I need help with a virus i think
Discussion in 'Malware and Virus Removal Archive' started by tiffanyc, 2007/05/11.
  1. 2007/05/20
    tiffanyc
    tiffanyc Inactive Thread Starter
    Volume in drive C has no label.
    Volume Serial Number is 10A4-67C2
    Directory of C:\Documents and Settings\tiff\Desktop
    05/19/2007 03:07 PM 72,192 tasklist.exe
    1 File(s) 72,192 bytes
    Directory of C:\WINDOWS\system32\New Folder
    Total Files Listed:
    2 File(s) 144,384 bytes
    0 Dir(s) 66,949,156,864 bytes free
    Parameter format not correct -
    ALLUSERSPROFILE=C:\Documents and Settings\All Users
    APPDATA=C:\Documents and Settings\tiff\Application Data
    CLASSPATH=C:\Program Files\Java\jre1.5.0_06\lib\ext\QTJava.zip
    CLIENTNAME=Console
    CommonProgramFiles=C:\Program Files\Common Files
    COMPUTERNAME=TIFFANY
    ComSpec=C:\WINDOWS\system32\cmd.exe
    FP_NO_HOST_CHECK=NO
    HOMEDRIVE=C:
    HOMEPATH=\Documents and Settings\tiff
    LOGONSERVER=\\TIFFANY
    NUMBER_OF_PROCESSORS=1
    OS=Windows_NT
    Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\WinSCP3\;C:\Program Files\QuickTime\QTSystem\
    PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
    PROCESSOR_ARCHITECTURE=x86
    PROCESSOR_IDENTIFIER=x86 Family 6 Model 10 Stepping 0, AuthenticAMD
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=0a00
    PROMPT=$P$G
    QTJAVA=C:\Program Files\Java\jre1.5.0_06\lib\ext\QTJava.zip
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\WINDOWS
    TEMP=C:\DOCUME~1\tiff\LOCALS~1\Temp
    TMP=C:\DOCUME~1\tiff\LOCALS~1\Temp
    USERDOMAIN=TIFFANY
    USERNAME=tiff
    USERPROFILE=C:\Documents and Settings\tiff
    windir=C:\WINDOWS
    Total Files Listed:
    0 Dir(s) 66,949,152,768 bytes free
  2. 2007/05/20
    bbbobins
    bbbobins Banned
    There it is
    it is in c:\windows\system32\new folder
    Use My Computer browse to c:\windows\system32\new folder
    copy tasklist.exe
    browse again to c:\windows\system32
    paste Tasklist.exe there.
    Bob
    bbbobins
    bbbobins Banned
    Ok Tiffany
    You have done a Bodacious job.
    I think we are clean.
    Hopefully the Bitdefender will run to completion.
    And I still want to see the tasklist.
    But we are going out for a late lunch (or early dinner) and an errand, 2:30 pm here.
    Perhaps 2-3 hrs.
    Then I will post some final cleanups and a couple of suggestions to improve stability and performance.
    But for now you can breath easy as you are now more Virus and Malware clean than most.
    Use your computer as normal untill I get back.
    After we finish that you can change your online passwords.
    Bob
  5. 2007/05/20
    tiffanyc
    ok i found the file and now have it in the right place!!!! I am going to run the bitdefender and panda now and will post results for you when you get back!!!
  6. 2007/05/20
    bbbobins
    bbbobins Banned
    Ok but the idea was when it was in the right place, to paste the following line to the run command
    %SystemRoot%\system32\cmd.exe /c %windir%\system32\tasklist.exe /svc > "%USERPROFILE% "\Desktop\Tasklist.txt
    and paste me the contents of the tasklist.txt file
    Bob
  7. 2007/05/20
    tiffanyc
    Image Name PID Services
    System Idle Process 0 N/A
    System 4 N/A
    smss.exe 532 N/A
    csrss.exe 596 N/A
    winlogon.exe 620 N/A
    services.exe 664 Eventlog, PlugPlay
    lsass.exe 676 PolicyAgent, ProtectedStorage, SamSs
    svchost.exe 824 DcomLaunch, TermService
    svchost.exe 884 RpcSs
    svchost.exe 976 AudioSrv, CryptSvc, Dhcp, ERSvc,
    EventSystem, helpsvc, lanmanserver,
    lanmanworkstation, Netman, Nla, RasMan,
    Schedule, seclogon, SENS, SharedAccess,
    ShellHWDetection, srservice, TapiSrv,
    Themes, TrkWks, W32Time, winmgmt, wscsvc,
    wuauserv, WZCSVC
    svchost.exe 1040 Dnscache
    svchost.exe 1112 LmHosts, SSDPSRV, WebClient
    spoolsv.exe 1336 Spooler
    explorer.exe 1608 N/A
    NvMixerTray.exe 1680 N/A
    jusched.exe 1692 N/A
    qttask.exe 1704 N/A
    avgcc.exe 1720 N/A
    ArovaxAntiSpyware.exe 1728 N/A
    msmsgs.exe 1736 N/A
    ctfmon.exe 1816 N/A
    aim6.exe 1824 N/A
    MySpaceIM.exe 1844 N/A
    aolsoftware.exe 1900 N/A
    EasyShare.exe 1908 N/A
    Kodak Software Updater.ex 1920 N/A
    guard.exe 2044 AVG Anti-Spyware Guard
    avgamsvr.exe 192 Avg7Alrt
    avgupsvc.exe 248 Avg7UpdSvc
    avgemc.exe 296 AVGEMS
    MDM.EXE 372 MDM
    wdfmgr.exe 460 UMWdf
    Ymsgr_tray.exe 1436 N/A
    svchost.exe 2200 stisvc
    alg.exe 2596 ALG
    firefox.exe 3192 N/A
    cmd.exe 3040 N/A
    cmd.exe 3160 N/A
    tasklist.exe 3324 N/A
    wmiprvse.exe 2356 N/A
  8. 2007/05/20
    tiffanyc
    the bit defender made my computer crash the first time i tried it and i have not tried again in the past 2 hours or so
  9. 2007/05/20
    bbbobins
    bbbobins Banned
    OK the tasklist agrees with all else. Good!
    Ok final cleanup.
    Cleanup all downloaded installer files on Desktop, all the txt files we created
    The following items will free memory and speed up in general (some)
    Start-run
    type or paste
    services.msc
    Maximize screen
    find
    DNS Client (will speed bootup)
    Double Click
    set Statup type to
    Disabled
    click apply then OK
    Indexing Service as previous set to disabled
    Machine Debug Manager Disabled
    Net Logon Disabled
    Uninteruptable power Supply (unless you have a UPS and it is cabled to the computer and has software installed)
    If you have no wireless then
    Wireless Zero configuration Disabled
    Next
    Download Regseeker
    http://www.hoverdesk.net/dl/en/RegSeeker.zip
    extract
    Download EasyCleaner 20
    http://personal.inet.fi/business/toniarts/files/EClea2_0.exe
    Run this file to install.
    Now run Enditall and killprocess as directed before
    Then
    start-run
    type
    cmd
    paste the following command to the run command
    "C:\Program Files\Registry Cleaners\EasyCleaner\EasyClea.exe" -delreg -delunn -ccache -chistory -ccookies -cmru -exit
    it will do a temp clean and reg clean and exit back to desktop
    Reboot
    Again un Enditall and killprocess as directed before
    Then run Regseeker
    click find in registry
    check all boxes except Match whole word
    paste
    Registrybooster
    into the Search for line
    click search
    Select and delete all found
    when finished
    click Installed Applications
    then Invalid Add/remove entries
    click Select All
    click Action
    click Delete Selected items
    next
    Click Clean the Registry
    check all blocks
    click autoclean
    in Passes put 4
    Select all square blocks including the one under Passes
    Put dot in circle all Green items
    click Go
    exit regseeker when finished
    Reboot
    Run for a few days and let us know.
    Are you still lockup free in general use?
    Good luck
    Bob
  10. 2007/05/20
    bbbobins
    bbbobins Banned
    Ok on the Bitdefender crash
    Not to worry
    But have you been using the Enditall and Killprocess before you run it?
    If not, try it that way.
    Otherwise forget it, as we have had several other (probably better) scans with positive opinions.
    Bob
  11. 2007/05/20
    tiffanyc
    i can't get enditall to run??everytime i click on it it brings me through the installations process again but then nothing?????
  12. 2007/05/20
    bbbobins
    bbbobins Banned
    Oh!
    I thought you had been running Enditall and Killprocess for all scans .
    Well you are running the install over and over. It only needs to be run once to install the program.
    Since it is already installed go to Start-programs and run it from there.
    What about Killprocess with the Killlist?
    Bob
  13. 2007/05/20
    tiffanyc
    i got everything done!! I am cleaning the regseeker registry now!!! I have not crashed at all since yesterday morning until i ran the bitfinder....It seems fine to me!!!! I am leaving tuesday for vacation to visit my family so I will not be abck until the 30!!!! I will update you as soon as i get back!!Thank you soo much!!!!!! I can't even say thanks enough!!!!!
