Resolved Loaded on XP SP3 on Dell Inspiron 1520 Internet will not work
Discussion in 'Networking (Hardware & Software)' started by desertbluesman, 2017/07/08.
  1. 2017/07/08
    desertbluesman
    desertbluesman Well-Known Member Thread Starter
    I loaded on the dell XP OS disk and I can not get the computer to recognize the Intel wireless even after installing SP3. It keeps asking for some kind of safety password, I tried the safety password from my router which is numbers only. I tried the wep key, it is looking for numbers only no letters. My wep key has letters characters and numbers in it. I also went out to Dell and downloaded and installed the latest Intel networking drivers. I don't get it, it never acted like this when I first bought the computer. Any help would be appreciated.
  2. 2017/07/08
    Hi desertbluesman. Can you provide a screenshot of the safety password dialog box that shows up?
    Have you tried hardwiring the computer to your router first via an Ethernet cable to make sure you have a secure connection, and then try connecting wirelessly to it?
    desertbluesman
    Thanks amigo, I do have a screen shot see below. I have not tried to hard wire it to the router yet. I am working wireless now on my HP laptop The connection works for both my laptop and desktop perfectly. And it worked perfectly before I reloaded XP and SP3. I tried loading on XP Pro then the Dell rescue disk, no luck. Thanks for your reply.
  5. 2017/07/08
    elcajongunsfan Lifetime Subscriber
    elcajongunsfan Well-Known Member
    Well,,this is fascinating... My first dumb question is, do you have a domain setup (win server, etc)
  6. 2017/07/09
    It's asking for a WPS key, which is a password hard coded in the router (connections are automatically established by pushing a button on router or entering a Personal Id #). That's not what you want. When clicking on "Connect" you should have an option,a text link, to enter a passphrase instead. However, I suggest NOT using WEP as it is not secure. Use WPA instead.
    WEP uses the characters 0-9 & A-F, can be cracked in less than 2 minutes using free software.
    WPA uses any character.
  7. 2017/07/09
    desertbluesman
    Thanks all, I am thinking of buying a USB Wi Fi Adapter for 13 to 18 bucks, disabling the on board wi fi with the hardware switch and deleting the drivers for the Intel wi fi setup.
  8. 2017/07/09
    Buy a fast one like a 600N or depending on your router
    desertbluesman likes this.
  9. 2017/07/09
    desertbluesman
    Thanks, amigo
  10. 2017/07/09
    Ah, you're right, I didnt see that
  11. 2017/07/09
    desertbluesman
    "It's asking for a WPS key, which is a password hard coded in the router (connections are automatically established by pushing a button on router or entering a Personal Id #)"
    I did see the button on the router". Just push the button on the router with an open paper clip. With the dialog box pictured above open? I can also hard wire them together and push that button?
  12. 2017/07/09
    Are you using Windows to connect wirelessly to the network or the Intel wireless utility? Try connecting to the network via the Windows XP Wireless network area in the Control Panel and see if you can successfully connect to the network without having to use a WPS password.
  13. 2017/07/10
    What is the Model and specs of your Dell computer?
  14. 2017/07/10
    No! The WPS button on the router should be a button, the "hole" for paperclip use is likely a "reset" button, bit WPS button.
    Don't use WPS. Do this:
    a. Click the Start button and select Control Panel.
    b. Double-click Network Connections.
    c. Right-click on Wireless Network Connection and select Properties.
    d. Select the Wreless Networks tab. Be sure the option Use Windows to configure my wireless network settings is checked and click Add.
    e. Enter your network settings:
    i. Network name (SSID)
    ii. Select your security level in the Data encryption drop-down menu (Open for no security, or WEP, WPA, or WPA2).
    iii. Uncheck The key is provided for me automatically (This enables you to input your encryption key/passphrase).
    iv. Click OK.
    f. Confirm your network is listed in Preferred networks and click OK.
  15. 2017/07/10
    desertbluesman
    There is a button on the router, I found that yesterday it is a small button on the back there is also a large wireless button on the front of the router The router is a Netgear NR300 WNR 2000 I will also try the above. I did try this before but I was still having problems with it. I will try it again.
  16. 2017/07/10
    desertbluesman
    It is a Dell Inspiron 1520 Laptop with Intel Core Two Duo and 4 megs RAM Clean XP Home Install with SP 3 added on.
  17. 2017/07/10
    desertbluesman
    Thanks amigo's problem solved. Of all the places I asked this is the place where I got the answers I needed
  18. 2017/07/10
    Thanks for the update. :)
  19. 2017/07/10
    The reason I asked the question.
