is my battery dead?
Discussion in 'PC Hardware' started by missy77, 2010/07/28.
  1. 2010/07/28
    missy77
    missy77 Inactive Thread Starter
    This is just started. Unplug a/c and computer shuts off. says its fully charged. no light on battery. I never removed it before, always kept it in and when I unplugged, it worked fine.. till now. I assume it is dead?? agree?
    I have Bestbuy 3 protection that ended just days ago :(
    what is the best way to get a replacement now? ebay? any suggested sites?
    I have a Gateway laptop, model MT6840 bought july 07.
    Thanks!!
  2. 2010/07/28
    GRAHAM WESTON
    GRAHAM WESTON Well-Known Member
    Battery problem
    Missy77,
    Batteries do not like being kept fully charged all the time. They can get a memory, or lose capacity. If it is not drawing current on charge because of this, the computer may think it is fully charged. To get maximum life from a battery it needs to be charged and discharged on a regular basis. Every week or so, disconnect your ac adaptor and run the battery down to nearly flat, then put it back on the charger. This will give u max life from the battery. I don't know where u are located, so I cannot advise where to get a new battery from. Just don't buy a second hand one from Ebay. There should be heaps of online stores that would have new one's in stock.
    Run powercfg /energy from a (admin) command prompt.
    When finished, copy C:\Windows\System32\energy-report.html to the desktop & open it with IE.
    Now look at the Battery information. It will show you Design Capacity & Last Full Charge.
    I did this test a few days before my battery failed, and the last full charge was around 25-30% less than its design capacity.
    missy77
    Thanks! Can you tell me where my run command is on Vista...
  6. 2010/07/29
  7. 2010/07/29
    You can't. It is a Windows 7 command, but since you never entered your System Details, I had no idea which OS you had.
