Limited or No Connectivity Problem
Discussion in 'Networking (Hardware & Software)' started by Olly, 2009/01/29.
  1. 2009/01/29
    Olly
    Olly Inactive Thread Starter
    I recently blew my friends motherboard after installing extra RAM into it - ive replaced the board, and it found the already installed XP, everything worked ok except the net connection. It tried to connect but seemed to hang on Assigning an IP - Limited or No Connectivity. Checked the usual suspects: IP/TCP stack, winsock and winsock 2 errors - repaired these.
    I've now reinstaled XP after formatting the HD - everything is A1, super fast except I get the same problem with Limited or No Connectivity. I use a BT Home Hub, it works because im using the Laptop on a wireless connection, ive also connected the laptop up via ethernet cable (same one that PC is connected to) and its ok - Still no internet, can anyone point me in the right direction as to where I am going wrong, i'm pulling my hair out now
    Olly
    Olly,
  2. 2009/01/30
    Most probably seems like a driver problem with network card.
    Did you install the network card driver from cd or did Win XP picked it automatically?
    Did you install the chipset drivers for the motherboard after reformatting and installing XP?
  5. 2009/01/30
    Olly
    @rsinfo - onboard network card was picked up automatically, as was the one I purchased as I thought the onboard was no good - ive also deleted the network card that I installed, rebooted and installed the drivers off the CD.
    @PeteC - When I installed the motherboard, I went thru the setup book as I was supposed to and installed everything ( I think ) that it suggested:
    Chipset Driver
    Lan Driver
    cant remember the next one
    The PC works A1 - its faster than it has ever been, I just cant access the net
    Cheers
    Olly,
    FastTracker
    FastTracker Banned
    Try powering off the network modem for 30 seconds then power up to refresh IP.
  8. 2009/01/30
    Olly
    Ive done all this FastTracker - I still get aquiring network address and then Limited or No Connectivity.
    @PeteC - cheers, i'll have a look see Pete and get back to you
    Cheers folks
    Olly,
    #7
  9. 2009/01/30
    At a command prompt (Start > Run type cmd press OK) can you enter this command:
    ipconfig /all > ipconfig.txt
    This will create a new file called ipconfig.txt. Post the contents of the file to this thread.
  10. 2009/01/30
    Olly
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Administrator>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : reborn
    Node Type . . . . . . . . . . . . : Broadcast
    Ethernet adapter Local Area Connection 2:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek RTL8139/810X Family Fast Eth
    ernet NIC
    Physical Address. . . . . . . . . : 00-0A-E6-64-78-B7
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 0.0.0.0
    Subnet Mask . . . . . . . . . . . : 0.0.0.0
    IP Address. . . . . . . . . . . . : fe80::20a:e6ff:fe64:78b7%4
    Default Gateway . . . . . . . . . :
    DHCP Server . . . . . . . . . . . : 255.255.255.255
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%2
    fec0:0:0:ffff::2%2
    fec0:0:0:ffff::3%2
    Ethernet adapter Local Area Connection 3:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : RTL8139D PCI Fast Ethernet Adapter
    Physical Address. . . . . . . . . : 00-18-06-01-36-50
    Tunnel adapter Teredo Tunneling Pseudo-Interface:
    Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    Physical Address. . . . . . . . . : FF-FF-FF-FF-FF-FF-FF-FF
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : fe80::5445:5245:444f%6
    NetBIOS over Tcpip. . . . . . . . : Disabled
    Arie - this is what I done the other day, ive not changed anything since then. The PC is currently switched off and I have no access to it at the moment,for about an hour or so - I'll redo it when I can get to it and see id anythjing has changed
    Cheers
    Olly,
    #9
  11. 2009/01/30
    Olly
    Its completely different now -
    Node Type . . . . . . . . . . . . : Unknown
    Description . . . . . . . . . . . : Realtek RTL8139/810X Family Fast Ethernet NIC
    Autoconfiguration IP Address. . . : 169.254.217.27
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    IP Address. . . . . . . . . . . . : fe80::5445:5245:444f%5
    Tunnel adapter Automatic Tunneling Pseudo-Interface:
    Description . . . . . . . . . . . : Automatic Tunneling Pseudo-Interface
    Physical Address. . . . . . . . . : A9-FE-D9-1B
    IP Address. . . . . . . . . . . . : fe80::5efe:169.254.217.27%2
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
  12. 2009/01/30
    Yea, looks broken:
    Try running this command:
    netsh int ip reset c:\resetlog.txt
  13. 2009/01/30
    Olly
    deleted SYSTEM\CurrentControlSet\Services\Netbt\Parameters\EnableLmhosts
    reset SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2605ABC9-E19C-4601-87FE-288AC64E9929}\AddressType
    old REG_DWORD = 1
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2605ABC9-E19C-4601-87FE-288AC64E9929}\IpAutoconfigurationAddress
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2605ABC9-E19C-4601-87FE-288AC64E9929}\IpAutoconfigurationMask
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{2605ABC9-E19C-4601-87FE-288AC64E9929}\IpAutoconfigurationSeed
    reset SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{87316598-B089-452E-8B75-67D646811225}\AddressType
    old REG_DWORD = 1
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{87316598-B089-452E-8B75-67D646811225}\IpAutoconfigurationAddress
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{87316598-B089-452E-8B75-67D646811225}\IpAutoconfigurationMask
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{87316598-B089-452E-8B75-67D646811225}\IpAutoconfigurationSeed
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\DontAddDefaultGatewayDefault
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\EnableIcmpRedirect
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\EnableSecurityFilters
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\SearchList
    deleted SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\UseDomainNameDevolution
    reset Linkage\UpperBind for ROOT\MS_NDISWANBH\0000. bad value was:
    REG_MULTI_SZ =
    PSched
    reset Linkage\UpperBind for PCI\VEN_1904&DEV_8139&SUBSYS_00000000&REV_01\3&61AAA01&0&50. bad value was:
    REG_MULTI_SZ =
    PSched
    reset Linkage\UpperBind for PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&61AAA01&0&68. bad value was:
    REG_MULTI_SZ =
    PSched
    reset Linkage\UpperBind for ROOT\MS_NDISWANIP\0000. bad value was:
    REG_MULTI_SZ =
    PSched
    <completed>
    It connected, but would not let me see any webpages, saidpage cannot be displayed. I disabled and enabledconnection, guess what - Limited or no connectivity again
  14. 2009/01/30
    Olly
    Just to update you again - ive done the same procedure, and get the connected message, however when i go into the net connection, I see the little monitor icon, and a padlock !!
    Packets sent was 2, recieved was 0 - then it went to sent 0
    Says I am connected, but im not
  15. 2009/01/30
    Olly
    I assume Arie that I can save these to my laptop then copy them over to the desktop PC ?
  17. 2009/01/30
    Yes, you can.
  18. 2009/01/30
    Olly
    OK Arie - logs posted in Malware section as requested, i'll wait for one of the excellent techies to look at it
    Thanks again
  19. 2009/01/31
    noahdfear
    noahdfear Inactive
    Looks as though the machine is trying to default to using the IPv6 protocol and IPv6 Teredo. Your hub might not support Teredo. Lets see what happens if we disable it.
    Open a command window and type each of the following lines, hitting Enter after each.
    netsh int ipv6 reset
    netsh int ipv6 6to4 set state disabled disabled
    netsh int ipv6 set teredo disable
    netsh int ipv6 isatap set state disabled
    Now restart the computer and see if it connects. Do another ipconfig /all >ipconfig.txt and post it as well.
    Another thing I noticed in the event log section of the logs posted was the following message. Please note the bolded part.
    The server could not bind to the transport \Device\NwlnkNb because another computer on the network has the same name. The server could not start.
    Do you have two computers with the same name?
  20. 2009/01/31
    Olly
    Noahdfear - I also noticed that yesterday regarding another computer:
    The desktop is connected to the net thru a BT homehub and ethernet cable, I am currently typing this on the laptop that is running wirelessly through the same hub - i'll go and do what you have requested first and come back toyou in 5
    Cheers,
    Olly
  21. 2009/01/31
    Olly
    Noahdfear - still limited or no connectivity - times out trying to aqquire an IP address
