Inactive [InActive] Possible malware preventing downloads
Discussion in 'Malware and Virus Removal Archive' started by DoubleJ, 2008/12/26.
  1. 2009/01/14
    noahdfear
    noahdfear Inactive
    If you're satisfied things are working normally again, lets cleanup now.
    Open MBAM and remove any items quarantined. Do the same with your resident antivirus.
    Click Start>Run and type ComboFix /u then hit Enter to uninstall ComboFix and remove the files it has quarantined. This action will also reset the System Restore points, removing any infected files there as well.
    Verify the C:\Qoobox and C:\ComboFix folders were removed, as well as the C:\ComboFix.txt file.
    Delete RSIT.exe and the C:\rsit folder.
    You can delete any other logs that were created/saved too.
    Empty the recycle bin when done.
    That should be it. Let me know if everything appears to be working normally.
