hijacked homepage
Discussion in 'Malware and Virus Removal Archive' started by ugostar, 2004/10/22.
  1. 2004/11/06
    Lonny Jones
    Lonny Jones Inactive Alumni
    Hi
    We have a couple Ideas, Killbox again with some added instructions.
    Close all browsers
    Start Killbox.exe, Select the
    [x]Delete on reboot option.
    Copy and paste the line below in the field labeled "Full path of file to delete"
    C:\Windows\system32\TGBRFV_5.dll
    Then press the button that looks like a red circle with a white X in it.
    When it asks if you would like to Reboot now, press the NO button.
    C:\WINDOWS\System32\TGBRFV_.exe
    When it asks if you would like to Reboot now, press the No button.
    Open this folder and delete then entire contents
    C:\WINDOWS\Prefetch
    Go start run type in
    %temp%
    and hit enter, again delete the entire contents of that temp.
    Go start run type
    temp
    hit enter, delete the entire contents again
    Clear Internet Explorers's cache via control panel internet options [delete files] button and mark the popup to also [x]delete offline content, history to.
    Now restart your computer
    If there are still problems you could try Kaspersky Anti-Virus trial, thats who made the reporting tool you used mwav.exe
    http://www.kaspersky.com/trials
    If this is a viable solution for you, first download it disconnect from the internet and uninstall your current AV program. fallow the promts, it will have you restart most likely. then install that trial, update it, then do a full system scan while in safe mode, you can always uninstall it and re-install your av program later.
    I see a varient of this nastie at several forums where even the leaders in the antispyware community are having a time with it, Usualy the killbox rutine works fine.
    CastleCops Grinler »tgbrfv_5=dll: http://castlecops.com/posts83534-0.html
    TonyKlein and TGBRFV_:
    http://castlecops.com/modules.php?name=Forums&file=viewtopic&p=358267#358267
    slightly differant varient
    LoPhatPhuud -Tgbrfv_: http://castlecops.com/modules.php?name=Forums&file=viewtopic&p=358124#358124
    PS do not use findNfix
  2. 2004/11/06
    ugostar
    ugostar Inactive Thread Starter
    Bingo
    Done Thank you I did exactly as you said in the last post deleted all those files then rebooted and bingo. I did a HJT Log and that F2 was still there I checked it rescaned and it was gone here is that log
    I did a adaware scan and the 2 criticals I always got are also gone.
    Logfile of HijackThis v1.98.2
    Scan saved at 11:50:27 AM, on 7/11/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\WINDOWS\System32\S24EvMon.exe
    C:\WINDOWS\system32\ZCfgSvc.exe
    C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    C:\WINDOWS\System32\DVDRAMSV.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
    C:\WINDOWS\System32\1XConfig.exe
    C:\WINDOWS\System32\RegSrvc.exe
    C:\Program Files\TOSHIBA\TME3\Tmesrv31.exe
    C:\Program Files\Trend Micro\Internet Security\Tmntsrv.exe
    C:\Program Files\Trend Micro\Internet Security\tmproxy.exe
    C:\WINDOWS\System32\00THotkey.exe
    C:\WINDOWS\System32\hkcmd.exe
    C:\Program Files\SigmaTel\SigmaTel AC97 Audio Drivers\stacmon.exe
    C:\Program Files\Apoint2K\Apoint.exe
    C:\WINDOWS\System32\TFNF5.exe
    C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
    C:\WINDOWS\System32\TPSMain.exe
    C:\Program Files\TOSHIBA\TME3\TMEEJME.EXE
    C:\Program Files\TOSHIBA\TME3\TMERzCtl.EXE
    C:\WINDOWS\system32\dla\tfswctrl.exe
    C:\Program Files\TOSHIBA\TouchED\TouchED.Exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\WINDOWS\System32\TPSBattM.exe
    C:\Program Files\Trend Micro\Internet Security\PccPfw.exe
    C:\Program Files\Trend Micro\Internet Security\pccguide.exe
    C:\Program Files\Trend Micro\Internet Security\PCClient.exe
    C:\Program Files\Trend Micro\Internet Security\TMOAgent.exe
    C:\WINDOWS\System32\ctfmon.exe
    C:\Program Files\Apoint2K\Apntex.exe
    C:\WINDOWS\system32\RAMASST.exe
    C:\Program Files\Microsoft Office\Office10\EXCEL.EXE
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    C:\Documents and Settings\justin\My Documents\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.iinet.net.au
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer provided by iiNet
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O4 - HKLM\..\Run: [00THotkey] C:\WINDOWS\System32\00THotkey.exe
    O4 - HKLM\..\Run: [000StTHK] 000StTHK.exe
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\System32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\System32\hkcmd.exe
    O4 - HKLM\..\Run: [SigmaTel StacMon] C:\Program Files\SigmaTel\SigmaTel AC97 Audio Drivers\stacmon.exe
    O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
    O4 - HKLM\..\Run: [TFNF5] TFNF5.exe
    O4 - HKLM\..\Run: [SmoothView] C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
    O4 - HKLM\..\Run: [TPSMain] TPSMain.exe
    O4 - HKLM\..\Run: [TMESRV.EXE] C:\Program Files\TOSHIBA\TME3\TMESRV31.EXE /Logon
    O4 - HKLM\..\Run: [TMERzCtl.EXE] C:\Program Files\TOSHIBA\TME3\TMERzCtl.EXE /Service
    O4 - HKLM\..\Run: [dla] C:\WINDOWS\system32\dla\tfswctrl.exe
    O4 - HKLM\..\Run: [TouchED] C:\Program Files\TOSHIBA\TouchED\TouchED.Exe
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [PRONoMgr.exe] c:\Program Files\Intel\PROSetWireless\NCS\PROSet\PRONoMgr.exe
    O4 - HKLM\..\Run: [pccguide.exe] "C:\Program Files\Trend Micro\Internet Security\pccguide.exe "
    O4 - HKLM\..\Run: [PCClient.exe] "C:\Program Files\Trend Micro\Internet Security\PCClient.exe "
    O4 - HKLM\..\Run: [TM Outbreak Agent] "C:\Program Files\Trend Micro\Internet Security\TMOAgent.exe" /run
    O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\System32\ctfmon.exe
    O4 - Global Startup: Microsoft Office OneNote 2003 Quick Launch.lnk = C:\Program Files\Microsoft Office\OFFICE11\ONENOTEM.EXE
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
    O4 - Global Startup: RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file)
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file)
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
    O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
    O14 - IERESET.INF: START_PAGE_URL=http://www.iinet.net.au
    O17 - HKLM\System\CCS\Services\Tcpip\..\{799F4E01-C5D9-454F-BD40-BC3EFEAA5FE3}: NameServer = 203.0.178.191
    Thank you once again Lonney for your patience and persistance I will post another log in a few days time as a check up Thank You
    Lonny Jones
    Thats good news
    You should also delete the temp folder contents of all the other users
    as in. Open C:\ then >
    C:\documents and settings\(all your pc users)\local settings\temp
    And Purge all the old system restore point's
    Reset and Re-enable your System Restore to remove bad files that have been backed up by Windows. The files in System Restore are protected to prevent any programs changing those files. This is the only way to clean these files: (You will lose all previous restore points which are likely to be infected)
    Turn off System Restore.
    On the Desktop, right-click My Computer.
    Click Properties.
    Click the System Restore tab.
    Check Turn off System Restore.
    Click Apply, and then click OK.
    Then Reboot.
    Turn ON System Restore.
    Click Properties.
    UN-Check Turn off System Restore.
    check the C:\!Submit folder and tell us whats in there please
  5. 2004/11/07
    ugostar
    Hi Lonney
    I deleted temp files for all users I did the system restore point thing checked the submit file and there was TGBRFV 5 dll listed so I deleted it straight away did the restore thing again seems ok will post in a week or so
    Thank you
