Solved Machine Sluggish and Not Responding Too Often
Discussion in 'Malware and Virus Removal Archive' started by Blue Star, 2015/03/17.
  1. 2015/03/20
    [​IMG] Update Firefox to the current version.
    [​IMG] Update Adobe Flash Player: http://get.adobe.com/flashplayer/
    Make sure you UN-check Yes, install McAfee Security Scan Plus
    NOTE 1: Beginning with Adobe Flash Version 11.3, the universal installer includes the 32-bit and 64-bit versions of the Flash Player.
    NOTE 2: While installing make sure you UN-check any extra garbage which wants to install alongside.
    [​IMG] Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions (if present).
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    [​IMG] Update your Java version here: http://www.java.com/en/download/manual.jsp
    Alternate download: http://www.filehippo.com/search?q=java
    Note 2: If you're running 64-bit system make sure you install BOTH, 32-bit and 64-bit Java.
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Scan without installing plugin" and then on "Scan now ")
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  2. 2015/03/21
    Blue Star
    Blue Star Well-Known Member Thread Starter
    working on all the above
    Blue Star
    Many Thanks!!
    :D Thank you soooo much for your help once again!
    Just one question.. do I run all the cleaning tools for each browser... or does once on my main browser do the job?
    Thank you...
    Ari :D
  5. 2015/03/21
    Which cleaning tools do you have in mind?
  6. 2015/03/22
    Blue Star
    TFC... AdwCleaner ... Junk Remover Tool
  7. 2015/03/22
    They run as separate programs and they check all browsers.
    Good luck and stay safe :)
  8. 2015/03/22
    Blue Star
    Many thanks!
    You are a true gem Broni ....thank you so much!!!:D
  9. 2015/03/22
    You're very welcome [​IMG]
  10. 2015/03/24
    Blue Star
    https://www.google.com/?trackid=sp-006
    Good evening Broni...
    I get this in the address bar when I open Chrome... is this normal? Part of the initial problem? ,,, Or shall I run a new scan and post in a new thread?
    Also unable to d/l purchased ebook in Chrome or Firefox... just blinks... If I d/l in IE...it crashes the browser.. geezzz... lol
  11. 2015/03/24
    That's normal in address bar.
    As for downloading issue create new topic in appropriate forum.
  12. 2015/03/24
    Blue Star
    Thanks a bunch sweetie! :)
  13. 2015/03/25
    [​IMG].....
