Help!
Discussion in 'Windows XP' started by Petar, 2023/12/09.
  1. 2023/12/09
    Petar
    Petar New Member Thread Starter
    Hello so i have a problem when i loš di the explorer it doesnt open anything. Its not running in proceses and whne i open it trough taskmgr it just opens file explorer instead OF the desktop.
  2. 2023/12/10
    Hi Petar, Welcome to WindowsBBS. :)
    You need to give us more info.eg. What Windows version are you using?
    You've put your Thread in Windows XP Forum and as I have been using W11 Home and Pro 64bit since October 2021.
    I have one comp still running W10 Pro 64bit. The process to open Explorer in these Windows versions is Right click on Start button and Left click on File Explorer.
    I truly cannot help you if it's XP as that has been dead and buried for me for some years now.
    Someone else may read your Thread and be able to help you.;)
    Hi,
    Can you describe your issue in more detail? Are you referring to Windows Explorer?
    Also please enter your System Details. It helps us in answering your questions, thanks.
