Resolved How often does an automatic restore point get created? My PC isn't doing it
Discussion in 'Windows 10' started by Alicia J, 2015/12/17.
  1. 2015/12/17
    Alicia J Lifetime Subscription
    Alicia J Geek Member Thread Starter
    How often does Windows 10 create an automatic restore point besides when you install software?
  2. 2015/12/17
    Did you Google your question;)
    They get created every few days AND or anytime you install a medium good piece of software.
    Yes and I got different answers. Mine doesn't seem to be created except when install and uninstall.
  5. 2015/12/17
    lj50 Lifetime Subscription
    lj50,
    Yes thanks the system restore is turned on and configured. It hasn't created any restore points for 7 days and only one that was not manually done since Dec 3rd. Perhaps this is normal behavior.
  7. 2015/12/17
    Hi Alicia.
    Yes this is normal behavior but you can change the interval for when Windows creates automatic restore points, Change How Often System Restore Creates Restore Points in Windows 7 or Vista.
  8. 2015/12/17
    The scheduler says it successfully completed on Dec 15th and yet when I try to look at the available restore points, it's not listed. I'm probably missing something here.
  9. 2015/12/19
    Well IMO you could always create a restore point manually if needed. I would change the interval period to something more frequent and then see if Windows creates the restore point automatically during that period. Plus, I think the computer needs to be idle during this time. If you are using the machine to do something then Windows may not create a automatic restore point during the period that you are using the machine.
  10. 2015/12/19
    And of course the restore points only backup system files.... If there hasn't been any updates to those, the system doesn't have much of a need to create the restore point.
  11. 2015/12/19
    Ok I'll do manual restore points. Thanks to all of you.
  12. 2015/12/19
    I had the same problem. I hacked the registry to create two restore points a day(24hrs.). I don't know weather or not you would want to go through the trouble of creating a reg. key.
  13. 2015/12/19
    I just checked and Windows created a restore point last night.
  14. 2015/12/19
    Great news. Thanks.
