Solved iexplore.exe problem
Discussion in 'Malware and Virus Removal Archive' started by bartdude59, 2010/07/02.
  1. 2010/07/04
    bartdude59
    bartdude59 Inactive Thread Starter
    Done with the scan. Here are the found threats:
    C:\Documents and Settings\Administrator\Desktop\GTA-SA-GarageEdit-v1.zip probably a variant of Win32/Spy.Agent trojan
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\35\7f6dbfe3-54ff7e02 Java/TrojanDownloader.Agent.NBE trojan
  2. 2010/07/04
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [resethosts]
      [Reboot]
    bartdude59
    Here's the log you requested:
    All processes killed
    ========== OTL ==========
    ========== FILES ==========
    C:\Documents and Settings\Administrator\Desktop\GTA-SA-GarageEdit-v1.zip moved successfully.
    C:\WINDOWS\system32\config\systemprofile\Application Data\Sun\Java\Deployment\cache\6.0\35 folder moved successfully.
    [EMPTYTEMP]
    User: Administrator
    ->Temp folder emptied: 83320 bytes
    ->Java cache emptied: 5400 bytes
    ->FireFox cache emptied: 60138813 bytes
    ->Google Chrome cache emptied: 34322979 bytes
    ->Flash cache emptied: 7862 bytes
    User: All Users
    User: Asdf
    ->FireFox cache emptied: 0 bytes
    User: Default User
    User: LocalService
    User: NetworkService
    Windows Temp folder emptied: 64245760 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 151.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Asdf
    User: Default User
    User: LocalService
    C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    OTL by OldTimer - Version 3.2.7.0 log created on 07042010_172547
  5. 2010/07/04
    Cool :)
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  6. 2010/07/04
    bartdude59
    I don't have a System Restore tab in Properties. There only tabs are Advanced, General, Automatic Updates, Computer Names, Remote, and Hardware.
  7. 2010/07/04
    bartdude59
    I am in the Windows NT folder, but there is no SystemRestore folder/file.
    Edit: I did what it told me to in the Group Policy Editor, but I still do not have a System Restore tab.
  9. 2010/07/04
    Did you try second option, GPEDIT.MSC?
  10. 2010/07/04
    bartdude59
    Yep, still no System Restore tab.
  11. 2010/07/04
    Skip that step for now.
    Since your computer is malware free, I suggest, you create new topic about system restore problem at Windows forum.
    You'll get more attention. In malware forum, it's just you and me.
    I just need a final word from you to mark this topic as "Resolved ".
  12. 2010/07/04
    bartdude59
    Alright, everything seems to be good. I'll start changing my passwords. Thanks for everything broni. :D
  13. 2010/07/04
    You're very welcome :)
    Good luck and stay safe :)
