How to remove Linked Inboxes.
Discussion in 'Microsoft Mail (Outlook / OE / Windows Mail)' started by BobbyScot, 2019/01/12.
  1. 2019/01/25
    BobbyScot
    Christer, what I meant was the choice "using FF and required to sign in at each BBS visit" or "not using (install) FF and not requiring to sign in to BBS at each visit". I hope this clarifies the matter.
  2. 2019/01/25
    Christer
    Christer Geek Member Staff
    Okey, if it works well in IE11 and Edge, then continue to use those browsers but I don't understand why it doesn't work in FF.
    BobbyScot
    I am baffled as you are, to be honest neither did IE11 and Edge as you have read in my earlier postings. How long the present set up last is unknown, but hope that it remains as at the present, a saying here is "the proof is in the pudding". An old childhood saying.
  5. 2019/01/25
    Have you installed any extensions in Firefox ?
  6. 2019/01/25
    Can you get a list of all the installed programs/apps that you have on your PC and put them in this thread?
  7. 2019/01/25
    Bobby, I'm afraid that after using Firefox Browser since 2004 I have never experienced the problem you keep describing.
    In my humble opinion either your OS is corrupt or you have 3rd party software that is causing the problem or you have not followed input procedures correctly.
    I'm bereft of any further ideas to help you so I will leave it to someone more knowledgeable.
  8. 2019/01/26
    BobbyScot
    At the moment with FF uninstalled, there is no conflicts with BBS, and all daily used program installed in my computer are appearing to be stabled.
  9. 2019/01/26
    Christer
    Thanks for the feedback ... :) ... and Happy Birthday!
  10. 2019/02/06
    Again I will ask this. We may be able to lead you in the right direction as to what is causing some of your problems.
  11. 2019/02/08
  12. 2019/02/08
