Resolved I.E. 10 doesn't load pages
Discussion in 'Internet Explorer & Microsoft Edge' started by Alicia J, 2013/08/27.
  1. 2013/08/30
    Alicia J Lifetime Subscription
    Alicia J Geek Member Thread Starter
    Evan I checked the intranet settings on my netbook and the default is greyed out so I think those settings are ok. Thanks again for all your help! I'm off to install I.E. 10 on my PC now.
  2. 2013/08/30
    So do you still get the error message that the intranet settings are turned off by default or has that issue been resolved?
    I have not got that message today. Is there something else I should check? Is it supposed to be greyed out?
  5. 2013/08/30
    If the Local Intranet security zone is set to the proper default level of Medium-low then you don't need to change that.
  6. 2013/08/30
    Yes it is thanks.
  7. 2013/08/30
    No Problem. :)
