantined
    C:\AdwCleaner\Quarantine\C\Windows\system32\installd.exe.vir a variant of Win32/Amonetize.BB potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Windows\system32\nethtsrv.exe.vir a variant of Win32/Amonetize.AZ potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Windows\system32\netupdsrv.exe.vir a variant of Win32/Amonetize.AZ potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Windows\system32\roboot.exe.vir a variant of Win32/Systweak.A potentially unwanted application deleted - quarantined
    C:\FRST\Quarantine\C\Program Files\FLV Toolbar\IE\9.9\flvToolbarIE64.dll a variant of Win64/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\FRST\Quarantine\C\Program Files\gorillaprice\gorillaprice.exe a variant of Win32/AdWare.GorillaPrice.F application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\DynLib.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\freebl3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\Interop.PCProxyLib.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\libnspr4.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\libplc4.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\libplds4.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\nss3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\nssckbi.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\nssdbm3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\nssutil3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\plsapp.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\plsapp.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\plsappDLL.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\plsappLSP.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\plsappLSP64.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\pureleads-win-upgrader.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeads.Library.dll a variant of MSIL/Adware.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeads.Service.exe a variant of MSIL/Adware.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeadsControl.exe Win32/AdWare.Sendori.C application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeadsSvc.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeadsTray.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\PureLeadsUp.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\smime3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\softokn3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\sqlite3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\ssl3.dll a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\FRST\Quarantine\C\Program Files\PureLeads\Uninstall.exe a variant of Win32/AdWare.Sendori.A application cleaned by deleting - quarantined
    C:\ProgramData\FLV.com FLV Downloader\ytd_installer.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\005\vulsrsebjh32.exe.vir a variant of Win32/AdWare.Adpeak.F application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\click-n-mark\clandm.exe.vir a variant of Win32/AdWare.AddLyrics.AF application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\click-n-mark\ClickAndMark_wd.exe.vir a variant of Win32/AdWare.AddLyrics.AJ application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\SearchSettings64.exe.vir a variant of Win64/Toolbar.Widgi.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\wth189.dll.vir a variant of Win32/Toolbar.Widgi.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\wthx189.dll.vir a variant of Win64/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Free Games 111\ScRIpthost.dll.vir a variant of Win32/Toolbar.Besttoolbars.J potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\PC Performer\PCPerformer.dll.vir Win32/PCPerformer.B potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\PC Performer\PCPerformer.exe.vir a variant of Win32/Systweak potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Quiknowledge\IE\QuiknowledgeClientIE.dll.vir a variant of Win32/AdWare.Vitruvian.C application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Quiknowledge\Service\qksvc.exe.vir a variant of Win32/AdWare.Vitruvian.C application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\SaveSenseLive.exe.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\npGoogleUpdate3.dll.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\psmachine.dll.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\SaveSenseLive.exe.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\SaveSenseLiveBroker.exe.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\SaveSenseLiveHandler.exe.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\SaveSenseLive\Update\1.3.23.0\SaveSenseLiveOnDemand.exe.vir Win32/SaveSense.A potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\del_DM_DLL_nsqA8DF.dll.vir a variant of Win32/Toolbar.SearchSuite.C potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\del_DM_LL_nsqA8DF.dll.vir a variant of Win32/Toolbar.SearchSuite.C potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\del_mg_nsqA8DF.dll.vir a variant of Win32/Toolbar.SearchSuite.S potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\Helper.dll.vir a variant of Win32/Toolbar.SearchSuite.Q potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\Internet Explorer Settings.exe.vir a variant of Win32/Toolbar.SearchSuite.Q potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\sysapcrt.dll.vir a variant of Win32/Toolbar.SearchSuite.C potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\syskldr.dll.vir a variant of Win32/Toolbar.SearchSuite.S potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\syskldr_u.dll.vir a variant of Win32/Toolbar.SearchSuite.S potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\systemkbho.dll.vir a variant of Win32/Toolbar.SearchSuite.C potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\systemkChrome.dll.vir a variant of Win32/AdWare.Bandoo.AE application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\systemkmgrc1.cfg.vir Win32/AdWare.Bandoo.AF application cleaned by deleting - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\SystemkService.exe.vir a variant of Win32/Toolbar.SearchSuite.D potentially unwanted application deleted - quarantined
    C:\Qoobox\Quarantine\C\Program Files\Settings Manager\systemk\systemku.exe.vir a variant of Win32/Toolbar.SearchSuite.Q potentially unwanted application deleted - quarantined
  11. 2014/10/25
    Update your Java version here: http://www.java.com/en/download/manual.jsp
    Alternate download: http://www.filehippo.com/search?q=java
    Note 2: If you're running 64-bit system make sure you install BOTH, 32-bit and 64-bit Java.
    Note 3: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. If you don't want to run another extra service, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and restart your computer.
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  12. 2014/10/25
    Thank you very much. I believe this machine is running very well.. I have been letting it run most all day, and after you gave the all clear sign, I did re download TFC, ADWARE, JRT. I removed Norton with the tool you provided and replaced it with BitDefender.. I'll let it run a few more hours
    I think you can mark this thread as [RESOLVED]
    Now on to number 2
    Regards
  13. 2014/10/25
    Way to go!! [​IMG]
    Good luck and stay safe :)
