Help with java jre
Discussion in 'Other PC Software' started by Imanoobatthis, 2009/12/21.
  1. 2009/12/22
    Imanoobatthis
    Imanoobatthis Inactive Thread Starter
    Google chrome. always worked before even though its not supported. That may be a problem which im looking in to now.
  2. 2009/12/22
    See, if same thing happens in Firefox and IE.
    Imanoobatthis
    nope no luck. I checked internet options and all ActiveX and java scripting is enabled. No I am really lost.
  5. 2009/12/22
    What exactly happens?
  6. 2009/12/22
    Imanoobatthis
    I get a yellow box and it tells me to install missing plugins, and tells me i don't have java installed. Though i do and have it enabled
  7. 2009/12/22
    Is it at Java test site?
  8. 2009/12/22
    Imanoobatthis
    yes it is and other sites that need java
  9. 2009/12/22
    I'm at loss. Tried Firefox?
  10. 2009/12/22
    Imanoobatthis
    yup same as ie and chrome =/ im going to goto sleep its 2am where i live. maybe someone has had my problem and fixed it and can tell me how. thx a lot for your help. installing was my bigger problem so yeah =)
  11. 2009/12/22
    Sure thing :)
    Good Night...
  12. 2009/12/22
    pccarehimanshu
    pccarehimanshu Inactive
    Simply try to rename the file
    If failed
    open Task Manager and End Tree any Java process and then try to rename it
    best oF luck
  13. 2009/12/22
    Imanoobatthis
    what file would i rename? Also ending process tree would do nothing because its not on for some reason
  14. 2009/12/22
    Imanoobatthis
    So now i have my java jre and jdk installed. But now i can't seem to get them to work in any browser. I need to find a way to turn java on. In my actions center java use to be there now it isn't my feeling is that it is just not on, or maybe being blocked. If anyone has any ideas, i'm sure its not a difficult problem to fix.
  15. 2009/12/22
    What do you need JDK for?
  16. 2009/12/22
    Imanoobatthis
    i dont know i thought installing it would help, but it didn't. I have a java file in my control panel/programs location and when i click on it it says... Explorer.exe on the top then in the box it says "application not found" i'm am sure that does not belong there and maybe that is the problem
  17. 2009/12/22
    JDK is for developers only, so you definitely don't need it.
    That icon in Control Panel may be the old icon, you had before we started this whole thread.
    At some point, I asked you to search the computer for java.cpl file and delete it, if found. did you do it?
  18. 2009/12/22
    Imanoobatthis
    yeah i did
  19. 2009/12/22
    For now, I'm out of ideas.
    Let's wait for some fresh minds :)
  20. 2009/12/22
    Imanoobatthis
    i thought that this java icon in my control panel didn't belong so i looked up how to get rid of it, i went here -- http://java.com/en/download/help/regkey_addremove.xml
    In here i read everything followed the steps to where i am at. I'm in the uninstall folder looking for Display name With the data java or anything java related. So far i have had no luck finding it.
  21. 2009/12/22
    So, you actually didn't search for java.cpl file?
