How to switch to Administrator logon
Discussion in 'Windows XP' started by pilotgal8, 2007/06/24.
  1. 2007/06/24
    pilotgal8 Lifetime Subscription
    pilotgal8 Well-Known Member Thread Starter
    New computer with XP Pro which I set up with my user ID with Administrator privilages. When I try to switch to Amin user......start/logoff ...then select "switch user "....I get a screen with User and Guest only....Administrator is NOT an option.
    Ctl Panel/User options shows an Administrator ID already exists.
    So how can I logon to the Administrator ID.
  2. 2007/06/24
    surferdude2
    surferdude2 Inactive
    That's a hidden account that will be revealed when you press Ctrl+Alt+Del twice while at the logon screen. Then type Administrator for the account name and type any password you have assigned. If no password is assigned, just leave that blank and press enter.
    Further Info Here
    Same section in Control Panel > User Accounts > change the way users log on or off > uncheck Use the Welcome screen
    Start > Logoff John Doe > type Administrator as username, enter admin password if exists. Can also logon via Safe Mode.
  5. 2007/06/24
    Thnaks Tony & surferdude...I think I'll try the 'uncheck welcome screen' and see if that does what I need.
    Sure appreciate the fast response.
    Excellent board as usualy.
