Solved malware from oovoo
Discussion in 'Malware and Virus Removal Archive' started by molsonrn, 2011/02/02.
  1. 2011/02/12
    molsonrn
    molsonrn Inactive Thread Starter
    things are really good and i'm afraid to do anything now!
  2. 2011/02/12
    Proceed with my reply #31.
    molsonrn
    otl
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: LocalService
    ->Temp folder emptied: 65748 bytes
    ->Temporary Internet Files folder emptied: 1278086 bytes
    ->Java cache emptied: 0 bytes
    ->Flash cache emptied: 4079 bytes
    User: Melanie
    ->Temp folder emptied: 837320 bytes
    ->Temporary Internet Files folder emptied: 98528687 bytes
    ->FireFox cache emptied: 45007709 bytes
    ->Flash cache emptied: 2126 bytes
    User: NetworkService
    ->Temp folder emptied: 2968 bytes
    ->Flash cache emptied: 49454 bytes
    Windows Temp folder emptied: 86610 bytes
    RecycleBin emptied: 53960022 bytes
    Total Files Cleaned = 191.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: LocalService
    User: Melanie
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.20.6 log created on 02132011_155634
    C:\Documents and Settings\Melanie\Local Settings\Temp\IadHide4.dll moved successfully.
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF2F82.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF2F94.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF6AF2.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF6B06.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF712.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DF76E.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DFEF9.tmp not found!
    File\Folder C:\Documents and Settings\Melanie\Local Settings\Temp\~DFF22.tmp not found!
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\Content.IE5\5689GZ6Z\iframescript[1].htm moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\Content.IE5\5689GZ6Z\iframescript[3].htm moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\Content.IE5\3CKJDQUL\97636-active-malware-oovoo-3[1].html moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\Content.IE5\3CKJDQUL\vmus39814_iframe[1].htm moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\Content.IE5\3CKJDQUL\vmus39814_iframe_control[1].htm moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\AntiPhishing\2CEDBFBC-DBA8-43AA-B1FD-CC8E6316E3E2.dat moved successfully.
    C:\Documents and Settings\Melanie\Local Settings\Temporary Internet Files\SuggestedSites.dat moved successfully.
    File\Folder C:\WINDOWS\temp\_avast5_\Webshlock.txt not found!
    File\Folder C:\WINDOWS\temp\Perflib_Perfdata_5f8.dat not found!
  5. 2011/02/13
    molsonrn
    today
    Things seem pretty good now...thank you once again.
  6. 2011/02/13
    You're very welcome :)
    Good luck and stay safe :)
