Solved Infected with My Search Dial
Discussion in 'Malware and Virus Removal Archive' started by diego1, 2014/08/16.
  1. 2014/08/21
    diego1
    diego1 Well-Known Member Thread Starter
    Fixlog - Report
    Fix result of Farbar Recovery Tool (FRST written by Farbar) (x86) Version:19-08-2014
    Ran by JJSR at 2014-08-21 01:35:29 Run:1
    Running from C:\Documents and Settings\JJSR\Desktop
    Boot Mode: Normal
    Content of fixlist:
    Toolbar: HKLM - No Name - {10921475-03CE-4E04-90CE-E2E7EF20C814} - No File
    S3 catchme; \??\C:\DOCUME~1\JJSR\LOCALS~1\Temp\catchme.sys [X]
    S3 esgiguard; \??\C:\Program Files\Enigma Software Group\SpyHunter\esgiguard.sys [X]
    U4 RemoteRegistry;
    U5 ScsiPort; C:\WINDOWS\system32\drivers\scsiport.sys [96384 2008-04-14] (Microsoft Corporation)
    U3 TlntSvr;
    S3 UIUSys; system32\DRIVERS\UIUSYS.SYS [X]
    C:\Documents and Settings\Administrator\Local Settings\Temp\AutoFix.exe
    C:\Documents and Settings\JJSR\Local Settings\Temp\Quarantine.exe
    AlternateDataStreams: C:\WindowsDefender.msi:SummaryInformation
    AlternateDataStreams: C:\WindowsDefender.msi:{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}
    AlternateDataStreams: C:\Documents and Settings\JJSR\Desktop\K54-Videostudio 8.rar:{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}
    AlternateDataStreams: C:\Documents and Settings\JJSR\Desktop\tmo_servicebooks.zip:{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}
    HKU\.DEFAULT\...\Run: [Advanced SystemCare 6] => "C:\Program Files\IObit\Advanced SystemCare 6\ASCTray.exe" /AutoStart
    CHR Extension: (Advanced SystemCare Surfing Protection) - C:\Documents and Settings\JJSR\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\bbmegnmpleoagolcnjnejdacakedpcgd [2014-02-25]
    CHR Extension: (Advanced SystemCare Surfing Protection) - C:\Documents and Settings\JJSR\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nfengeggddojhakldhlpjdlddgkkjkdd [2014-01-11]
    HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\\{10921475-03CE-4E04-90CE-E2E7EF20C814} => value deleted successfully.
    "HKCR\CLSID\{10921475-03CE-4E04-90CE-E2E7EF20C814}" => Key not found.
    catchme => Service deleted successfully.
    esgiguard => Service deleted successfully.
    RemoteRegistry => Service deleted successfully.
    ScsiPort => Service deleted successfully.
    TlntSvr => Service deleted successfully.
    UIUSys => Service deleted successfully.
    C:\Documents and Settings\Administrator\Local Settings\Temp\AutoFix.exe => Moved successfully.
    C:\Documents and Settings\JJSR\Local Settings\Temp\Quarantine.exe => Moved successfully.
    C:\WindowsDefender.msi => ":SummaryInformation" ADS removed successfully.
    C:\WindowsDefender.msi => ":{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}" ADS removed successfully.
    C:\Documents and Settings\JJSR\Desktop\K54-Videostudio 8.rar => ":{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}" ADS removed successfully.
    C:\Documents and Settings\JJSR\Desktop\tmo_servicebooks.zip => ":{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}" ADS removed successfully.
    HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run\\Advanced SystemCare 6 => value deleted successfully.
    C:\Program Files\IObit => Moved successfully.
    C:\Documents and Settings\JJSR\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\bbmegnmpleoagolcnjnejdacakedpcgd => Moved successfully.
    C:\Documents and Settings\JJSR\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nfengeggddojhakldhlpjdlddgkkjkdd => Moved successfully.
    ==== End of Fixlog ====
  2. 2014/08/21
    Good :)
    How is computer doing?
    Last scans...
    [​IMG] Download Security Check from here or here and save it to your Desktop.
    • Double-click SecurityCheck.exe
    • Follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    NOTE 1. If one of your security applications (e.g., third-party firewall) requests permission to allow DIG.EXE access the Internet, allow it to do so.
    NOTE 2 SecurityCheck may produce some false warning(s), so leave the results reading to me.
    [​IMG] Please download Farbar Service Scanner (FSS) and run it on the computer with the issue.
    • Make sure the following options are checked:
      • Internet Services
      • Windows Firewall
      • System Restore
      • Security Center
      • Windows Update
      • Windows Defender
      • Other Services
    • Press "Scan ".
    • It will create a log (FSS.txt) in the same directory the tool is run.
    • Please copy and paste the log to your reply.
    [​IMG] Download Temp File Cleaner (TFC)
    Alternate download: http://www.itxassociates.com/OT-Tools/TFC.exe
    • Double click on TFC.exe to run the program.
    • Click on Start button to begin cleaning process.
    • TFC will close all running programs, and it may ask you to restart computer.
    [​IMG] Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Click on "Run ESET Online Scanner" button.
    • Tick the box next to YES, I accept the Terms of Use
    • Click Start
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, click on List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    • NOTE. If Eset won't find any threats, it won't produce any log.
    diego1
    Progress
    Hi Again,
    My computer and browser (Mozilla Firefox) are still slow on start up and today, I experienced pop up ads. Also, after running FRST, I ran search which again yielded with hundreds of Advanced Care System v6 & v7 files.
  5. 2014/08/21
    diego1
    Checkup txt
    Results of screen317's Security Check version 0.99.87
    Windows XP Service Pack 3 x86
    Internet Explorer 8
    ``````````````Antivirus/Firewall Check:``````````````
    Windows Firewall Enabled!
    AVG 2014
    `````````Anti-malware/Other Utilities Check:`````````
    CCleaner
    Java 7 Update 67
    Adobe Flash Player 14.0.0.179
    Adobe Reader XI
    Mozilla Firefox (31.0)
    Google Chrome 36.0.1985.125
    Google Chrome 36.0.1985.143
    ````````Process Check: objlist.exe by Laurent````````
    AVG avgwdsvc.exe
    AVG avgrsx.exe
    AVG avgnsx.exe
    AVG avgemc.exe
    `````````````````System Health check`````````````````
    Total Fragmentation on Drive C:: 11% Defragment your hard drive soon! (Do NOT defrag if SSD!)
    ````````````````````End of Log``````````````````````
  7. 2014/08/21
    diego1
    FSS Scan
    Farbar Service Scanner Version: 21-07-2014
    Ran by JJSR (administrator) on 21-08-2014 at 23:33:27
    Running from "C:\Documents and Settings\JJSR\Desktop "
    Microsoft Windows XP Home Edition Service Pack 3 (X86)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Google.com is accessible.
    Yahoo.com is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    System Restore:
    System Restore Disabled Policy:
    Security Center:
    Windows Update:
    Windows Autoupdate Disabled Policy:
    Other Services:
    File Check:
    C:\WINDOWS\system32\dhcpcsvc.dll => File is digitally signed
    C:\WINDOWS\system32\Drivers\afd.sys => File is digitally signed
    C:\WINDOWS\system32\Drivers\netbt.sys => File is digitally signed
    C:\WINDOWS\system32\Drivers\tcpip.sys => File is digitally signed
    C:\WINDOWS\system32\Drivers\ipsec.sys => File is digitally signed
    C:\WINDOWS\system32\dnsrslvr.dll => File is digitally signed
    C:\WINDOWS\system32\ipnathlp.dll => File is digitally signed
    C:\WINDOWS\system32\netman.dll => File is digitally signed
    C:\WINDOWS\system32\wbem\WMIsvc.dll => File is digitally signed
    C:\WINDOWS\system32\srsvc.dll => File is digitally signed
    C:\WINDOWS\system32\Drivers\sr.sys => File is digitally signed
    C:\WINDOWS\system32\wscsvc.dll => File is digitally signed
    C:\WINDOWS\system32\wuauserv.dll => File is digitally signed
    C:\WINDOWS\system32\qmgr.dll => File is digitally signed
    C:\WINDOWS\system32\es.dll => File is digitally signed
    C:\WINDOWS\system32\cryptsvc.dll => File is digitally signed
    C:\WINDOWS\system32\svchost.exe => File is digitally signed
    C:\WINDOWS\system32\rpcss.dll => File is digitally signed
    C:\WINDOWS\system32\services.exe => File is digitally signed
    Extra List:
    Avgtdix(10) Gpc(3) IPSec(5) NetBT(6) PSched(7) Tcpip(4)
    0x0A000000050000000100000002000000030000000400000008000000090000000A0000000600000007000000
    IpSec Tag value is correct.
    **** End of log ****
  8. 2014/08/22
    diego1
    ESETScan
    C:\AdwCleaner\Quarantine\C\Documents and Settings\JJSR\Application Data\Slick Savings\CouponsHelper.exe.vir a variant of Win32/Toolbar.Widgi.F potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Application Updater\ApplicationUpdater.exe.vir a variant of Win32/Toolbar.Widgi.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\SearchSettings.exe.vir a variant of Win32/Toolbar.Widgi.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\SearchSettings64.exe.vir a variant of Win64/Toolbar.Widgi.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\wth179.dll.vir a variant of Win32/Toolbar.Widgi.A potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Spigot\Search Settings\wthx179.dll.vir a variant of Win64/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Common Files\Spigot\SlickSavings\SlickSavingsSetup.exe.vir Win32/Toolbar.Widgi.F potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\IObit Apps Toolbar\FF\components\iobitappsToolbarFF.dll.vir a variant of Win32/Toolbar.Widgi.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\IObit Apps Toolbar\IE\8.9\iobitappsToolbarIE.dll.vir a variant of Win32/Toolbar.Widgi.G potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\IObit Apps Toolbar\IE\8.9\iobitappsToolbarIE64.dll.vir a variant of Win64/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\AdwCleaner\Quarantine\C\Program Files\Uninstaller\Uninstall.exe.vir MSIL/DomaIQ.A potentially unwanted application deleted - quarantined
    C:\Documents and Settings\All Users\Application Data\IObit\ASCDownloader\ASCSetup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\advanced-systemcare-setup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\asc-setup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\asc7-setup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\cbsidlm-cbsi188-Ashampoo_Burning_Studio_Free-ORG-10776287.exe a variant of Win32/CNETInstaller.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\defragsetup(1).exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\defragsetup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\Documents and Settings\JJSR\My Documents\Downloads\smart-defrag-setup.exe a variant of Win32/Toolbar.Widgi.B potentially unwanted application deleted - quarantined
    C:\System Volume Information\_restore{F601E956-7E51-4F51-A6E9-0241E6B09109}\RP29\A0007580.exe MSIL/DomaIQ.A potentially unwanted application deleted - quarantined
  9. 2014/08/22
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  10. 2014/08/23
    diego1
    Progress
    Hi Broni,
    Yes it appears to be free of My Search Dial as it starts up faster and appears to be responding and operating smoother. I have downloaded the tools you recomended to run as maintenence and, I will watch out for what I download. Although, as for the Advanced Care System files, the fact that there are so many (in the hundreds) causes a thought that I can use that space later on. I trust they are harmless as you say but, can I delete these files manually one by one without any detrimental effects?
    Thank you so much for your invaluable assistance. You guys ae the best.
  11. 2014/08/23
    Yes, you can safely delete those leftovers.
    Good luck and stay safe :)
  12. 2014/08/23
    diego1
    Closing Thread
    Thanks Again.:)
  13. 2014/08/23
    diego1
    How to close Thread
    Hi Again Broni,
    How do I close thread and mark as solved?
  14. 2014/08/23
    I already marked it as solved.
