Resolved Lost sound
Discussion in 'Windows XP' started by lloyd, 2012/05/12.
  1. 2012/05/12
    lloyd
    lloyd Inactive Thread Starter
    I lost all sound on my HP desktop, I go to sound and audio device properties and I cant seem to activate it. I am using the built in speaker. I also checked the hardware devices and there is no conflict, it say's everything is working.
    So I have no speaker or volume control on my task bar. I have tried the troubleshooting exercises but no luck.
    I would appreciate some help, My operating system is Windows XP.
    On my desktop I have model HST NC.016P.SF HP Compaq AMD Athlon(TM)64X2 dual core.
    I did a system search and it idintified my computer as HP Compaq DC5700 PC series.
    The built in system speaker is always on, and used for music and communication.
    I have tried your sugestions, thanks but no luck as yet.
  2. 2012/05/12
    Hi, try Uninstalling in Device Manager > Shut down > Reboot and see if Windows installs it again.
    Have you updated Drivers for Sound System? Neil.
    Hi lloyd, Welcome to Windowsbbs! :)
    Adding to what Neil said, is the sound device listed in device manager? What sound device is installed on your system? Did the loss of sound just happen randomly?
    It sounds to me like you need to get updated drivers for your sound device in order to get it working again.
    Also please enter your System Details. It helps us in answering your questions.
    Note: A common error is to forget to show your System Details in your profile:
    Make sure to do the above when entering your System Details, thanks.
  5. 2012/05/13
    hawk22
    hawk22 Geek Member
    Is Volume Control ticked on,
    look here
    Go to Control Panel.
    Double click on Sound and Audio Devices to open.
    In the open window, select Volume in the menu bar.
    Tick the box Place volume icon in the taskbar.
  6. 2012/05/13
    SpywareDr
    What built-in speaker?
    Do you mean the little piezoelectric single frequency beeper on the motherboard?
    What's the model number of the HP desktop?
  7. 2012/05/13
    Dr. we are still waiting for lloyd to fill in his System Details. Lloyd, if you go to FileHippo and have a look around, try Everest Home to find out whats in your comp. Cheers Neil.
  8. 2012/05/28
    lloyd
    Thank you all for your suggestions I finaly got my sound again, I deleted the driver and reinstalled it with the updates
  9. 2012/05/28
    lloyd
    Thank you all, my problem have been resolved
    I deleted the sound driver and reinstalled it, It's now working again
  10. 2012/05/28
    Thanks for the update. :)
  11. 2012/05/29
    Nice to know it worked. Neil.;)
  12. 2012/06/03
    lloyd
    problem resolved thank you all
