Solved homepage keeps changing to bing.zugo.com
Discussion in 'Malware and Virus Removal Archive' started by gideon01, 2010/03/21.
  1. 2010/03/23
    gideon01
    gideon01 Inactive Thread Starter
    All processes killed
    ========== PROCESSES ==========
    ========== FILES ==========
    LoadLibrary failed for C:\Program Files\Mozilla Firefox\extensions\{b213b800-b50c-14f4-a353-7f58602f49f1}\components\--_4f_71L.dll
    C:\Program Files\Mozilla Firefox\extensions\{b213b800-b50c-14f4-a353-7f58602f49f1}\components\--_4f_71L.dll moved successfully.
    C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: home
    ->Temp folder emptied: 103096235 bytes
    ->Temporary Internet Files folder emptied: 23548770 bytes
    ->Java cache emptied: 1193618 bytes
    ->FireFox cache emptied: 77323019 bytes
    ->Flash cache emptied: 8903 bytes
    User: LocalService
    User: NetworkService
    Windows Temp folder emptied: 2674003 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 198.00 mb
    OTM by OldTimer - Version 3.1.10.1 log created on 03232010_150042
    Files moved on Reboot...
  2. 2010/03/23
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Disable TeaTimer, as it'll interfere with the cleaning process:
    Right click Spybot's TeaTimer System Tray Icon.
    Click Exit Spybot-S&D Resident.
    TeaTimer closes.
    NOTE. If on re-boot, Spybot inquires about registry change(s), allow it.
    Alternatively, I suggest, you uninstall Spybot since it's a tool of the past.
    Print this post out, since you won't have an access to it, at some point.
    1. Open HijackThis.
    2. Close all windows, except for HijackThis.
    3. Put checkmarks next to the following HijackThis entries:
    O2 - BHO: TBSB05974 - {FCBCCB87-9224-4B8D-B117-F56D924BEB18} - C:\Program Files\Search Toolbar\tbcore3.dll (file missing)
    4. You should also checkmark following entries (these are unnecessary startups; no actual programs will be removed):
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe "
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\RunOnce: [Uninstall Adobe Download Manager] "C:\WINDOWS\system32\rundll32.exe" "C:\Program Files\NOS\bin\getPlus_Helper.dll ",Uninstall /IE2883E8F-472F-4fb0-9522-AC9BF37916A7 /Get1noarp
    5. Click on Fix checked button.
    6. Restart computer.
    When done...
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
    gideon01
    thanks again for all your help and very fast responces.
  5. 2010/03/23
    You're very welcome :)
