Resolved If Enable protected mode is checked am I automatically running I.E. 64bit
Discussion in 'Internet Explorer & Microsoft Edge' started by Alicia J, 2015/04/14.
  1. 2015/04/14
    Alicia J Lifetime Subscription
    Alicia J Geek Member Thread Starter
    I'm using I.E. 11. If I have enable protected mode checked am I automatically running the 64 bit version?
    I read the thread about 32 vs 64 bit version and am thoroughly confused.
  2. 2015/04/14
    I read that thread and got lost. I obviously misunderstood it if I'm not
    necessarily running I.E. 64bit.
  5. 2015/04/15
    If you are using the regular Protected Mode then you are still running the 32-bit version of Internet Explorer. If you enable the Enhanced Protected Mode feature in Internet Explorer then you enable 64-bit tabs in Internet Explorer.
  6. 2015/04/15
    I have enable protected mode checked. Out of curiosity, where is the option to check enhanced protected mode located? I couldn't find it under the security tab in I.E. options. (I could just be blind).
  7. 2015/04/15
    The option is located on the Advanced tab in Internet Options at the bottom.
  8. 2015/04/15
    Thanks Evan. I appreciate your help.
  9. 2015/04/15
    You're Welcome. :)
