Resolved Issues with pc that are not due to having malware or a virus
Discussion in 'Windows 7' started by Forsaken Knight, 2011/11/17.
  1. 2011/11/18
    Yes. Uninstall them with Revo then reboot, then install them again.
  2. 2011/11/18
    Hi Forsaken Knight. I noticed that in your screenshots you have 92 processes running in Task Manager and all those background programs are using almost half of your system RAM. Having that many processes running definitely can have a negative impact on your performance of your system.
    Now I know you are running Malwarebytes on your system but are you running any other security software? You stated in your first post that you attempted to download Zone Alarm. Do you have it installed?
    I looked at some of the screenshots and I noticed that you have a few toolbars installed in IE9. Its possible that some IE add-ons are causing your downloads to become corrupted. I would start by running IE9 with no add-ons and see if you can download anything. To run IE9 without add-ons click Start< All Programs< Accessories< System Tools< Internet Explorer (No-Addons).
    Instead of posting tons of screenshots of your processes in Task Manager I would like for you to use Process Explorer to view the running processes on your system which will then make reading what is running on your computer much easier for me.
    Download and run Process Explorer. Extract the contents of the folder and then right click the procexp.exe program and click Run As Administrator. After it opens see if you can pinpoint any processes that you don't need running and find out which ones are taking up any of the CPU usage.
    After you have monitored the processes in Process Explorer click File< Save As and save the ProcessXP text file to your desktop.
    Open the text file and copy and paste the results here in your next reply with the number of processes the computer is running.
    @MrBill,
    I believe walmart is the username that Forsaken Knight is using on the computer.
    Edit: Forsaken Knight, go ahead and reinstall Flash Player and see if the issue remains regarding the stuttering video. If reinstalling Flash Player doesn't help then go ahead and follow the instructions that I posted above.
    Forsaken Knight
    Forsaken Knight Well-Known Member Thread Starter
    http://imageshack.us/photo/my-images/196/errorwheninstallingadob.png/
    Look at the above screen shots. I did as you stated, uninstalled, restarted/rebooted, then when to the official site, and got an error message. I am not sure why this message appears, but it seems that when I try to download something new, I more than not, get the message that something is currupted. What the hell that may be, I have no idea. I think it might not be curruption, but an interruption within the downloading process. Which ever the case may be, this is a rather annoying issue I am dealing with.
    Yes, I have zone alarm on my laptop pc. It is outdated, so I wanted to download an updated version of the free program. However, as you can see in one of my previous image posts, the system see's some sort of curruption during the download process. What that may be has stumpped me to the point that I do not know.
  5. 2011/11/18
    Ok. Go ahead and start IE9 with no add-ons. To run IE9 without add-ons click Start< All Programs< Accessories< System Tools< Internet Explorer (No-Addons).
    After IE9 has started, download Adobe Flash Player from here. See if it installs now.
  6. 2011/11/18
    wildfire
    wildfire Getting Old
    Try saving the file and running once downloaded, (this is looking like an ISP issue rather than a problem at your end)
    EDIT: Sorry Evan, didn't want to step on your toes.
  7. 2011/11/18
    No problem wildfire.
  8. 2011/11/18
    Forsaken Knight
    did as stated. restarted pc, ran ie no add ons, went to adobe flash web site, same issue as stated in my last screen shot. Came here, followed directions, and installed flash player. Went to youtube to test it out, nothing yet. went back to filehippo, and tried redownloading same thing, got message after ie download that "...was reported as unsafe." Then I tried to download the 64 bit ex, and got the same error.
  9. 2011/11/18
    wildfire
    And saving before running?
  10. 2011/11/18
    Forsaken Knight
    did that with adobe flash player from their offical download site, got as far as 25 percent before the currupted error showed up.
  11. 2011/11/18
    Forsaken Knight
    yeah, saved right to my desktop, saved as, was the option I chose, instead of save and run option.
  12. 2011/11/18
    wildfire
    During a save??? Are You Serious.
  13. 2011/11/18
    Forsaken Knight
    Process PID CPU Private Bytes Working Set Description Company Name
    System Idle Process 0 40.86 0 K 24 K
    System 4 4.80 176 K 824 K
    Interrupts n/a 2.45 0 K 0 K Hardware Interrupts and DPCs
    smss.exe 340 444 K 980 K
    csrss.exe 496 0.02 2,108 K 4,384 K
    conhost.exe 1472 1,992 K 4,616 K
    wininit.exe 540 2,716 K 6,464 K
    services.exe 608 0.31 6,984 K 10,112 K
    svchost.exe 772 6.81 4,772 K 9,724 K
    igfxsrvc.exe 2892 3,624 K 8,492 K igfxsrvc Module Intel Corporation
    igfxext.exe 3300 3,208 K 7,804 K igfxext Module Intel Corporation
    unsecapp.exe 3328 3,296 K 8,056 K Sink to receive asynchronous callbacks for WMI client application Microsoft Corporation
    WmiPrvSE.exe 3404 3,744 K 7,968 K
    svchost.exe 864 0.03 5,284 K 9,312 K
    svchost.exe 940 20,688 K 22,016 K
    svchost.exe 992 1.27 96,720 K 103,096 K
    dwm.exe 1336 3.19 47,192 K 28,144 K Desktop Window Manager Microsoft Corporation
    wlanext.exe 1460 2,720 K 6,380 K
    svchost.exe 112 0.05 24,016 K 36,684 K
    svchost.exe 492 0.03 10,300 K 15,576 K
    svchost.exe 1116 0.01 16,024 K 16,708 K
    vsmon.exe 1184 0.75 26,444 K 26,764 K
    AvastSvc.exe 1632 0.02 26,868 K 3,068 K
    ISWSVC.exe 1664 15.98 6,844 K 10,216 K
    spoolsv.exe 1264 7,756 K 13,756 K
    svchost.exe 2060 11,720 K 12,868 K
    taskhost.exe 2072 0.05 4,356 K 9,000 K Host Process for Windows Tasks Microsoft Corporation
    armsvc.exe 2240 1,924 K 5,256 K
    AppleMobileDeviceService.exe 2340 0.01 2,628 K 7,416 K
    mDNSResponder.exe 2388 2,588 K 6,868 K
    ePowerSvc.exe 2444 3,680 K 7,908 K
    ePowerEvent.exe 4408 1.14 2,804 K 6,360 K
    GregHSRW.exe 2512 0.05 2,320 K 6,204 K
    SchedulerSvc.exe 2628 0.02 3,524 K 7,656 K
    psia.exe 2928 0.77 14,656 K 21,920 K
    UpdaterService.exe 3136 1,936 K 5,232 K
    WLIDSVC.EXE 3336 0.01 8,500 K 15,588 K
    WLIDSVCM.EXE 3620 2,508 K 5,244 K
    IAANTmon.exe 3444 2,828 K 7,200 K
    SearchIndexer.exe 3904 0.02 38,932 K 22,920 K
    svchost.exe 3972 3,076 K 6,860 K
    sua.exe 3120 2,100 K 5,388 K
    svchost.exe 1388 < 0.01 7,924 K 24,408 K
    wmpnetwk.exe 4184 < 0.01 12,624 K 11,036 K
    svchost.exe 4652 6,504 K 9,872 K
    iPodService.exe 4124 0.03 3,896 K 9,128 K
    svchost.exe 2580 0.01 80,104 K 34,652 K Host Process for Windows Services Microsoft Corporation
    svchost.exe 2068 2,516 K 6,288 K
    taskhost.exe 1816 7,636 K 15,800 K
    lsass.exe 624 10.64 5,724 K 12,092 K
    lsm.exe 640 0.01 3,732 K 6,524 K
    csrss.exe 560 1.23 2,596 K 10,980 K
    winlogon.exe 716 3,160 K 6,696 K
    explorer.exe 1360 0.21 35,304 K 60,892 K Windows Explorer Microsoft Corporation
    IAAnotif.exe 1856 2,428 K 7,008 K Event Monitor User Notification Tool Intel Corporation
    RAVCpl64.exe 1884 9,220 K 10,512 K HD Audio Control Panel Realtek Semiconductor
    ePowerTray.exe 2004 0.60 4,816 K 10,272 K ePowerTray Acer Incorporated
    SynTPEnh.exe 2020 0.01 5,240 K 13,720 K Synaptics TouchPad Enhancements Synaptics Incorporated
    SynTPHelper.exe 4860 2,480 K 5,416 K
    hkcmd.exe 2772 3,640 K 8,308 K hkcmd Module Intel Corporation
    igfxpers.exe 2804 3,392 K 8,516 K persistence Module Intel Corporation
    ProfilerU.exe 2828 0.07 3,984 K 8,384 K Saitek SST Profile Launcher Saitek
    SaiMfd.exe 2900 3,028 K 6,908 K Saitek MFD File System Driver Saitek
    ipoint.exe 2940 0.47 8,616 K 17,532 K IPoint.exe Microsoft Corporation
    dpupdchk.exe 3492 2,800 K 6,072 K dpupdchk.exe Microsoft Corporation
    UpdateChecker.exe 388 36,736 K 30,508 K FileHippo.com Update Checker FileHippo.com
    psi_tray.exe 2404 0.02 1,940 K 5,888 K Secunia PSI Tray Secunia
    AvastUI.exe 2540 0.07 12,356 K 5,956 K avast! Antivirus AVAST Software
    iexplore.exe 1984 0.05 20,580 K 47,192 K Internet Explorer Microsoft Corporation
    iexplore.exe 1788 0.01 38,480 K 71,284 K Internet Explorer Microsoft Corporation
    iexplore.exe 4524 0.64 66,928 K 112,260 K Internet Explorer Microsoft Corporation
    procexp.exe 2524 2,764 K 8,248 K Sysinternals Process Explorer Sysinternals - www.sysinternals.com
    procexp64.exe 3272 5.50 20,484 K 38,572 K Sysinternals Process Explorer Sysinternals - www.sysinternals.com
    soffice.exe 2636 1,852 K 4,888 K OpenOffice.org 3.3 OpenOffice.org
    soffice.bin 2968 0.01 16,088 K 29,668 K OpenOffice.org 3.3 OpenOffice.org
    LManager.exe 4868 0.13 10,972 K 10,240 K
    zlclient.exe 4996 1.57 19,232 K 6,376 K ZoneAlarm Client Check Point Software Technologies LTD
    ForceField.exe 4820 0.08 24,708 K 7,020 K ZoneAlarm ForceField Check Point Software Technologies
    iTunesHelper.exe 420 < 0.01 5,848 K 13,232 K iTunesHelper Apple Inc.
  14. 2011/11/18
    Forsaken Knight
    thats from that program you told me to download. I followed your instructions and that is the file.
  15. 2011/11/18
    Forsaken Knight
    yeah...I am. Look, I don't want to waste your time or mine. I just want to find out where this little bugger is and fix the problem once and for all on my laptop pc.
  16. 2011/11/18
    Forsaken Knight
    Forsaken Knight
    I saved as, then ran the program adobe flash player. I know, annoying thing on my end too.
  18. 2011/11/18
    wildfire
    Ok, I have no need to waste your time either but how can you run the program if you had a corrupted message 25% during download?
  19. 2011/11/18
    I'm not really seeing anything in the list of processes or add-ons that could be causing your Internet downloads to become corrupted.
    The only thing that you could try would be to temporarily shut down your Zone Alarm Firewall and Avast Antivirus then see if you can download anything.
    Do you have any other browsers installed that you can try downloading files from?
  20. 2011/11/18
    Forsaken Knight
    ROFL, you, me, like eye to eye.
    I thought of that same thing. I did not come back here to see you write that message. I thought of this on my own. I just shut down my zone alarm, and tried to install adobe flash player, it succeeded. I then tried to play a video on youtube. I tried one that I like but I knew was always having problems. it ran smoothly. I then installed windows important updates, all 3 that were giving me issues. All went smoothly. I did not disable avast antivirus during this whole thing.
    Now, when I first saw that adobe flash installed successfully, I banged my head on the desk. I want to laugh, but I was more sad about this.
    Now that I know the issue is derived from my fire wall, what should I do?
    Should I get a different free fire wall?
    Should I get an updated version of zone alarm fire wall?
  21. 2011/11/18
    Forsaken Knight
    I was also able to update malwarebytes too once I shut down my zone alarm fire wall.
