Invalid Page Fault
Discussion in 'Legacy Windows' started by mtwilco, 2003/01/01.
  1. 2003/01/05
    Is that keyboard by Logitech?
    Search your computer for "touchmgr.exe ", and "touchmgr.vxd ". They may be gone due to uninstallation. If you find "touchmgr.vxd" try to rename it to "touchmgr.old ".
    Shut down your computer, unplug a keyboard, wait a few minutes, plug it in. Restart.
    Any referrences to above files in "msconfig>startup tab ", registry?
    Check also this page:
    http://aumha.org/a/kernel32.htm
    Broni
  2. 2003/01/05
    mtwilco
    mtwilco Inactive Thread Starter
    broni,I found this in the registy:REGEDIT4
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Doc Find Spec MRU]
    "a "=" "
    "MRUList "= "dcba "
    "b "= "Touchmanager.exe "
    "c "= "touchmgr.exe "
    "d "= "touchmgr.vxd "
    Do I delete the entries? Keyboard is not a Logitech, but my mouse is. Have also found this a I have been poking around. Plug and Play Software Device Enumerator
    SYSTEM
    This Device Has a Problem: Code=2 (0x2)
    Device failure: Try changing the driver for this device. If that doesn't work,
    see your hardware documentation.
    Registry Key: HKEY_LOCAL_MACHINE\enum\ROOT\SWENUM\0000
    Alloc resources: None
    Forced resources: None
    Boot resources: None
    Filtered resources: None
    Basic resources: None
    Driver: SYSTEM\0001
    Driver Date: 4-23-1999
    Driver: streamci.dll
    File Size: 20480 (0x5000)
    File Date: 4/23/1999 10:22 PM
    Company Name: Microsoft Corporation
    File Version: 5.00.2020.1
    Driver: ks.sys
    File Size: Driver Not Installed
    File Date: Driver Not Installed
    Driver: swenum.sys
    Would this have anything to do with the problem ? How do I aquire and install these drivers?
    "Doc Find Spec MRU "...this registry listing doesn't matter...those entries are just your recent searches.
    How about unplugging your keyboard?
    Nothing in msconfig, or search in Windows Explorer?
    How about that link, I gave you? There is a lot of checking there.
