Solved I need help with very strange Chinese SPAM/Malware
Discussion in 'Malware and Virus Removal Archive' started by bellisimo, 2014/05/25.
  1. 2014/05/29
    bellisimo Lifetime Subscription
    bellisimo Well-Known Member Thread Starter
    There's a message that says another antivirus software was detected. This may affect the performance and quality of the scan. It shows AVG. I have it disabled.
  2. 2014/05/29
    Disregard that warning.
    Hi Broni,
    After 45 minutes, ESET is still on Step 1 of 4. The only indication that it might be working at all is that the Ethernet and Internet lights on the router are flickering a little bit.
  5. 2014/05/29
    Eset may take time.
    Leave it overnight.
  6. 2014/05/29
    Okay.
    I've started to tun it on Firefox though I don't hear any activity from the tower. I would have thought I'd hear more than the fans spinning around.
  7. 2014/05/30
    Hi Broni,
    Its 4 pm and ESET doesn't seem to have done anything after more than 18 hours. It's still on Step 1. I did a Ctrl. Alt. Delete and it seems to still be running.
    If you think it would make a difference I uninstalled my AVG.
  8. 2014/05/30
    Try to run Eset with different browser.
  9. 2014/05/30
    Okay, I've started to run it with Firefox though I don't hear any activity from the tower.
  10. 2014/05/30
    Please run F-Secure Online Scanner
    • Disable your Antivirus program.
    • Click on Run now button.
      NOTE. If you're using non-IE browser you'll be asked to download small file (F-SecureOnlineScanner.exe). After downloading double click on the file to run the scan.
    • Click on Start button.
    • Click on "Accept" button.
    • When scan is done, in Step 3: Clean the files, leave all settings as they're.
    • Click Next button.
    • Click Full report... button.
    • Copy report's content and paste it into your next reply.
  11. 2014/05/30
    Broni,
    The F-Secure scan finished quickly and it said there were no problems.
    There's a message saying: Your device is not protected. We recommend that you use a security application to protect your device.
    Then, there is a button on which it says Get SAFE. I think it would probably take me to an antivirus download. What next?
    I think you've cleaned it out. The system has been running beautifully and I haven't seen the wireless light on the router for two days. Before, it was on constantly.
  12. 2014/05/30
    [​IMG] Update Firefox to the latest 29.0.1 version.
    [​IMG] Update Adobe Flash Player: http://get.adobe.com/flashplayer/
    Make sure you UN-check Yes, install McAfee Security Scan Plus
    NOTE 1: Beginning with Adobe Flash Version 11.3, the universal installer includes the 32-bit and 64-bit versions of the Flash Player.
    NOTE 2: While installing make sure you UN-check any extra garbage which wants to install alongside.
    Your computer is clean [​IMG]
    1. This step will remove all cleaning tools we used, it'll reset restore points (so you won't get reinfected by accidentally using some older restore point) and it'll make some other minor adjustments...
    This is a very crucial step so make sure you don't skip it.
    Download [​IMG]DelFix by Xplode to your desktop. Delfix will delete all the used tools and logfiles.
    Double-click Delfix.exe to start the tool.
    Make sure the following items are checked:
    • Activate UAC (optional; some users prefer to keep it off)
    • Remove disinfection tools
    • Create registry backup
    • Purge System Restore
    • Reset system settings
    Now click "Run" and wait patiently.
    Once finished a logfile will be created. You don't have to attach it to your next reply.
    2. Make sure Windows Updates are current.
    3. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    4. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Temporary File Cleaner (TFC), AdwCleaner and Junkware Removal Tool (JRT) weekly (you need to redownload these tools since they were removed by DelFix).
    10. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    11. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    About those Toolbars and Add-ons - Potentially Unwanted Programs (PUPs) which change your browser settings: http://www.bleepingcomputer.com/for...curity-questions-best-practices/#entry3187642
    12. Please, let me know, how your computer is doing.
  13. 2014/05/31
    Broni,
    I just opened my computer to send you a thank you message, and as soon as my machine booted up, I was shocked to find the attached on my screen.
    I guess we didn't get it all yet.
    I did everything else you suggested and the only thing that was different was that the Adobe Flash Player is updated to version 13.
    Have you ever seen one worse than this? I don't know what to do.
    I changed my passwords last night, too. Will I have to change them again?
    It's not a very sharp image, I'm afraid. It's the one I described earlier with the trash can about the size of a business card. I can send another if you need it.
    Please let me know what you think.
    Thanks,
    bellisimo
  14. 2014/05/31
    Please re-run MBAM, AdwCleaner and JRT.
    Post all logs.
  15. 2014/05/31
    Hi Broni,
    Here is the MBAM report:
    Malwarebytes Anti-Malware (Trial) 1.75.0.1300
    www.malwarebytes.org
    Database version: v2014.05.31.10
    Windows 7 Service Pack 1 x64 NTFS
    Internet Explorer 10.0.9200.16899
    a :: BBELL-PC [administrator]
    Protection: Enabled
    5/31/2014 9:29:25 PM
    mbam-log-2014-05-31 (21-29-25).txt
    Scan type: Full scan (C:\|)
    Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
    Scan options disabled: P2P
    Objects scanned: 449883
    Time elapsed: 15 minute(s), 58 second(s)
    Memory Processes Detected: 0
    (No malicious items detected)
    Memory Modules Detected: 0
    Registry Keys Detected: 0
    Registry Values Detected: 0
    Registry Data Items Detected: 0
    Folders Detected: 0
    Files Detected: 0
    (end)
  16. 2014/05/31
    Here is the JRT scan:
    Junkware Removal Tool (JRT) by Thisisu
    Version: 6.1.4 (04.06.2014:1)
    OS: Windows 7 Home Premium x64
    Ran by a on Sat 05/31/2014 at 21:48:43.35
    ~~~ Services
    ~~~ Registry Values
    ~~~ Registry Keys
    ~~~ Files
    ~~~ Folders
    ~~~ Event Viewer Logs were cleared
    Scan was completed on Sat 05/31/2014 at 21:55:09.14
    End of JRT log
  17. 2014/05/31
    Here's the AdwrCleaner scan:
    # AdwCleaner v3.211 - Report created 31/05/2014 at 22:00:09
    # Updated 26/05/2014 by Xplode
    # Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
    # Username : a - BBELL-PC
    # Running from : C:\Users\a\Desktop\AdwCleaner.exe
    # Option : Clean
    ***** [ Services ] *****
    ***** [ Files / Folders ] *****
    ***** [ Shortcuts ] *****
    ***** [ Registry ] *****
    Key Deleted : HKCU\Software\AppDataLow\Software
    ***** [ Browsers ] *****
    -\\ Internet Explorer v10.0.9200.16866
    -\\ Mozilla Firefox v29.0.1 (en-US)
    [ File : C:\Users\a\appData\Roaming\Mozilla\Firefox\Profiles\naxv236a.default\prefs.js ]
    -\\ Google Chrome v
    AdwCleaner[R0].txt - [845 octets] - [31/05/2014 19:50:53]
    AdwCleaner[R1].txt - [902 octets] - [31/05/2014 21:58:58]
    AdwCleaner[S0].txt - [814 octets] - [31/05/2014 22:00:09]
    ########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [873 octets] ##########
  18. 2014/05/31
    OK...I want to make sure...
    The issue happens only if you're actually using IE.
    It doesn't happen when some other browser is being used or no browser is being used at all.
    Is that correct?
  19. 2014/05/31
    Yes, I believe that's true because IE is the only browser I have been using, and my email account is Outlook on IE as well.
  20. 2014/05/31
    I can see you also have Firefox installed.
    I want you to use Firefox for couple of computer sessions and see if the issue happens there too.
  21. 2014/05/31
    Sure, I'll try that. For how many days should we try it for? I only ask because if the malware is active in my system, could it now be destroying files during the period when I'm using Firefox.
    I looked up some email files I had saved 2 or 3 years ago and pages of them that I used to be able to open have changed into a type of file that I can no longer access. I don't know if it has anything to do with this malware though.
    I do have all my hard drives backed up with Acronis True image on my external drive though I haven't a clue how to restore my C: Drive with them.
