Macromedia problems
Discussion in 'Security and Privacy' started by jd0427, 2004/07/22.
  1. 2004/07/27
    jd0427
    jd0427 Inactive Thread Starter
    Hi Mark,
    I downloaded LSPfx.exe and ran it. The file 'Ao2lsp.dll' is in the 'Remove' column. I read the lspfix.txt file, and I don't understand what it is that I need to do to 'fix' it. I know I can check 'I know what I'm doing' (but, I really don't,lol) and move it over to the 'Keep' column, but, does doing just that, fix it. Also, in reading the .txt file, it says that it will fix my inability to access the internet, but, I don't have that problem, or, do I and just don't know it?
    One more thing, I use gator. I know that it gives me a lot of pop-up ads, but, I do use it and would like to keep it, unless it is REALLY is harmful to the PC.
    Thanks for your time, effort, patience, & knowledge.
    Jean
  2. 2004/07/27
    noahdfear
    noahdfear Inactive
    Hi Jean :)
    Actually, the Ao2lsp.dll file is a valid one, and does not have to be fixed. It is part of the program AdsOff 2 Ad Filter, which is no longer supported. Did you install that program? It also doesn't appear to be designed for use with XP.
    http://www.pcworld.com/downloads/file_description/0,fid,6182,00.asp
    If you uninstall it, and your internet connection is lost, you will need to run the LSPFix. Just open it, check the box 'I know what I'm doing' and click finish.
    Gator is not only delivering you pop-ups, it is considered Spyware, and should be removed. What is it that you use it for? We may be able to recommend an alternative.
    jd0427
    Hi Dave,
    I use it for mostly for remembering ALL of my login/passwords, and also for filling in forms. I do not use the credit card feature.
    If there is an alternative I would need to transfer all of the data from Gator.
    I have seen others that would limit the number (I think 30) login/passwords, and I have many more than that.
    Your help is most appreciated. :)
    Jean
  5. 2004/07/27
    Bmoore1129
    Bmoore1129 Geek Member
    jd0427
    Hi Bill,
    I checked it out, and it looks like it only has 30 login/passwords, and it's not free. I need lot more than 30.
    Thanks for the suggestion,
    Jean
  7. 2004/07/27
    Jean - wouldn't it simplify your life some if you cut back to only a few login names and passwords? I get by with about 4 and only need that many to take care of the various different naming & password rules for the sites I use.
  8. 2004/07/27
    markp62
    markp62 Geek Member Alumni
    If you want to keep Gator, that is your choice. But since this is the Security/Virus/Spyware forum, just about the only advice I'll give you is to remove it.
    Have you ever used Internet Explorer's ability to handle username's and password's?
    Mozilla and Firefox have good username and password abilities, you have the ability to delete unwanted or incorrect entries in the Password Manager.
    Both are free.
  9. 2004/07/28
    jd0427
    Hi all,
    Ok, I'm going to be busy today checking/verifying all logins/password that gator has stored, and copying them. I'll check back when that's done and I've uninstalled Gator.
    Thanks again everyone,
    Be back soon,
    Jean
  10. 2004/07/28
    Bmoore1129
    Hey Jean,
    Roboform will copy your Gator stuff to the program and save you a lot of Copy/Paste operations. The link is still on message #24 of this thread if you want to try.
    I never did find where it said it was restricted to 30 but I think you can get by that by making multiple users.
    The free version is what I have been using for a couple of years and it reminds me if there is a new version available and down loads it and installs it and doesn't lose any of your stored info in the process. Also no spyware or advertizements at all.
    Just a thought that may save you a lot of time... :)
  11. 2004/07/28
    jd0427
    Bill,
    Thank you. I'm going to try that right now.
    Jean
  12. 2004/07/28
    noahdfear
    noahdfear Inactive
  13. 2004/07/28
    jd0427
    Hello again,
    Well, downloaded and installed Roboform. Bill, you are right, it does export login/passwords from gator, and it does allow for more than 30. Thank you.
    After that, I uninstalled Gator. Rebooted - ran Spybot and Ad-Aware to clean it out again, ran HJT and here is the latest log. It's still too long for one post, so, here's Part 1
    Logfile of HijackThis v1.97.7
    Scan saved at 7:25:04 PM, on 7/28/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Norton AntiVirus\navapsvc.exe
    C:\WINDOWS\System32\nvsvc32.exe
    C:\Program Files\Norton AntiVirus\SAVScan.exe
    C:\WINDOWS\System32\tcpsvcs.exe
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\windows\system\hpsysdrv.exe
    C:\Windows\system32\HpSrvUI.exe
    C:\HP\KBD\KBD.EXE
    C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
    C:\Program Files\Hewlett-Packard\HP OfficeJet Series 500\bin\ktchnsnk.exe
    C:\Program Files\CursorXP\CursorXP.exe
    C:\Program Files\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe
    C:\Program Files\BigFix\BigFix.exe
    C:\Palm\HOTSYNC.EXE
    C:\Program Files\Webshots\WebshotsTray.exe
    C:\Documents and Settings\Owner\Desktop\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1:9022
    O1 - Hosts: 64.215.170.96 securityresponse.symantec.com
    O1 - Hosts: 206.204.52.5 symantecsecurity.com
    O1 - Hosts: 65.200.215.12 housecall.trendmicro.com
    O1 - Hosts: 128.121.221.219 www.sendfunpages.com
    O1 - Hosts: 207.68.178.238 rad.msn.com
    O1 - Hosts: 209.87.112.28 earn.mypoints.com
    O1 - Hosts: 65.115.131.127 www.ez-mortgage.com
    O1 - Hosts: 66.227.17.149 www.registry-first-aid.com
    O1 - Hosts: 64.246.42.33 www.infinisource.com
    O1 - Hosts: 63.151.147.55 www.lobstersoft.com
    O1 - Hosts: 217.106.235.203 www.gamesbanner.net
    O1 - Hosts: 65.39.136.108 www.asentus.net
    O1 - Hosts: 209.115.240.249 cardgamecentral.com
    O1 - Hosts: 205.174.16.12 e.delta.com
    O1 - Hosts: 205.174.16.50 www.delta.com
    O1 - Hosts: 205.138.230.129 www.americanexpress.com
    O1 - Hosts: 66.151.158.176 img.gotomypc.com
    O1 - Hosts: 12.29.100.56 ssologin.americanexpress.com
    O1 - Hosts: 12.29.100.115 www64.americanexpress.com
    O1 - Hosts: 216.109.127.60 login.yahoo.com
    O1 - Hosts: 66.77.22.105 jobs.brassring.com
    O1 - Hosts: 216.136.224.130 us.f147.mail.yahoo.com
    O1 - Hosts: 209.179.82.43 www.regrow.com
    O1 - Hosts: 216.32.6.102 www.drugstore.com
    O1 - Hosts: 64.235.234.30 www.thestaffguide.com
    O1 - Hosts: 65.245.67.101 www.comptia.org
    O1 - Hosts: 63.81.68.3 www.cheaptickets.com
    O1 - Hosts: 63.163.247.24 secure.pentontech.com
    O1 - Hosts: 64.26.22.57 www.itcertifyhome.com
    O1 - Hosts: 63.99.224.16 www.real-certify.com
    O1 - Hosts: 64.124.201.45 go.columbiahouse.com
    O1 - Hosts: 63.89.139.81 www.ertltoys.com
    O1 - Hosts: 211.38.186.169 gmp.com
    O1 - Hosts: 211.38.186.163 www.gmp.co.kr
    O1 - Hosts: 216.122.248.107 www.suttonsracing.com
    O1 - Hosts: 207.89.178.40 www.nostalgiamotorsports.com
    O1 - Hosts: 161.58.173.116 ssl.monthlycalling.com
    O1 - Hosts: 209.87.112.25 www.mypoints.com
    O1 - Hosts: 199.2.246.79 www.woodyswatch.com
    O1 - Hosts: 216.230.240.97 www.msusapartnerreadiness.com
    O1 - Hosts: 65.54.230.240 login.passport.com
    O1 - Hosts: 65.54.225.252 login.passport.net
    O1 - Hosts: 207.46.196.50 register.microsoft.com
    O1 - Hosts: 205.188.243.121 www.mapquest.com
    O1 - Hosts: 12.32.71.232 www.pinnacle.com
    O1 - Hosts: 64.225.154.175 www.pinnacletraining.com
    O1 - Hosts: 212.190.116.43 www.freedownloadscenter.com
    O1 - Hosts: 216.55.128.40 www.paranormal.org
    O1 - Hosts: 209.247.51.57 pub57.ezboard.com
    O1 - Hosts: 142.167.11.75 www.stephenking.com
    O1 - Hosts: 216.92.15.218 www.paraseek.com
    O1 - Hosts: 216.254.10.116 www.historylink.org
    O1 - Hosts: 64.78.44.87 www.beaumontuniversity.net
    O1 - Hosts: 164.109.16.142 www.kraftfoods.com
    O1 - Hosts: 12.22.155.114 www.mastercard.com
    O1 - Hosts: 216.239.57.100 pagead.googlesyndication.com
    O1 - Hosts: 64.94.178.72 www9.dealtime.com
    O1 - Hosts: 199.106.235.5 survey.npdor.com
    O1 - Hosts: 216.230.210.124 www.wirebike.com
    O1 - Hosts: 207.241.152.130 www.newyorkmetro.com
    O1 - Hosts: 216.136.224.156 store.yahoo.com
    O1 - Hosts: 69.0.187.248 www.timelypieces.com
    O1 - Hosts: 64.78.57.243 finebrandwatches.com
    O1 - Hosts: 209.41.187.175 www.americasjewelry.com
    O1 - Hosts: 128.242.104.140 daily.webshots.com
    O1 - Hosts: 128.242.104.137 www.webshots.com
    O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
    O2 - BHO: Popup Manager - {08E74C67-99A6-45C7-94DA-A397A8FD8082} - (no file)
    O2 - BHO: SpywareGuard Download Protection - {4A368E80-174F-4872-96B5-0B27DDD11DB2} - C:\Program Files\SpywareGuard\dlprotect.dll (file missing)
    O2 - BHO: (no name) - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboForm.dll
    O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\windows\googletoolbar1.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: FDA Bar - {9595C62C-76C6-49A6-9BDA-3253DD7A34FF} - C:\Program Files\Free Downloads Accelerator\fdabar.dll
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: MSN Toolbar - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\MSN Toolbar\01.01.1517.0\en-us\msntb.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\windows\googletoolbar1.dll
    O3 - Toolbar: &RoboForm - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboForm.dll
    O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    O4 - HKLM\..\Run: [hp Silent Service] C:\Windows\system32\HpSrvUI.exe
    O4 - HKLM\..\Run: [hpScannerFirstBoot] c:\hp\drivers\scanners\scannerfb.exe
    O4 - HKLM\..\Run: [PreloadApp] c:\hp\drivers\printers\photosmart\hphprld.exe c:\hp\drivers\printers\photosmart\setup.exe -d
    O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
    O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\System32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\System32\hkcmd.exe
    O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
    O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
    O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
    O4 - HKLM\..\Run: [BootWarn] C:\Program Files\Norton AntiVirus\BootWarn.exe /a
    O4 - HKLM\..\Run: [HP OfficeJet Series 500] "C:\Program Files\Hewlett-Packard\HP OfficeJet Series 500\bin\ktchnsnk.exe" -reg "Software\Hewlett-Packard\OfficeJet Series 500\Install "
    O4 - HKCU\..\Run: [CursorXP] C:\Program Files\CursorXP\CursorXP.exe
    O4 - HKCU\..\Run: [Acme.PCHButton] C:\PROGRA~1\HPINST~1\plugin\bin\PCHButton.exe
    O4 - HKCU\..\Run: [Microsoft Works Update Detection] c:\Program Files\Microsoft Works\WkDetect.exe
    O4 - HKCU\..\Run: [RoboForm] "C:\Program Files\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe "
    O4 - Startup: Webshots.lnk = C:\Program Files\Webshots\WebshotsTray.exe
    O4 - Global Startup: BigFix.lnk = C:\Program Files\BigFix\BigFix.exe
    O4 - Global Startup: HotSync Manager.lnk = C:\Palm\HOTSYNC.EXE
  14. 2004/07/28
    jd0427
    And, here's Part 2.
    O8 - Extra context menu item: &Add animation to IncrediMail Style Box - C:\PROGRA~1\INCRED~1\bin\resources\WebMenuImg.htm
    O8 - Extra context menu item: &Google Search - res://c:\windows\GoogleToolbar1.dll/cmsearch.html
    O8 - Extra context menu item: Backward &Links - res://c:\windows\GoogleToolbar1.dll/cmbacklinks.html
    O8 - Extra context menu item: Cac&hed Snapshot of Page - res://c:\windows\GoogleToolbar1.dll/cmcache.html
    O8 - Extra context menu item: Customize Menu &4 - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html
    O8 - Extra context menu item: Download with Free Downloads Accelerator - C:\Program Files\Free Downloads Accelerator\fdaie.htm
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\Office10\EXCEL.EXE/3000
    O8 - Extra context menu item: Fill Forms &] - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComFillForms.html
    O8 - Extra context menu item: MyPoints - file://C:\Program Files\MyPointsPointAlert\System\Temp\mypoints_script0.htm
    O8 - Extra context menu item: Save Forms &[ - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComSavePass.html
    O8 - Extra context menu item: Search Dictionary - file://\program files\powershell-xp2\search4.htm
    O8 - Extra context menu item: Search for Images - file://\program files\powershell-xp2\search3.htm
    O8 - Extra context menu item: Search Newsgroups - file://\program files\powershell-xp2\search2.htm
    O8 - Extra context menu item: Search the Web - file://\program files\powershell-xp2\search.htm
    O8 - Extra context menu item: Si&milar Pages - res://c:\windows\GoogleToolbar1.dll/cmsimilar.html
    O8 - Extra context menu item: Translate into English - res://c:\windows\GoogleToolbar1.dll/cmtrans.html
    O9 - Extra 'Tools' menuitem: Sun Java Console (HKLM)
    O9 - Extra button: MktBrowser (HKLM)
    O9 - Extra 'Tools' menuitem: MarketBrowser (HKLM)
    O9 - Extra button: Fill Forms (HKLM)
    O9 - Extra 'Tools' menuitem: Fill Forms &] (HKLM)
    O9 - Extra button: Save (HKLM)
    O9 - Extra 'Tools' menuitem: Save Forms &[ (HKLM)
    O9 - Extra button: RoboForm (HKLM)
    O9 - Extra 'Tools' menuitem: RF Toolbar &2 (HKLM)
    O9 - Extra button: AIM (HKLM)
    O9 - Extra button: Messenger (HKLM)
    O9 - Extra 'Tools' menuitem: Messenger (HKLM)
    O9 - Extra button: Point Alert (HKCU)
    O12 - Plugin for .bcf: C:\Program Files\Internet Explorer\Plugins\NPBelv32.dll
    O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
    O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/c381/chat.cab
    O16 - DPF: Yahoo! Freecell Solitaire - http://yog55.games.scd.yahoo.com/yog/y/fs9_x.cab
    O16 - DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} (Microsoft Office Template and Media Control) - http://office.microsoft.com/templates/ieawsdc.cab
    O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - http://www.apple.com/qtactivex/qtplugin.cab
    O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (sys Class) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
    O16 - DPF: {11865A2A-649F-4FA1-8B99-B97DF8070B7C} (IWSystemchecks Control) - http://msfm.interwise.com/msfm/English/ActiveX/IWsystemchecks.cab
    O16 - DPF: {11B2C0D3-DFFB-11D3-9253-00500498D7E2} (ShowSetupObj2 Class) - http://invite.mshow.com/ShowSetup2.dll
    O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) - http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    O16 - DPF: {17163BB4-107E-11D4-9B76-006097DF2317} (EABootStrap Class) - http://www.ea.com/downloads/games/common/boot_strap/iegils.cab
    O16 - DPF: {20F6D002-518C-4FA3-8636-B2604E65E1B5} (URLDownload Class) - http://www2.bingoblowout.com/client/webbingo/controls/BingoBlowout.CAB
    O16 - DPF: {2B323CD9-50E3-11D3-9466-00A0C9700498} (Yahoo! Audio Conferencing) - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/v45/yacscom.cab
    O16 - DPF: {3AF4DACE-36ED-42EF-9DFC-ADC34DA30CFF} (PatchInstaller.Installer) - file://D:\content\include\XPPatchInstaller.CAB
    O16 - DPF: {3E68E405-C6DE-49FF-83AE-41EE9F4C36CE} (Office Update Installation Engine) - http://office.microsoft.com/officeupdate/content/opuc.cab
    O16 - DPF: {4E330863-6A11-11D0-BFD8-006097237877} (InstallFromTheWeb ActiveX Control) - http://msfm.interwise.com/IWCampus/student/client/iftwclix.cab
    O16 - DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} (RdxIE Class) - http://207.188.7.150/0494bff0d5681bf68100/netzip/RdxIE601.cab
    O16 - DPF: {597C45C2-2D39-11D5-8D53-0050048383FE} (OPUCatalog Class) - http://office.microsoft.com/productupdates/content/opuc.cab
    O16 - DPF: {6A060448-60F9-11D5-A6CD-0002B31F7455} (ExentInf Class) - http://us.games2.yimg.com/download.games.yahoo.com/games/play/client/exentctl_0_0_0_1.ocx
    O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2003031901/housecall.antivirus.com/housecall/xscan53.cab
    O16 - DPF: {7B297BFD-85E4-4092-B2AF-16A91B2EA103} (WScanCtl Class) - http://www3.ca.com/securityadvisor/virusinfo/webscan.cab
    O16 - DPF: {814EA0DA-E0D9-4AA4-833C-A1A6D38E79E9} (DASWebDownload Class) - http://das.microsoft.com/activate/cab/x86/i486/NTANSI/retail/DASAct.cab
    O16 - DPF: {9059F30F-4EB1-4BD2-9FDC-36F43A218F4A} (Microsoft RDP Client Control (redist)) - http://www.entirenet.net/hdattend/shared/msrdp.cab
    O16 - DPF: {917623D1-D8E5-11D2-BE8B-00104B06BDE3} (CamImage Class) - http://hawaiilive.sheraton-hawaii.com/AxisCamControl.ocx
    O16 - DPF: {9522B3FB-7A2B-4646-8AF6-36E7F593073C} (cpbrkpie Control) - http://a19.g.akamai.net/7/19/7125/1435/ftp.coupons.com/v3123/cpbrkpie.cab
    O16 - DPF: {9732FB42-C321-11D1-836F-00A0C993F125} (mhLabel Class) - http://www.pcpitstop.com/mhLbl.cab
    O16 - DPF: {98BC86B6-F34A-4BCB-8F82-489C5F59EC2B} (VMRCClientControl Class) - http://www.entirenet.net/hdattend/shared/VMRCActiveXClient.cab
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} (Update Class) - http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?37886.2678125
    O16 - DPF: {AE1C01E3-0283-11D3-9B3F-00C04F8EF466} (HeartbeatCtl Class) - http://fdl.msn.com/zone/datafiles/heartbeat.cab
    O16 - DPF: {C1BAC744-8F0B-11D0-89E7-00C0A8295197} (Cameractl Class) - http://www.lochness.scotland.net/push.cab
    O16 - DPF: {C2FCEF52-ACE9-11D3-BEBD-00105AA9B6AE} (Symantec RuFSI Registry Information Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
    O16 - DPF: {CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA} (Java Runtime Environment 1.4.0) -
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {D32C3BAD-5213-49BD-A7D5-E6DE6C0D8249} (CRAVOnline Object) - http://www.ravantivirus.com/scan/ravonline.cab
    O16 - DPF: {DE22A7AB-A739-4C58-AD52-21F9CD6306B7} (CTAdjust Class) - http://www.microsoft.com/typography/clearadj.cab
    O16 - DPF: {DF6A0F17-0B1E-11D4-829D-00C04F6843FE} (Microsoft Office Tools on the Web Control) - http://officeupdate.microsoft.com/TemplateGallery/downloads/outc.cab
    O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} (PopCapLoader Object) - http://anu.popcap.com/games/popcaploader_v5.cab
    O16 - DPF: {E93A6FCA-C052-45DF-AC9B-B729066092F8} (Util Class) - https://isupport4.hp.com/motivedocs/linklauncher/MotUtil.cab
    O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/vso/en-us/tools/mcfscan/2,0,0,4375/mcfscan.cab
    O16 - DPF: {F00F4763-7355-4725-82F7-0DA94A256D46} (IMDownloader Class) - http://www2.incredimail.com/contents/setup/downloader/imloader.cab
    O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} (MSN Chat Control 4.5) - http://chat.msn.com/bin/msnchat45.cab
  15. 2004/07/29
    jd0427
    Hi,
    After 'fixing' those items suggested by markp62, I have 34 backup files on my desktop. Can I delete these?
    Thanks,
    Jean
  16. 2004/07/29
    I'd keep them for a while just as a safety measure.
    I'd also put the Hijackthis exe and the backups in their own folder to prevent junking up your desktop. Maybe c:\hjt or if you run multiple items, c:\anti-spyware\hjt (and put the other similar items in their own folders there too).
    How about another HJT log posting. You have so much stuff that a thing or three might easily have been missed from the first one.
  17. 2004/07/29
    jd0427
    Thanks for the info. Gladly sending another HJT log.
    Again, thank you for all of your interest and help.
    Jean
    Scan saved at 7:15:03 PM, on 7/29/2004
    C:\HP\KBD\KBD.EXE
    C:\Palm\HOTSYNC.EXE
    C:\Program Files\MSN\MSNCoreFiles\msn.exe
    C:\Program Files\MSN\MSNIA\msniasvc.exe
    C:\Program Files\MSN\MSNIA\WA\ClientSideProxy.exe
    C:\Program Files\MSN Messenger\msnmsgr.exe
    C:\Program Files\Windows Media Player\wmplayer.exe
    C:\Documents and Settings\Owner\Desktop\AntiVirus\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://iwon.com/
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
    O8 - Extra context menu item: View Original Image - C:\program files\msn\msnia\wa\getoriginal.htm
    O17 - HKLM\System\CCS\Services\Tcpip\..\{5E96071F-371B-439F-AD47-E852760179E0}: NameServer = 205.171.3.65 205.171.2.65
  18. 2004/07/29
    Some general comments.
    C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe - you are about 2 versions behind and would be doing yourself a favor to update from version 03 to version 05. http://www.java.com/en/download/windows_automatic.jsp
    The long string of 01 Hosts entries aren't really needed. They do allow your PC to bypass DNS for any site listed there so in theory give you faster access to the site but in practice, the difference isn't enough to notice. The downside of a static hosts file is when any of the sites change IP address (and they do on occasion), if you have the old one in a hosts file you'll never reach the site at it's new IP address.
    The huge mass of 016 DPF entries probably contains some that you don't need any longer. My understanding is that if you remove one of them and it's needed when you visit the site, it will be added back for you. Might speed things up to get rid of the entire crop and just get the ones you need added back in. Slight delay when first reloading one of them but not much even with 56Kb dial-up. Wait for confirmation from one of the real security pros on this though.
    There will also likely be some specific 'bad thing' removal instructions added. For instance, this is one that I think is probably a bad thing (but not sure so wait on the experts)
  19. 2004/07/29
    markp62
    Other than the start page pointed out by Newt, I see nothing bad in the log.
    Do the Java update, and you should be good to go.
  20. 2004/07/31
    jd0427
    Hi again,
    Sorry for the delay in my responding, but. life got in the way.
    Ok, removed hosts, some of the 16DPF files and the R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://iwon.com/.
    Then uninstalled Flash and Shockwave Players -> rebooted -> installed Flash and Shockwave Players -> rebooted and voila, it was working again.
    Rebooted, and now not working.
    Here is the latest log...
    Scan saved at 5:56:25 PM, on 7/31/2004
    C:\HP\KBD\KBD.EXE
    C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
    C:\Palm\HOTSYNC.EXE
    C:\Program Files\Common Files\Real\Update_OB\realevent.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
    O17 - HKLM\System\CCS\Services\Tcpip\..\{5E96071F-371B-439F-AD47-E852760179E0}: NameServer = 205.171.3.65 205.171.9.251
    Any ideas?
    Thanks again for ALL of your (all of you) help.
    Jean
  21. 2004/08/02
    jd0427
    Should I start a new thread for the macromedia failure?
    Thanks,
    Jean :confused:
