I need help with a virus i think
Discussion in 'Malware and Virus Removal Archive' started by tiffanyc, 2007/05/11.
  1. 2007/05/19
    bbbobins
    bbbobins Banned
    Fantastic job.
    Try to do that line again then continue to the below part.
    I will be studying these while you do the rest.
    Bob
  2. 2007/05/19
    tiffanyc
    tiffanyc Inactive Thread Starter
    sorry my mother called......
    ok i tried line 4 again and it is saying it is not recognized as an internal or external command operable program or batch file
    I am going to now continue with the rest you said to do as i await what to do about the tasklist
    tiffanyc
    ok i ran the arovax and cleaned somestuff out but 3 of the things it found it says unknown and when i went to clean it it opened a box saying this file is unknown and could cause damage to your computer sop should i clean it anyways????
    I am now moving onto the next step
  5. 2007/05/19
    bbbobins
    bbbobins Banned
    After completeing all the other steps rerun Arovax and get me the names.
    Do this before going to safe mode and testing the ones that lock up.
    And give me the names of any that the rest find that you are not sure of.
    Edit: on the Kaspersky run each of the scans with My Computer last!
    Bob
  6. 2007/05/19
    tiffanyc
    i was in the middle of running the bit defender when my computer crashed.i just got back online off to scan the arovax again
  7. 2007/05/19
    tiffanyc
    the first one just says UNKNOWN
    second UNKNOWN AIM6 c:program files\aim6\aim6.exe
    third UNKNOWN MYSPACEIM c:program files\myspace\im\myspaceim.exe
  8. 2007/05/19
    bbbobins
    bbbobins Banned
    The first unknown leave for now.
    the others are related to AOL messenger and My Space instant messenger so if you use these then leave them alone.
    if you do not use them then uninstall them in control panel Ad/Remove programs.
    did you do the tasklist that failed again and did it come up blank again?
    What other results are you having?
    Bob
  9. 2007/05/19
    tiffanyc
    sorry my cable went out for a few minutes so i got knocked off..off to get my baby to bed then ill be back to work on everything Thanks!!!
  10. 2007/05/19
    tiffanyc
    I was running the kaspersky when my computer crashed again grrrrr i'm going to try it again now
  11. 2007/05/19
    bbbobins
    bbbobins Banned
    Kaspersky has 4 different scans with the big one being My Computer.
    Which one crashed.
    If one crashes skip it and do the next kaspersky scan.
    Run what will run and continue on.
    And what about the Tasklist?
    Bob
  12. 2007/05/19
    bbbobins
    bbbobins Banned
    OK sorry I reread the last page and see where you tried the Tasklist again.
    try pasting this line
    c:\windows\system32\cmd.exe /c c:\windows\system32\tasklist.exe /svc > "%USERPROFILE% "\Desktop\Tasklist.txt
    Bob
  13. 2007/05/19
    tiffanyc
    the tasklist is still not working it is giving me the same message..
    kaspersky crashed when i tried critical areas and my computer it completed email and memory.....
  14. 2007/05/19
    bbbobins
    bbbobins Banned
    Ok
    sounds like tasklist.exe is missing
    try this to see if it is missing
    start-run
    type
    cmd
    enter
    in the command window
    type
    tasklist
    enter
    if it runs let me know
    Now
    Lets check for a Rootkt
    downlaod Catcheme
    http://www.gmer.net/catchme.exe
    run it and post back the log.
    Bob
  15. 2007/05/19
    bbbobins
    bbbobins Banned
    This is for after you have done all the above that will run.
    Download EndItAll http://www.compu-docs.com/Downloads/enditall.exe
    Run enditall click enditall bottom left corner
    close enditall
    Download and install Killprocess
    http://orangelampsoftware.com/products_killprocess.shtml
    get Killprocess 241
    On the download page is a "Download Kill lists" select that then the one that says "Clean Windows XP ". You may have to rt click this and do Save As.
    When you have it and have installed KillProcess move this file to inside the KillProcess folder. Which should be C:\Program Files\Killprocess.
    Instructions for use.
    Run KillProcess then click File-Load Kill List, browse to the KillProcess folder and choose "Clean XP.lst ".
    Then back to File, then Execute Kill list.
    Answer yes to all.
    exit Kill process
    Now try only the programs that failed. But if it locks up again and you reboot you must run Enditall and Killprocess again before trying the next program.
    Bob
  16. 2007/05/19
    tiffanyc
    ok for the tasklist same message still
    catchme scan completed everything reads 0
  17. 2007/05/19
    bbbobins
    bbbobins Banned
    OK tasklist.exe is missing.
    DL it here
    http://www.computerhope.com/download/winxp/tasklist.exe
    cut it and paste it to c:\windows\system32
    now do the original tasklist operation.
    and fill me in on the results of what you are doing.
    I think we are close.
    I am going to post the process to find and remove RegistryBooster in my next post.
    Just do what you can to follow the steps.
    Bob
    You are doing a great job. I know you must be exasperated. But sometimes it takes this kind of effort. I will stick with you untill you say UNCLE!
  18. 2007/05/19
    tiffanyc
    omg avg spyware completed the fast scan!!!!!!! only had cookies picked up i am going to try the full scan after doing your above instructions!!!!
  19. 2007/05/19
    tiffanyc
    ok i did the above....it is still giving me the same message when i paste that into the command bar
  20. 2007/05/19
    bbbobins
    bbbobins Banned
    OK
    that is a mystery that needs solving
    continue on all the rest
    but when you get time
    start-run
    type cmd
    enter
    command window opens
    type
    cd\windows\system32
    enter
    type
    dir tasklist.exe
    enter
    if it finds it
    type (or paste fron here)
    While in the command window if the above worked or not
    attrib c:\registrybooster.* > "%USERPROFILE% "\Desktop\rboost.txt
    close the command window and post the contents of rboost.txt. (should be icon on desktop).
    Bob
    I will be away for about 1 hour.
  21. 2007/05/19
    tiffanyc
    it did not find the tasklist again
    results of rboost
    File not found - C:\registrybooster.*
