Resolved I Got A Problem With My Home Group
Discussion in 'Networking (Hardware & Software)' started by SVEN, 2016/05/29.
  1. 2016/05/29
    SVEN
    SVEN Well-Known Member Thread Starter
    Hi all,
    I got a problem with my home group.
    Some background:
    4 laptops and 1 desktop
    All running windows 10
    After getting “no other computer are available” or something like that, even though all are up and running, I went to each computer and clicked on “leave the home group” and rebooted the computer.
    After they are up and running again I go to the home group setup in Control panel trying to set up a new home group, but instead I get: “you are invited to join a home group”.
    There should be no home group. When I click on join, it either takes me to the screen to input my password or on some computers it goes to: “verifying password”
    After a couple of minutes it tells me it can no longer detect the home group, but when I click on ok it takes me back to “you are invited…..
    On some computers I stopped the “verifying password” after 20 minutes or so.
    Apparently there is something leftover of the old home group and I cannot setup a new home group.
    Anyone have an idea on where to go next?
    Sven
    SVEN,
  2. 2016/05/29
    Don't use Homegroup, it has always been troublesome.
    Follow the directions at this link. It's for Windows 7 but pretty much the same for Windows 10.
    How to Network Windows 7 With Other Windows Versions. | HelpWithWindows
    The only thing I'd add is to also disable Homegroup services: Control Panel > Administrative Tools > Services > set the 2 Homegroup services to Stopped & Disabled.
    SVEN
    Thanks TonyT
    I had it going for a while, and then it stopped. probably an upgrade or something broke it.
    Question remains: why can't I set up a new group?
    Sven
    SVEN,
    SVEN
    I used the guide above to set it up and it works fine.
    Thanks TonyT
    SVEN,
    Well done!
