Solved Hkey registry issues
Discussion in 'Malware and Virus Removal Archive' started by langsa, 2010/06/28.
  1. 2010/07/04
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
    5. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
  2. 2010/07/04
    langsa
    langsa Inactive Thread Starter
    Well, it's a good thing I did the system restore before I installed ZoneAlarm and SpywareBlaster. During the installation of ZoneAlarm, my computer crashed and did its pixelated screen routine. I tried to restart, and got a BSOD each time. So I used System Restore, and it stopped.
    Now you wait...
    I hope, you used the newest restore point, you created following steps from my previous reply??
  5. 2010/07/04
    langsa
    The only difference is that I had no previous restore points to delete. So I just created a new one, as you asked.
  6. 2010/07/04
    I see. You're safe then.
    Is computer doing fine otherwise?
  7. 2010/07/04
    langsa
    For now. I still want to know what causes that pixelated screen crash, though. >.>
  8. 2010/07/04
    All I care, your computer is clean and doing fine :)
    Don't investigate old issues, if they're not there anymore.
    Good luck and stay safe :)
