Help with java jre
Discussion in 'Other PC Software' started by Imanoobatthis, 2009/12/21.
  1. 2009/12/22
    Imanoobatthis
    Imanoobatthis Inactive Thread Starter
    i did deleted it a while back. now that i have it reinstalled i cant find it. but the java jre also doesn't work.
  2. 2009/12/22
    Imanoobatthis
    Imanoobatthis
    ok foloing a part of the second link above me theres the part where you make a shortcut to find out the file name. I found the name and my java is supposed to be in program files. Not program filesx86 so i moved and now the link in control panel works =) im getting there. im testing now
  5. 2009/12/22
    I cross my fingers :)
  6. 2009/12/22
    Imanoobatthis
    ehh still not working, all i really did was move files from one spot to another which made the java in the control panel work. so i can access the java control panel but i cant use jre. even though its working and enabled..... >=/ lol
  7. 2009/12/22
    Imanoobatthis
    Now when i try to verify it on java. The box doesn't say install missing plugins... its just a white box
  8. 2009/12/22
    Imanoobatthis
    hate to say, but im backing up all my files and flushing my computer. Need to work and i cant work without java haha. Thanks for help everyone
  9. 2009/12/22
    Good luck :)
