how to fix C00D1199?
Discussion in 'PC Hardware' started by atown, 2008/09/29.
  1. 2008/09/29
    atown
    atown Inactive Thread Starter
    so i recently had to delete everything from my computer
    and now that i add everything back
    it wont let me watch videos
    it says C00D1199
    and i ask everyone and they bring me to sites
    i dont even need.
    Can you PLEASE tell me exactly what i need
    to download?
  2. 2008/09/30
    Welcome to WindowsBBS:)
    Windows Media Player Error Message Help
    You've encountered error message C00D1199 while using Windows Media Player. The following information might help you troubleshoot the issue.
    Cannot play the file
    Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
    The file type is not supported by the Player. For a list of file types (formats) that are supported by Windows Media Player, see Supported file types.
    The file type is supported by the Player, but the file was compressed by using a codec that is not supported by the Player.
    Your sound card or sound controller is not configured properly. Try changing the audio output device associated with the Player.
    http://www.microsoft.com/windows/windowsmedia/player/webhelp/default.aspx?&id=C00D1199
