Solved logs of dds,mbrcheck as requested
Discussion in 'Malware and Virus Removal Archive' started by janwin7, 2011/04/03.
  1. 2011/04/07
    Whenever ready.....
  2. 2011/04/07
    janwin7
    janwin7 Inactive Thread Starter
    results
    Thank you Broni for your help! You're the man!!!!!!!!
    I think, for now, that the first one of my 3 pc's is doing well. I hope it stays this way. He is slow, but maybe there is something we can do about this.
    I deleted all the programs i had to install to fix my computer. And i installed the other ones to prevent getting spyware on it.
    So, can you help me fixing the other 2 pc's too? Thank you!:)
    You need more RAM.
    Windows 7 will run much better with at least 2GB of RAM.
    As for other computers, create separate topics for each one.
    Good luck and stay safe :)
  5. 2011/04/07
    janwin7
    Thank you i will work on it. It's a small laptob, so i don't know if i can get the 2GB. I will look for it.
    What about the other pc's? Do i start an new topic? Or do we continue till they are all clean? :)
  6. 2011/04/07
    janwin7
    Ok i will. Thanks!!!
  8. 2011/04/07
    Sure thing :)
