Is Java really necessary
Discussion in 'Other PC Software' started by Ann, 2007/07/27.
  1. 2007/07/27
    Ann
    Ann Well-Known Member Thread Starter
    Hi,
    Can anyone tell me what is the purpose of having Java. I uninstalled mine at the suggestion of a friend. I can browse the Internet and do not notice any change. I would just like to be certain that it is not needed for normal user. On the other hand, what benefits are there in having it installed.
    Any input will be appreciated.
    Ann :confused:
    Ann,
  2. 2007/07/27
    No, java is not necessary for average day to day computer usage. It IS necessary for many online games, such as those at Yahoo, and it IS necessary to be able to use programs coded in the java language (mostly specialty applications or commercial applications). I've not used java for anything in the last several years. Java was at one time considered quite necvessary for everyday Web browsing because many sites used embedded java applets for advertisements or interactive content, but Flash has take over in that realm today.
    Ann
    Hi TonyT,
    Thank you so much for your reply. I do have another question. If I wanted to create a web page would I, then, need Java? TIA.
    Ann,
    Johanna
    Johanna Inactive Alumni
    It's not necessary to have Java, but as TonyT mentioned, some applications call for it. You could install the latest version, and set your browser or security software to prompt you if a java application is launched.
    You can test a machine's Java version here.
    Johanna
    Java required Crossword Puzzles
  6. 2007/07/28
    James
    James Inactive
    Java Script?
    Continuing along the same lines.... what is the purpose of java script? How does it relate to Java? Is "it" necessary for everyday usage? I've heard that java script can carry potential security problems and have wondered about the necessity of having it "turned on" in my browser. TIA
  7. 2007/07/28
    mailman Lifetime Subscription
    mailman Geek Member
    Hi, James. :)
    Both Java and Javascript have had security vulnerabilities addressed in the past. You could try browsing with both of them turned off and see how they affect your browsing experience.
    I leave Javascript enabled on my computer (for convenience) because at least some of my favorite sites make use of Javascript. I turn Java on only when I plan to use a site that requires Java (such as Secunia's Software Inspector). After using a site that requires Java, I immediately turn Java off and exit out of my browser.
    If you want to study further, then you might want to view links provided by Googling differences between java and javascript.
    EDIT: If you find Java does not work at Johanna's link to a Java version tester site or Secunia Software Inspector after enabling Java in your browser, you might need to configure your firewall to allow Java applets to be executed from those sites.
  8. 2007/07/29
    Absolutely NOT! Java applets can be used in Web pages, but are not necessary. Realize that java is NOT javascript. Javascript is not necessary for Web pages either.
  9. 2007/08/03
    Ann
    Thanks TonyT - Sorry I took so long to get back here, but I had a Trojan scare
    that kept me pretty busy.
    Ann,
    #8
