help on spyware win98
Discussion in 'Malware and Virus Removal Archive' started by johngkerr, 2007/12/27.
  1. 2008/02/04
    johngkerr
    johngkerr Inactive Thread Starter
    did some good
    removing the files in the temp dir did alot.
    it stopped the popups and the red X in toolbar
    but i sill can not run regedit
    also i try to remove beem.ddl for the startup using msconfig
    and a this popup came up [Spybot-SD Resident 1172 Processes Blacklisted]
    there is a icon on the toolbar that the popup came from.
    can spybot be running and stopping changes to the reg:confused:
    was also able the run dr web but was taking to long i had to go so i will get
    the log later. i will email the system.dat and user.dat
  2. 2008/02/05
    noahdfear
    noahdfear Inactive
    Run HijackThis again and fix the following entries.
    O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1
    O7 - HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1
    See if the registry editor will open then.
    johngkerr
    can't change registry
    I think this is the problem with the locked registry. See link below
    http://forums.spybot.info/showthread.php?t=44
    this is a old thread but i bet the tea timer popup is bad. He has a old copy of
    spybot.
    It will be friday before I can is if this is the problem:rolleyes:
  5. 2008/02/05
    noahdfear
    noahdfear Inactive
    Not one of the logs you posted showed TeaTimer as an active process. Did you enable it? If not active, it can't interfere. In any event, TeaTimer does not disable editing the registry ....... the infection present does.
    You mentioned beem.dll ....... where is it located? You said you tried removing it from the startup using msconfig, but I don't see it in the HijackThis log either. Is this a new entry, or one that HijackThis just didn't show? Is there a location of that file given?
  6. 2008/02/06
    johngkerr
    beem.dll
    beem.dll has been removed by spyware programs but there is call for it in startup. I was unchecking it in msconfig startup to stop error message at startup. and spybot did stop me but the popup you can not read like in the thread. I do not think that spybot is the reason i can not run regedit. when i get back over there i will stop tea timer and see if it helps.
    by the way the person that owns the computer dosen't know anything about
    computers and likes to play.
  7. 2008/02/08
    johngkerr
    Good News
    I things are better know. I turned off tea timer and unistalled old ver spybot.
    This let me remove thinks from startup using msconfig also let hijackthis fix that regedit problem, i can run regedit now.
    this is the last hijackthis scan log
    I know there is more to fix but my freinds computer is get over it's sickness:D
    Let me know what i should fix on the scan, Thanks you all for your help:D
    C:\WINDOWS\SYSTEM\USBMMKBD.EXE
    C:\WINDOWS\SYSTEM\STIMON.EXE
    C:\WINDOWS\RunDLL.exe
    C:\PROGRAM FILES\COMMON FILES\MICROSOFT SHARED\WORKS SHARED\WKCALREM.EXE
    C:\WINDOWS\DESKTOP\MY SOFTWARE\MOUSEWARE\SYSTEM\EM_EXEC.EXE
    C:\WINDOWS\SYSTEM\WMIEXE.EXE
    C:\PROGRAM FILES\NETROPA\ONE-TOUCH MULTIMEDIA KEYBOARD\KEYBDMGR.EXE
    C:\PROGRAM FILES\NETROPA\ONSCREEN DISPLAY\OSD.EXE
    C:\PROGRAM FILES\NETROPA\ONE-TOUCH MULTIMEDIA KEYBOARD\MMUSBKB2.EXE
    C:\PROGRAM FILES\TREND MICRO\HIJACKTHIS\HIJACKTHIS.EXE
    C:\WINDOWS\SYSTEM\WBEM\WINMGMT.EXE
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.yahoo.com/p/hp/us/?http://hp.yahoo.com
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = www.yahoo.com
    O2 - BHO: (no name) - {CC9BC69C-F035-46bc-A67B-353B8BAE61CD} - (no file)
    O2 - BHO: (no name) - {B3B010A1-A877-4CD7-BAB5-9EE8F9965E20} - (no file)
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX
    O4 - HKLM\..\Run: [TaskMonitor] c:\windows\taskmon.exe
    O4 - HKLM\..\Run: [TCASUTIEXE] TCAUDIAG.EXE -off
    O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
    O4 - HKLM\..\Run: [AtiKey] Atitask.exe
    O4 - HKLM\..\Run: [InstallAurealDemos] C:\windows\temp\InstallAurealDemos.js //b
    O4 - HKLM\..\Run: [HPScanPatch] C:\WINDOWS\SYSTEM\HPScanFix.exe
    O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
    O4 - HKLM\..\Run: [Keyboard Manager] C:\Program Files\Netropa\One-touch Multimedia Keyboard\MMKeybd.exe
    O4 - HKLM\..\Run: [USBMMKBD] usbmmkbd.exe
    O4 - HKLM\..\Run: [AtiCwd32] Aticwd32.exe
    O4 - HKLM\..\Run: [Logitech Utility] LOGI_MWX.EXE
    O4 - HKLM\..\Run: [StillImageMonitor] C:\WINDOWS\SYSTEM\STIMON.EXE
    O4 - HKLM\..\Run: [ScanRegistry] c:\windows\scanregw.exe /autorun
    O4 - HKLM\..\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
    O4 - HKLM\..\Run: [System Helper] syshlp.exe
    O4 - HKLM\..\RunServices: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
    O4 - HKLM\..\RunServices: [SchedulingAgent] mstask.exe
    O4 - HKLM\..\RunServices: [Hidserv] Hidserv.exe run
    O4 - HKLM\..\RunServices: [AolFix] C:\windows\system\AolFix.exe
    O4 - HKLM\..\RunServices: [KB891711] c:\windows\SYSTEM\KB891711\KB891711.EXE
    O4 - HKLM\..\RunServices: [KB918547] C:\WINDOWS\SYSTEM\KB918547\KB918547.EXE
    O4 - HKCU\..\Run: [MoneyAgent] "C:\Program Files\Microsoft Money\System\Money Express.exe "
    O4 - HKCU\..\Run: [Taskbar Display Controls] RunDLL deskcp16.dll,QUICKRES_RUNDLLENTRY
    O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\PROGRAM FILES\SUPERANTISPYWARE\SUPERANTISPYWARE.EXE
    O4 - HKUS\.DEFAULT\..\Run: [MoneyAgent] "C:\Program Files\Microsoft Money\System\Money Express.exe" (User 'Default user')
    O4 - HKUS\.DEFAULT\..\Run: [Taskbar Display Controls] RunDLL deskcp16.dll,QUICKRES_RUNDLLENTRY (User 'Default user')
    O4 - HKUS\.DEFAULT\..\Run: [SUPERAntiSpyware] C:\PROGRAM FILES\SUPERANTISPYWARE\SUPERANTISPYWARE.EXE (User 'Default user')
    O4 - .DEFAULT Startup: Microsoft Works Calendar Reminders.lnk = C:\Program Files\Common Files\Microsoft Shared\Works Shared\wkcalrem.exe (User 'Default user')
    O4 - .DEFAULT Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE (User 'Default user')
    O4 - Startup: Microsoft Works Calendar Reminders.lnk = C:\Program Files\Common Files\Microsoft Shared\Works Shared\wkcalrem.exe
    O4 - Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
    O9 - Extra button: RealGuide - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\SYSTEM\Shdocvw.dll
    O12 - Plugin for .pdf: C:\PROGRA~1\INTERN~1\PLUGINS\nppdf32.dll
    O12 - Plugin for .spop: C:\PROGRA~1\INTERN~1\Plugins\NPDocBox.dll
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} (Update Class) -
    O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
    O20 - Winlogon Notify: !SASWinLogon - C:\WINDOWS\
    O22 - SharedTaskScheduler: Windows Installer Class - {24E31EA9-FCE2-404F-BD80-20543565D946} - (no file)
    End of file - 4967 bytes
  8. 2008/02/10
    noahdfear
    noahdfear Inactive
    Fix the following with HijackThis, then post a new log.
  9. 2008/02/11
    johngkerr
    ok to fix
    is it ok to fix this so main window will say the page you are at. fixing with hijackthis will that make it defalt?
  10. 2008/02/12
    noahdfear
    noahdfear Inactive
    Fixing that entry should reset the window title to 'Microsoft Internet Explorer'.
    How's the computer doing now?
