Solved javascript exploit and rootkit
Discussion in 'Malware and Virus Removal Archive' started by Oh Great, 2011/09/05.
  1. 2011/09/11
    Oh Great
    Oh Great Inactive Thread Starter
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Compaq_Owner
    ->Temp folder emptied: 2257231 bytes
    ->Temporary Internet Files folder emptied: 46694470 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 71454643 bytes
    ->Flash cache emptied: 1400 bytes
    User: Default User
    User: LocalService
    ->Temp folder emptied: 1062312 bytes
    User: NetworkService
    ->Temp folder emptied: 994744 bytes
    Windows Temp folder emptied: 1083460 bytes
    RecycleBin emptied: 103030417 bytes
    Total Files Cleaned = 216.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Compaq_Owner
    User: Default User
    User: LocalService
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.27.0 log created on 09122011_070253
    C:\Documents and Settings\Compaq_Owner\Local Settings\Temp\~DF139F.tmp moved successfully.
    C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\RP1LYESB\ads[3].htm moved successfully.
    C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\L9MEJ84O\00b42e3a-b809-49b2-b433-cc45b2bc89d33rd_party_BBS[2].htm moved successfully.
    File\Folder C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\L9MEJ84O\like[1].htm not found!
    File\Folder C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\L9MEJ84O\p-01-0VIaSjnOLg[1].gif not found!
    File\Folder C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\AAOUGBDG\100208-active-javascript-exploit-rootkit-3[1].html not found!
    File\Folder C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\Content.IE5\AAOUGBDG\p-01-0VIaSjnOLg[1].gif not found!
    C:\Documents and Settings\Compaq_Owner\Local Settings\Temporary Internet Files\AntiPhishing\2CEDBFBC-DBA8-43AA-B1FD-CC8E6316E3E2.dat moved successfully.
    File\Folder C:\WINDOWS\temp\ZLT00a03.TMP not found!
  2. 2011/09/11
    Whenever ready....
    Oh Great
    Sorry broni, in a rush this morning
    Computer seems to be running well, not sure about windows update. There are two updates that always fail, been there for a while.
    Some apps now won't run because Java not there so will need to sort that out asap.
    Was going to start a new thread re Java as it seemed the right thing to do...not really malware problem. Just waiting for your confirmation. Should it be in the Windows XP area? seems the right place to me, might resolve the update problem at the same time
    Thanks for all your help
  5. 2011/09/11
    You're very welcome [​IMG]
    Yes.
    Good luck!
