Inactive [InActive] Google Redirect Problem - Beginner
Discussion in 'Malware and Virus Removal Archive' started by gray916, 2008/11/16.
  1. 2008/11/17
    gray916
    gray916 Inactive Thread Starter
    on broad band, hardwired from phone socket into modem into computer
    I am running zone alarm and avg 8
    Any other ideas?
  2. 2008/11/18
    noahdfear
    noahdfear Inactive
    Once again, please disable any realtime protection applications. Highlight and copy the contents of the code box below and paste it into a blank notepad, then save it to your desktop as;
    Filename: CFScript.txt
    Save As Type: All Files (*.*)
    File::
    c:\windows\system32\drivers\Ndisprot.sys
    Driver::
    Ndisprot
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button. Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log.
    Please do not click on the ComboFix window while it is running a scan. This can cause it to stall.
    **NOTE - Allow ComboFix to update if prompted.
    gray916
    It seems the problem has been fixed. This is the order i (think) i did things:
    Uninstalled the google toolbar
    Deny any registry changes alerted by Spybot (i denied them incase it was like you say - spoof requests)
    Went to google.co.uk and did a search - everything fine, no redirects
    Re installed google toolbar, and accepted any registry changes from spybot
    Searched in google toolbar - everything fine, no redirects.
    Not sure why it worked, maybe it just needed a kick up the proverbial.
    Should i still run that last piece of code you suggested?
  5. 2008/11/19
    noahdfear
    noahdfear Inactive
    Yes, the recommended fix still needs to be done.
  6. 2008/11/19
    gray916
    Just tried my google searching again and the problem is back....
    Must have got lucky yesterday....
    I have uninstalled google toobar and will run the code you suggest
  7. 2008/11/19
    gray916
    Done what was asked and here it is
    ComboFix 08-11-18.A2 - Gray 2008-11-19 19:26:13.4 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.703 [GMT 0:00]
    Running from: c:\documents and settings\Gray\Desktop\ComboFix.exe
    Command switches used :: c:\documents and settings\Gray\Desktop\CFScript.txt
    * Created a new restore point
    FILE ::
    c:\windows\system32\drivers\ndisprot.sys
    D:\resycled
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
    -------\Legacy_NDISPROT
    -------\Service_Ndisprot
    ((((((((((((((((((((((((( Files Created from 2008-10-19 to 2008-11-19 )))))))))))))))))))))))))))))))
    2008-11-16 20:21 . 2008-11-16 20:22 <DIR> d-------- c:\program files\malware
    2008-11-16 20:21 . 2008-11-16 20:21 <DIR> d-------- c:\documents and settings\Gray\Application Data\Malwarebytes
    2008-11-16 20:21 . 2008-11-16 20:21 <DIR> d-------- c:\documents and settings\All Users\Application Data\Malwarebytes
    2008-11-16 20:21 . 2008-10-22 16:10 38,496 --a------ c:\windows\system32\drivers\mbamswissarmy.sys
    2008-11-16 20:21 . 2008-10-22 16:10 15,504 --a------ c:\windows\system32\drivers\mbam.sys
    2008-11-16 17:34 . 2008-11-16 17:34 250 --a------ c:\windows\gmer.ini
    2008-11-16 11:29 . 2008-11-16 17:31 <DIR> d-------- C:\rsit
    2008-11-16 11:29 . 2008-11-16 17:31 <DIR> d-------- c:\program files\trend micro
    2008-11-16 09:43 . 2008-11-16 09:43 <DIR> d-------- C:\!KillBox
    2008-11-15 21:40 . 2008-11-15 21:43 <DIR> d-------- c:\program files\WinAVIVideoConverter
    2008-11-15 21:37 . 2008-11-17 21:03 <DIR> d-------- c:\program files\Spybot - Search & Destroy
    2008-11-15 21:37 . 2008-11-16 09:35 <DIR> d-------- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
    2008-11-15 20:52 . 2008-11-15 21:00 <DIR> d-a------ c:\documents and settings\All Users\Application Data\TEMP
    2008-11-15 13:44 . 2008-11-15 13:44 <DIR> d-------- c:\documents and settings\Gray\Application Data\AVS4YOU
    2008-11-15 13:43 . 2008-11-15 13:43 <DIR> d-------- c:\documents and settings\All Users\Application Data\AVS4YOU
    2008-11-15 13:31 . 2008-11-15 20:59 <DIR> d-------- c:\program files\Common Files\AVSMedia
    2008-11-15 13:31 . 2008-11-15 20:59 <DIR> d-------- c:\program files\AVS4YOU
    2008-11-15 13:31 . 2007-02-27 18:36 1,700,352 --a------ c:\windows\system32\GdiPlus.dll
    2008-11-15 13:31 . 2007-02-27 18:36 974,848 --a------ c:\windows\system32\mfc70.dll
    2008-11-15 13:31 . 2007-02-27 18:36 24,576 --a------ c:\windows\system32\msxml3a.dll
    2008-11-13 09:08 . 2008-09-04 17:15 1,106,944 --------- c:\windows\system32\dllcache\msxml3.dll
    2008-11-13 09:08 . 2008-10-24 11:21 455,296 --------- c:\windows\system32\dllcache\mrxsmb.sys
    2008-11-05 20:57 . 2006-05-03 11:57 520,192 --------- c:\windows\system32\ati2sgag.exe
    2008-11-05 20:47 . 2008-11-05 20:58 <DIR> d-------- c:\program files\ATI Technologies
    2008-11-05 20:18 . 2008-11-16 16:05 139 --a------ c:\windows\WININIT.INI
    2008-11-05 18:55 . 2008-11-17 01:22 <DIR> d--h----- C:\$AVG8.VAULT$
    2008-11-01 11:09 . 2008-11-01 11:09 <DIR> d-------- c:\program files\Alex Buturuga
    2008-10-28 19:08 . 2008-10-28 19:08 <DIR> d-------- c:\windows\system32\scripting
    2008-10-28 19:07 . 2008-10-28 19:07 <DIR> d-------- c:\windows\system32\en
    2008-10-28 19:07 . 2008-10-28 19:07 <DIR> d-------- c:\windows\system32\bits
    2008-10-28 19:07 . 2008-10-28 19:07 <DIR> d-------- c:\windows\l2schemas
    2008-10-27 21:01 . 2008-11-15 22:46 69 --a------ c:\windows\NeroDigital.ini
    2008-10-27 20:55 . 2008-10-27 20:55 30,912 --a------ c:\documents and settings\Gray\Application Data\GDIPFONTCACHEV1.DAT
    2008-10-27 20:33 . 2003-02-28 18:26 139,536 --a------ c:\windows\system32\javaee.dll
    2008-10-27 20:33 . 2003-02-28 18:26 46,352 --a------ c:\windows\setdebug.exe
    2008-10-27 20:33 . 2003-02-28 16:54 7,315 --a------ c:\windows\system32\javasup.vxd
    2008-10-27 20:33 . 2003-02-28 16:35 6,550 --a------ c:\windows\jautoexp.dat
    2008-10-27 20:33 . 2003-02-28 16:38 113 --a------ c:\windows\system32\zonedon.reg
    2008-10-27 20:33 . 2003-02-28 16:38 113 --a------ c:\windows\system32\zonedoff.reg
    2008-10-27 18:30 . 2008-10-27 18:30 <DIR> d-------- c:\program files\MSXML 4.0
    2008-10-26 09:50 . 2008-10-26 09:50 <DIR> d-------- c:\documents and settings\Gray\Application Data\Sonic
    2008-10-26 09:49 . 2008-10-26 09:49 <DIR> d-------- c:\documents and settings\Gray\Application Data\Leadertech
    2008-10-26 09:47 . 2008-10-26 09:47 <DIR> d-------- c:\program files\Belkin
    2008-10-26 09:40 . 2008-11-05 21:04 <DIR> d-------- c:\documents and settings\Gray\Application Data\ATI
    2008-10-26 09:28 . 2008-10-26 09:28 <DIR> d-------- c:\program files\Common Files\Adobe AIR
    2008-10-26 09:27 . 2008-10-26 09:27 <DIR> d-------- c:\program files\Common Files\Adobe
    2008-10-25 21:16 . 2008-04-14 00:12 712,704 --------- c:\windows\system32\windowscodecs.dll
    2008-10-25 21:16 . 2008-04-14 00:12 346,112 --------- c:\windows\system32\windowscodecsext.dll
    2008-10-25 21:16 . 2008-04-14 00:12 276,992 --------- c:\windows\system32\wmphoto.dll
    2008-10-25 21:16 . 2008-04-14 00:12 69,120 --------- c:\windows\system32\wlanapi.dll
    2008-10-25 21:16 . 2008-04-14 00:12 53,248 --------- c:\windows\system32\tsgqec.dll
    2008-10-25 21:16 . 2008-04-14 00:12 50,688 --------- c:\windows\system32\tspkg.dll
    2008-10-25 21:16 . 2008-04-14 00:12 28,672 --------- c:\windows\system32\verclsid.exe
    2008-10-25 21:14 . 2008-04-14 00:11 650,752 --------- c:\windows\system32\dot3ui.dll
    2008-10-25 21:09 . 2008-10-25 21:10 <DIR> d-------- c:\documents and settings\Gray\Application Data\Teleca
    2008-10-25 21:09 . 2007-04-23 14:54 108,680 -ra------ c:\windows\system32\drivers\s115mdm.sys
    2008-10-25 21:09 . 2007-04-23 14:54 100,488 -ra------ c:\windows\system32\drivers\s115mgmt.sys
    2008-10-25 21:09 . 2007-04-23 14:54 98,568 -ra------ c:\windows\system32\drivers\s115obex.sys
    2008-10-25 21:09 . 2007-04-23 14:54 83,208 -ra------ c:\windows\system32\drivers\s115bus.sys
    2008-10-25 21:09 . 2007-04-23 14:54 15,112 -ra------ c:\windows\system32\drivers\s115mdfl.sys
    2008-10-25 21:09 . 2007-04-23 14:54 12,424 -ra------ c:\windows\system32\drivers\s115whnt.sys
    2008-10-25 21:09 . 2007-04-23 14:54 12,424 -ra------ c:\windows\system32\drivers\s115wh.sys
    2008-10-25 21:09 . 2007-04-23 14:54 12,424 -ra------ c:\windows\system32\drivers\s115cmnt.sys
    2008-10-25 21:09 . 2007-04-23 14:54 12,424 -ra------ c:\windows\system32\drivers\s115cm.sys
    2008-10-25 21:07 . 2008-10-25 21:08 <DIR> d----c--- c:\windows\system32\DRVSTORE
    2008-10-25 21:05 . 2008-10-25 21:05 <DIR> d-------- c:\program files\Sony Ericsson
    2008-10-25 21:05 . 2008-10-25 21:05 <DIR> d-------- c:\program files\Common Files\Sony Ericsson Shared
    2008-10-25 21:05 . 2008-10-25 21:05 <DIR> d-------- c:\documents and settings\Gray\Application Data\Sony Ericsson
    2008-10-25 21:04 . 2008-10-25 21:04 <DIR> d-------- c:\windows\Downloaded Installations
    2008-10-25 21:04 . 2008-10-25 21:05 <DIR> d-------- c:\documents and settings\All Users\Application Data\Teleca
    2008-10-25 21:04 . 2008-10-25 21:05 <DIR> d-------- c:\documents and settings\All Users\Application Data\Sony Ericsson
    2008-10-25 20:47 . 2008-10-25 21:07 <DIR> d-------- c:\program files\Common Files\Teleca Shared
    2008-10-25 20:42 . 2008-10-25 20:42 <DIR> d-------- c:\program files\NOS
    2008-10-25 20:42 . 2008-10-26 08:19 <DIR> d-------- c:\documents and settings\All Users\Application Data\NOS
    2008-10-25 20:35 . 2008-09-15 12:12 1,846,400 --------- c:\windows\system32\dllcache\win32k.sys
    2008-10-25 20:35 . 2008-09-08 10:41 333,824 --------- c:\windows\system32\dllcache\srv.sys
    2008-10-25 20:35 . 2008-06-13 11:05 272,128 --------- c:\windows\system32\dllcache\bthport.sys
    2008-10-25 20:35 . 2008-05-08 14:02 203,136 --------- c:\windows\system32\dllcache\rmcast.sys
    2008-10-25 20:34 . 2008-08-14 10:11 2,189,184 --------- c:\windows\system32\dllcache\ntoskrnl.exe
    2008-10-25 20:34 . 2008-08-14 10:09 2,145,280 --------- c:\windows\system32\dllcache\ntkrnlmp.exe
    2008-10-25 20:34 . 2008-08-14 09:33 2,066,048 --------- c:\windows\system32\dllcache\ntkrnlpa.exe
    2008-10-25 20:34 . 2008-08-14 09:33 2,023,936 --------- c:\windows\system32\dllcache\ntkrpamp.exe
    2008-10-25 20:34 . 2008-04-11 19:04 691,712 --------- c:\windows\system32\dllcache\inetcomm.dll
    2008-10-25 20:34 . 2008-05-01 14:33 331,776 --------- c:\windows\system32\dllcache\msadce.dll
    2008-10-25 20:31 . 2008-10-15 16:34 337,408 --------- c:\windows\system32\dllcache\netapi32.dll
    2008-10-25 20:21 . 2008-10-26 07:59 51 --a------ c:\windows\iTouch.ini
    2008-10-25 20:17 . 2008-10-25 20:17 <DIR> d-------- c:\program files\Microsoft ActiveSync
    2008-10-25 20:17 . 2008-10-25 20:17 376 --a------ c:\windows\ODBC.INI
    2008-10-25 20:16 . 2008-10-25 20:17 <DIR> d-------- c:\windows\ShellNew
    2008-10-25 20:09 . 2008-10-25 20:09 <DIR> d-------- c:\documents and settings\Gray\Application Data\Ahead
    2008-10-25 20:06 . 2008-10-25 20:06 <DIR> d-------- c:\program files\Nero
    2008-10-25 20:06 . 2008-10-25 20:10 <DIR> d-------- c:\program files\Common Files\Ahead
    2008-10-25 20:06 . 2008-10-25 20:06 81,920 -r------- c:\windows\bwUnin-6.1.4.36-8876480L.exe
    2008-10-25 20:05 . 2002-11-21 08:50 155,648 --a------ c:\windows\system32\ifc21.dll
    2008-10-25 20:05 . 2002-11-08 09:50 152,064 --------- c:\windows\system32\lmoufrc.dll
    2008-10-25 20:05 . 2002-11-21 08:50 105,472 --a------ c:\windows\system32\COMNCTR.DLL
    2008-10-25 20:05 . 2002-11-21 08:50 99,328 --a------ c:\windows\system32\LGUICOM.DLL
    2008-10-25 20:05 . 2002-11-21 08:50 94,208 --a------ c:\windows\system32\FEELIT.DLL
    2008-10-25 20:05 . 2002-11-08 09:50 70,238 --a------ c:\windows\system32\drivers\LMouFlt2.Sys
    2008-10-25 20:05 . 2002-11-08 09:50 52,238 --------- c:\windows\system32\drivers\L8042PR2.SYS
    2008-10-25 20:05 . 2002-11-08 09:50 23,838 --a------ c:\windows\system32\drivers\LHidFlt2.Sys
    2008-10-25 20:05 . 2002-11-08 09:50 19,968 --------- c:\windows\LOGI_MWX.EXE
    2008-10-25 20:05 . 2002-11-21 08:50 16,896 --a------ c:\windows\system32\LMOUSE32.DLL
    2008-10-25 20:05 . 2002-11-08 09:50 4,524 --------- c:\windows\system32\LCOINST.DLL
    2008-10-25 20:05 . 2002-11-21 08:50 3,568 --a------ c:\windows\system32\LMOUSE16.DLL
    2008-10-25 20:04 . 2008-10-25 20:06 <DIR> d-------- c:\program files\Logitech
    2008-10-25 20:04 . 2008-10-25 20:04 <DIR> d-------- c:\program files\Common Files\Logitech
    2008-10-25 20:04 . 2002-11-23 11:15 322,832 --a------ c:\windows\system32\MFC30.DLL
    2008-10-25 20:04 . 2002-11-08 09:50 41,420 --a------ c:\windows\system32\drivers\LHidUsb.sys
    2008-10-25 20:04 . 2002-11-08 09:50 14,156 --a------ c:\windows\system32\drivers\LCcfltr.sys
    2008-10-25 20:04 . 2002-11-15 02:15 12,640 --------- c:\windows\system32\drivers\itchfltr.sys
    2008-10-25 13:33 . 2008-10-25 13:33 <DIR> d-------- C:\OEMCUST
    2008-10-25 13:31 . 2008-11-14 12:32 <DIR> d--h----- c:\windows\$hf_mig$
    2008-10-25 13:29 . 2008-11-19 19:17 <DIR> d-------- c:\windows\system32\drivers\Avg
    2008-10-25 13:29 . 2008-10-25 13:29 <DIR> d-------- c:\program files\Windows Media Connect 2
    2008-10-25 13:29 . 2008-10-25 13:29 <DIR> d-------- c:\program files\AVG
    2008-10-25 13:29 . 2008-10-25 20:24 <DIR> d-------- c:\documents and settings\Gray\Application Data\AVGTOOLBAR
    2008-10-25 13:29 . 2008-10-25 13:29 <DIR> d-------- c:\documents and settings\All Users\Application Data\avg8
    2008-10-25 13:29 . 2008-10-26 09:42 97,928 --a------ c:\windows\system32\drivers\avgldx86.sys
    2008-10-25 13:29 . 2008-10-25 13:29 76,040 --a------ c:\windows\system32\drivers\avgtdix.sys
    2008-10-25 13:29 . 2008-10-25 13:29 10,520 --a------ c:\windows\system32\avgrsstx.dll
    2008-10-25 13:27 . 2008-10-25 13:27 <DIR> d-------- c:\windows\system32\LogFiles
    2008-10-25 13:27 . 2008-10-25 13:28 <DIR> d-------- c:\windows\system32\drivers\UMDF
    2008-10-25 13:19 . 2008-10-25 13:25 316,640 --a------ c:\windows\WMSysPr9.prx
    2008-10-25 13:17 . 2008-10-28 19:08 <DIR> d-------- c:\windows\ServicePackFiles
    2008-11-17 01:23 1,618,432 ----a-w c:\windows\Internet Logs\xDB1.tmp
    2008-11-16 18:59 977,334 ----a-w c:\windows\Internet Logs\tvDebug.zip
    2008-10-24 11:21 455,296 ----a-w c:\windows\system32\drivers\mrxsmb.sys
    2008-10-16 14:13 202,776 ----a-w c:\windows\system32\wuweb.dll
    2008-10-16 14:13 202,776 ----a-w c:\windows\system32\dllcache\wuweb.dll
    2008-10-16 14:13 1,809,944 ----a-w c:\windows\system32\wuaueng.dll
    2008-10-16 14:13 1,809,944 ----a-w c:\windows\system32\dllcache\wuaueng.dll
    2008-10-16 14:12 561,688 ----a-w c:\windows\system32\wuapi.dll
    2008-10-16 14:12 561,688 ----a-w c:\windows\system32\dllcache\wuapi.dll
    2008-10-16 14:12 323,608 ----a-w c:\windows\system32\wucltui.dll
    2008-10-16 14:12 323,608 ----a-w c:\windows\system32\dllcache\wucltui.dll
    2008-10-16 14:09 92,696 ----a-w c:\windows\system32\dllcache\cdm.dll
    2008-10-16 14:09 92,696 ----a-w c:\windows\system32\cdm.dll
    2008-10-16 14:09 51,224 ----a-w c:\windows\system32\wuauclt.exe
    2008-10-16 14:09 51,224 ----a-w c:\windows\system32\dllcache\wuauclt.exe
    2008-10-16 14:09 43,544 ----a-w c:\windows\system32\wups2.dll
    2008-10-16 14:08 34,328 ----a-w c:\windows\system32\wups.dll
    2008-10-16 14:08 34,328 ----a-w c:\windows\system32\dllcache\wups.dll
    2008-10-03 17:41 6,066,176 ------w c:\windows\system32\dllcache\ieframe.dll
    2008-09-30 16:43 1,286,152 ----a-w c:\windows\system32\msxml4.dll
    2008-09-15 12:12 1,846,400 ----a-w c:\windows\system32\win32k.sys
    2008-09-10 01:14 1,307,648 ------w c:\windows\system32\msxml6.dll
    2008-09-10 01:14 1,307,648 ------w c:\windows\system32\dllcache\msxml6.dll
    2008-09-04 17:15 1,106,944 ----a-w c:\windows\system32\msxml3.dll
    2008-08-27 08:24 3,593,216 ------w c:\windows\system32\dllcache\mshtml.dll
    2008-08-25 08:38 13,824 ------w c:\windows\system32\dllcache\ieudinit.exe
    2008-08-25 08:37 70,656 ------w c:\windows\system32\dllcache\ie4uinit.exe
    2008-08-23 05:56 635,848 ------w c:\windows\system32\dllcache\iexplore.exe
    2008-08-23 05:54 161,792 ------w c:\windows\system32\dllcache\ieakui.dll
    ((((((((((((((((((((((((((((( snapshot@2008-11-16_16.42.20.48 )))))))))))))))))))))))))))))))))))))))))
    + 2005-10-20 20:02:28 163,328 ----a-w c:\windows\ERDNT\subs\ERDNT.EXE
    + 2008-11-16 17:34:40 884,736 ----a-w c:\windows\gmer.dll
    + 2008-04-17 21:13:02 811,008 ----a-w c:\windows\gmer.exe
    + 2008-11-16 17:34:40 85,969 ----a-w c:\windows\system32\drivers\gmer.sys
    "ctfmon.exe "= "c:\windows\system32\ctfmon.exe" [2008-04-14 15360]
    "SpybotSD TeaTimer "= "c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2008-09-16 1833296]
    "ZoneAlarm Client "= "c:\program files\Zone Labs\ZoneAlarm\zlclient.exe" [2008-07-09 919016]
    "AVG8_TRAY "= "c:\progra~1\AVG\AVG8\avgtray.exe" [2008-10-26 1234712]
    "ATICCC "= "c:\program files\ATI Technologies\ATI.ACE\cli.exe" [2006-01-02 45056]
    "QuickTime Task "= "c:\program files\QuickTime\qttask.exe" [2008-10-25 77824]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    "CTFMON.EXE "= "c:\windows\System32\CTFMON.EXE" [2008-04-14 15360]
    c:\documents and settings\Gray\Start Menu\Programs\Startup\
    Flip.lnk - c:\program files\Belkin\Flip\flip.exe [2006-08-22 385024]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "AppInit_DLLs "=avgrsstx.dll
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Logitech Desktop Messenger.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Logitech Desktop Messenger.lnk
    backup=c:\windows\pss\Logitech Desktop Messenger.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
    backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
    --a------ 2008-06-12 02:38 34672 c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}]
    --a------ 2005-11-24 14:38 94208 c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HotKeysCmds]
    --a------ 2002-12-13 06:10 114688 c:\windows\system32\hkcmd.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IgfxTray]
    --a------ 2002-12-13 06:22 155648 c:\windows\system32\igfxtray.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LDM]
    --a------ 2008-10-25 20:06 16384 c:\program files\Logitech\Desktop Messenger\8876480\Program\backWeb-8876480.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
    --a------ 2001-07-09 09:50 155648 c:\windows\system32\NeroCheck.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Sony Ericsson PC Suite]
    -ra------ 2007-06-13 07:16 528384 c:\program files\Sony Ericsson\Mobile2\Application Launcher\Application Launcher.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\zBrowser Launcher]
    --a------ 2002-11-23 01:15 631362 c:\program files\Logitech\iTouch\iTouch.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Logitech Utility]
    --------- 2002-11-08 09:50 19968 c:\windows\LOGI_MWX.EXE
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\ZoneLabsFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "c:\\Program Files\\AVG\\AVG8\\avgemc.exe "=
    "c:\\Program Files\\AVG\\AVG8\\avgupd.exe "=
    "c:\\Program Files\\Logitech\\Desktop Messenger\\8876480\\Program\\backWeb-8876480.exe "=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\Drivers\avgldx86.sys [2008-10-25 97928]
    R2 avg8emc;AVG Free8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [2008-10-25 875288]
    R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [2008-10-25 231704]
    R2 AvgTdiX;AVG Free8 Network Redirector;c:\windows\system32\Drivers\avgtdix.sys [2008-10-25 76040]
    R3 s115bus;Sony Ericsson Device 115 driver (WDM);c:\windows\system32\DRIVERS\s115bus.sys [2008-10-25 83208]
    R3 s115mdfl;Sony Ericsson Device 115 USB WMC Modem Filter;c:\windows\system32\DRIVERS\s115mdfl.sys [2008-10-25 15112]
    R3 s115mdm;Sony Ericsson Device 115 USB WMC Modem Driver;c:\windows\system32\DRIVERS\s115mdm.sys [2008-10-25 108680]
    R3 s115mgmt;Sony Ericsson Device 115 USB WMC Device Management Drivers (WDM);c:\windows\system32\DRIVERS\s115mgmt.sys [2008-10-25 100488]
    R3 s115obex;Sony Ericsson Device 115 USB WMC OBEX Interface;c:\windows\system32\DRIVERS\s115obex.sys [2008-10-25 98568]
    R3 STAC97NA;SigmaTel 3D Environmental Audio;c:\windows\system32\drivers\stac97na.sys [1979-12-31 296179]
    R3 STAC97NH;STAC97NH;c:\windows\system32\drivers\stac97nh.sys [1979-12-31 231983]
    S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\NOS\bin\getPlus_HelperSvc.exe [2008-10-25 33752]
    S3 LCcfltr;Logitech USB Filter Driver;c:\windows\system32\Drivers\LCcFltr.Sys [2008-10-25 14156]
    catchme 0.3.1367 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2008-11-19 19:32:16
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    ------------------------ Other Running Processes ------------------------
    c:\windows\system32\ati2evxx.exe
    c:\windows\system32\ZoneLabs\vsmon.exe
    c:\program files\AVG\AVG8\avgrsx.exe
    Completion time: 2008-11-19 19:36:04 - machine was rebooted
    ComboFix-quarantined-files.txt 2008-11-19 19:35:52
    ComboFix2.txt 2008-11-16 21:44:25
    ComboFix3.txt 2008-11-16 18:28:57
    ComboFix4.txt 2008-11-16 16:43:06
    Pre-Run: 26,951,794,688 bytes free
    Post-Run: 27,005,272,064 bytes free
    279 --- E O F --- 2008-11-14 12:34:11
  8. 2008/11/20
    noahdfear
    noahdfear Inactive
    Please do an online scan with Kaspersky Online Scanner
    Click Accept, when prompted to download and install the program files and database of malware definitions.
    • Click Run at the Security prompt.
    • The program will then begin downloading and installing and will also update the database.
    • Please be patient as this can take several minutes.
    • Once the update is complete, click on My Computer under the green Scan bar to the left to start the scan.
    • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
    • Click View scan report at the bottom.
    • Click the Save Report As... button.
    • Click the Save as Text button to save the file to your desktop so that you may post it in your next reply.
    **Note**
    To optimize scanning time and produce a more sensible report for review:
    • Close any open programs.
    • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
    Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75%. Once the license is accepted, reset to 100%.
    Post the Kaspersky log here.
  9. 2008/11/21
    gray916
    Hi
    I tried to run the programme but the accept box is greyed out. I have closed spybot, avg and zone alarm. Still greyed out.
    It says i need java 1.5 which i have installed. Still greyed out.
    One thing i have noticed, the with all of this shutdown, the redirect seems to have stopped. I shall now do a reeboot and try angain, see if the redirect comes back, and see if i can run the scan.
    Any other ideas in the meantime?
  10. 2008/11/21
    gray916
    re boot worked
    i am scanning now
  11. 2008/11/21
    gray916
    KASPERSKY ONLINE SCANNER 7 REPORT
    Friday, November 21, 2008
    Operating System: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner 7 version: 7.0.25.0
    Program database last update: Friday, November 21, 2008 16:12:31
    Records in database: 1399616
    Scan settings:
    Scan using the following database: extended
    Scan archives: yes
    Scan mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    Q:\
    R:\
    Scan statistics:
    Files scanned: 73829
    Threat name: 2
    Infected objects: 4
    Suspicious objects: 0
    Duration of the scan: 03:37:39
    File name / Threat name / Threats count
    C:\Qoobox\Quarantine\C\autorun.inf.vir Infected: Worm.Win32.AutoRun.nuu 1
    C:\Qoobox\Quarantine\C\resycled\boot.com.vir Infected: Trojan.Win32.Agent.aoir 1
    C:\System Volume Information\_restore{98E46F0A-9DA1-4258-92C4-7CCAE5D21E6E}\RP45\A0012073.inf Infected: Worm.Win32.AutoRun.nuu 1
    C:\System Volume Information\_restore{98E46F0A-9DA1-4258-92C4-7CCAE5D21E6E}\RP46\A0012119.inf Infected: Worm.Win32.AutoRun.nuu 1
    The selected area was scanned.
  12. 2008/11/22
    noahdfear
    noahdfear Inactive
    How's the behavior now?
  13. 2008/11/23
    gray916
    It seems to be working correctly
    However, i dont have google toolbar installed any more.
    I suspect if i re install the GT the problem will re occur
  14. 2008/11/23
    noahdfear
    noahdfear Inactive
    I do not suspect it is the Google toolbar. It would be the first I'd ever heard of it if it is though. Would actually be great if you could confirm. Lets clean up.
    Click Start>Run and type or paste the following command then hit enter to uninstall gmer.
    %systemroot%\gmer_uninstall.cmd
    Restart the computer to complete the uninstallation of gmer.
    Now open MBAM and remove any items quarantined. Do the same with your resident antivirus.
    Click Start>Run and type ComboFix /u then hit Enter to uninstall ComboFix and remove the files it has quarantined. This action will also reset the System Restore points, removing any infected files there as well.
    Verify the C:\Qoobox and C:\ComboFix folders were removed, as well as the C:\ComboFix.txt file.
    You can delete any other logs that were created/saved too.
    Run ATF Cleaner once again as previously described.
    Provided there are no other problems, that should wrap this up.
  15. 2008/11/23
    gray916
    i have ran the first line of code and re booted
    forgive by ignorance, what is MBAM?
  16. 2008/11/23
    gray916
    makware byte anti malware (sorry)
    running thatnow
  17. 2008/11/23
    gray916
    It didnt delete the C:\ComboFix folder, although it did delete most of the stuff in it, except 'moveex' and 'nircmd'
    C:\ComboFix.txt file was NOT removed.
    i did get a box saying that combofix was uninistalled successfully
    I tried deleting them myself but i got the error saying it was being used by another process.
    qoobox file was removedshould i still run atf cleaner?
  18. 2008/11/23
    noahdfear
    noahdfear Inactive
    Go ahead and run ATF and reboot. You should be able to remove the leftovers then.
  19. 2008/11/23
    gray916
    ! REG.EXE VERSION 3.0
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{0E04FC30-8D36-43B4-9D5D-E30458C65896}
    UseZeroBroadcast REG_DWORD 0x0
    EnableDHCP REG_DWORD 0x0
    IPAddress REG_MULTI_SZ 0.0.0.0\0\0
    SubnetMask REG_MULTI_SZ 0.0.0.0\0\0
    DefaultGateway REG_MULTI_SZ \0
    EnableDeadGWDetect REG_DWORD 0x1
    DontAddDefaultGateway REG_DWORD 0x0
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{39EA83D4-86B1-4C4F-9592-517144DFF1AE}
    EnableDHCP REG_DWORD 0x1
    DefaultGatewayMetric REG_MULTI_SZ \0
    NameServer REG_SZ
    Domain REG_SZ
    RegistrationEnabled REG_DWORD 0x1
    RegisterAdapterName REG_DWORD 0x0
    TCPAllowedPorts REG_MULTI_SZ 0\0\0
    UDPAllowedPorts REG_MULTI_SZ 0\0\0
    RawIPAllowedProtocols REG_MULTI_SZ 0\0\0
    NTEContextList REG_MULTI_SZ 0x00000002\0\0
    DhcpClassIdBin REG_BINARY
    DhcpIPAddress REG_SZ 192.168.1.3
    DhcpSubnetMask REG_SZ 255.255.255.0
    DhcpServer REG_SZ 192.168.1.1
    Lease REG_DWORD 0x15180
    LeaseObtainedTime REG_DWORD 0x4929a23d
    T1 REG_DWORD 0x492a4afd
    T2 REG_DWORD 0x492ac98d
    LeaseTerminatesTime REG_DWORD 0x492af3bd
    IPAutoconfigurationAddress REG_SZ 0.0.0.0
    IPAutoconfigurationMask REG_SZ 255.255.0.0
    IPAutoconfigurationSeed REG_DWORD 0x0
    AddressType REG_DWORD 0x0
    IsServerNapAware REG_DWORD 0x0
    DhcpRetryTime REG_DWORD 0xa8be
    DhcpRetryStatus REG_DWORD 0x0
    DhcpNameServer REG_SZ 192.168.1.1
    DhcpDefaultGateway REG_MULTI_SZ 192.168.1.1\0\0
    DhcpSubnetMaskOpt REG_MULTI_SZ 255.255.255.0\0\0
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{EB879521-6354-4BC0-A544-81E745F8CB74}
  20. 2008/11/23
    noahdfear
    noahdfear Inactive
    Looks fine. How's everything now?
  21. 2008/11/24
    gray916
    Everything is fine, should i try reinstalling google toolbar?
    I dont want to mess it up again by putting in GT
