Inactive [InActive] XP Malware
Discussion in 'Malware and Virus Removal Archive' started by mcseadogs, 2008/09/18.
  1. 2008/10/07
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi
    OK good.
    Please do this.
    Delete C:\SDFix <<This folder
    • Please double-click OTMoveIt2.exe to run it.
    • Click on the CleanUp! button. When you do this a text file named cleanup.txt will be downloaded from the internet. If you get a warning from your firewall or other security programs regarding OTMoveIt attempting to contact the internet you should allow it to do so. After the list has been download you'll be asked if you want to Begin cleanup process? Select Yes.
    • This step removes the files, folders, and shortcuts created by the tools I had you download and run.
    Empty your recycle bin
    That should clean you up.
    Please look at this link for some preventive recommendations, It could keep you from ending up back here to the Malware and Virus Removal Forums.
    http://www.windowsbbs.com/showthread.php?t=67958
    Let me know how things are running.
    Geri
