Solved Internet Explorer 7 Will Not Launch after Trojan was removed
Discussion in 'Malware and Virus Removal Archive' started by BigMarklin, 2010/09/26.
  1. 2010/09/28
    Update your Java version here: http://www.java.com/en/download/installed.jsp
    Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    Run OTL
      :OTL
      O2 - BHO: (no name) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - No CLSID value found.
      O2 - BHO: (no name) - AutorunsDisabled - No CLSID value found.
      O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
      O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
      O9 - Extra 'Tools' menuitem : IBM Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - Reg Error: Key error. File not found
      O16 - DPF: {0DB074F0-617E-4EE9-912C-2965CF2AA5A4} http://download.microsoft.com/downlo...ualEarth3D.cab (Reg Error: Key error.)
      O16 - DPF: {428A9DEF-F057-402B-9F2D-A5887F4544ED} http://download.microsoft.com/downlo...ualEarth3D.cab (Reg Error: Key error.)
      [2 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
      [2 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
      [2010/09/26 09:35:02 | 000,000,792 | ---- | C] () -- C:\Documents and Settings\jim\Desktop\AML Free Registry Cleaner.lnk
      :Services
      :Reg
      [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
       "DisableMonitoring" =-
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Last scans....
    1. Download Security Check from HERE, and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    2. Download Temp File Cleaner (TFC)
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    3. Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • IMPORTANT! UN-check Remove found threats
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  2. 2010/09/28
    BigMarklin
    BigMarklin Inactive Thread Starter
    Hi Broni,
    Here is the OTL scan. I'm working on the others. I had to get through a BSOD.
    All processes killed
    ========== OTL ==========
    Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ not found.
    Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\AutorunsDisabled\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Internet Explorer\Restrictions\ deleted successfully.
    Registry key HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{08B0E5C0-4FCB-11CF-AAA5-00401C608501}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{08B0E5C0-4FCB-11CF-AAA5-00401C608501}\ deleted successfully.
    Starting removal of ActiveX control {0DB074F0-617E-4EE9-912C-2965CF2AA5A4}
    C:\WINDOWS\Downloaded Program Files\VE3DInstall.inf moved successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{0DB074F0-617E-4EE9-912C-2965CF2AA5A4}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{0DB074F0-617E-4EE9-912C-2965CF2AA5A4}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{0DB074F0-617E-4EE9-912C-2965CF2AA5A4}\ not found.
    Starting removal of ActiveX control {428A9DEF-F057-402B-9F2D-A5887F4544ED}
    C:\WINDOWS\Downloaded Program Files\VE3DInstall.inf not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{428A9DEF-F057-402B-9F2D-A5887F4544ED}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{428A9DEF-F057-402B-9F2D-A5887F4544ED}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{428A9DEF-F057-402B-9F2D-A5887F4544ED}\ not found.
    C:\WINDOWS\System32\74F.tmp deleted successfully.
    C:\WINDOWS\System32\CONFIG.TMP deleted successfully.
    C:\WINDOWS\003150_.tmp deleted successfully.
    C:\WINDOWS\msdownld.tmp folder deleted successfully.
    C:\Documents and Settings\jim\Desktop\AML Free Registry Cleaner.lnk moved successfully.
    Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus\\DisableMonitoring deleted successfully.
    ========== FILES ==========
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Dad
    ->Temporary Internet Files folder emptied: 67 bytes
    User: Default User
    ->Temporary Internet Files folder emptied: 53357 bytes
    User: jim
    ->Temp folder emptied: 14284533 bytes
    ->Temporary Internet Files folder emptied: 261610 bytes
    ->Java cache emptied: 2027 bytes
    ->FireFox cache emptied: 49384377 bytes
    ->Flash cache emptied: 3574 bytes
    User: LocalService
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: Mackie
    ->Temporary Internet Files folder emptied: 78991 bytes
    ->FireFox cache emptied: 3471103 bytes
    User: Nancy
    ->Temp folder emptied: 339 bytes
    ->Temporary Internet Files folder emptied: 2479639 bytes
    ->FireFox cache emptied: 137109771 bytes
    ->Flash cache emptied: 13625 bytes
    User: NetworkService
    Windows Temp folder emptied: 98787 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 198.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Dad
    User: Default User
    User: jim
    User: LocalService
    User: Mackie
    User: Nancy
    OTL by OldTimer - Version 3.2.14.1 log created on 09282010_225602
    C:\WINDOWS\temp\vtclrg41.tmp moved successfully.
    Thanks!
    Ok :)
  5. 2010/09/28
    BigMarklin
    Here is the Security Check log
    Thanks!
    Results of screen317's Security Check version 0.99.5
    Windows XP Service Pack 3
    Internet Explorer 7 Out of date!
    Antivirus/Firewall Check:
    Windows Firewall Disabled!
    Symantec AntiVirus
    Antivirus up to date!
    Anti-malware/Other Utilities Check:
    Out of date Spybot installed!
    Malwarebytes' Anti-Malware
    HijackThis 2.0.2
    CCleaner
    AML Free Registry Cleaner 4.21
    IBM 32-bit Runtime Environment for Java 2, v1.4.2
    Java(TM) 6 Update 21
    Mozilla Firefox (3.6.4) Firefox Out of Date!
    Process Check:
    objlist.exe by Laurent
    Symantec AntiVirus DefWatch.exe
    Symantec AntiVirus Rtvscan.exe
    DNS Vulnerability Check:
    GREAT! (Not vulnerable to DNS cache poisoning)
    ``````````End of Log````````````
  6. 2010/09/28
    Please, uninstall IBM 32-bit Runtime Environment for Java 2, v1.4.2 .
    Update Firefox to current 3.6.10 version.
  7. 2010/09/28
    BigMarklin
    Hi Broni,
    I uninstalled the IBM 32-bit Java you mentioned and updated Firefox. I still have to do the free online scan, but since that will take some time and it's approaching midnight, I'll do that tomorrow night.
    Thank you for all your work and perseverance.
  8. 2010/09/28
    You're very welcome :)
  9. 2010/09/29
    BigMarklin
    Hi Broni,
    I ran the ESET scan. I did get 1 BSOD and had to restart. The second time it went to completion (2 hrs +). It did not find anything. I did not see any way to save/print a log so I have nothing to post. If I just missed it, I can run the scan again tomorrow.
  10. 2010/09/29
    If Eset doesn't find anything, it won't produce any log.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
  11. 2010/09/29
    BigMarklin
    Broni,
    It looks like OTL messed up my Symantec antivirus. When I reboot I get a message that Symantec failed to load.
    Here is the OTL log.
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Dad
    User: Default User
    User: jim
    ->Temp folder emptied: 19810829 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 35285298 bytes
    ->Flash cache emptied: 456 bytes
    User: LocalService
    ->Temp folder emptied: 16384 bytes
    User: Mackie
    ->FireFox cache emptied: 0 bytes
    User: Nancy
    Windows Temp folder emptied: 115199 bytes
    RecycleBin emptied: 3608162 bytes
    Total Files Cleaned = 56.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Dad
    User: Default User
    User: jim
    User: LocalService
    User: Mackie
    User: Nancy
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.14.1 log created on 09292010_232900
    Jim
  12. 2010/09/29
    OTL couldn't do anything to your Norton.
    It merely did reset restore points.
    Restart and see how it goes.
  13. 2010/09/29
    BigMarklin
    Hi Broni,
    Well 2 reboots did the trick. Symantec is working again.
    Also, I have not had the error about my user profile not loading due to insufficient system resources for the last few reboots.
    However, IE still won't launch. It opens a blank window, and acts like it is attempting to load. Then the window closes.
    Thanks again. It's after midnight, so I'm pretty bleary. I'll pick this back up tomorrow night.
  14. 2010/09/29
    Try couple of things...
    1. Close IE.
    Go Start>All Programs>Accessories>System Tools, and click on Internet Explorer (no add-ons). Same thing?
    2. See, if IE will open in Safe Mode with Networking.
  15. 2010/09/30
    BigMarklin
    When I tried 1 above, an IE window partially loaded. It was missing some icons, etc. When I tried to surf somewhere it was non-responsive.
    When I tried 2 above, more of the IE window loaded, but again it was non-responsive.
  16. 2010/09/30
    In IE, go Tools>Internet options>Advanced tab, click on "Reset" button.
    Restart computer.
  17. 2010/09/30
    BigMarklin
    Hi Broni,
    I can't get into IE to follow your directions. Not enough loads to give me any menu items. Even in safe mode, no menus are visible. Perhaps I should try reinstalling IE7 ?:confused:
  18. 2010/09/30
    Try Start>Control Panel>Internet options
  19. 2010/09/30
    BigMarklin
    I tried that; same results
  20. 2010/09/30
    What do you mean by same results?
  21. 2010/09/30
    BigMarklin
    IE tried to start; a window opened, then closed
