Resolved HDDs became corrupted after low CMOS battery
Discussion in 'Windows XP' started by Barry, 2013/10/05.
  1. 2013/10/16
    Barry
    Tony, before I do this, does it matter if the drive is jumpered to CS, primary or slave?
    Jumpers are ignored when using such an adapter. Don't have its usb cable connected when you boot your computer. Besides, you won't be able to boot an XP drive that came from another computer without errors.
  2. 2013/10/16
    Barry
    That's interesting. Your response came up on my post. I'll follow your instructions now.
    Barry
    It works. I don't have Maya installed on my computer, so I can't view the files, but they are there. I can see the photos. I'll transfer everything over to my drive and then do the other drive, before addressing his actual computer. Thanks.
  5. 2013/10/16
    Barry
    OK, I've copied both drives, and there doesn't appear to be anything wrong with them. I have these two drives plus the smaller drive I installed XP on. Let me know which one or ones to put in his computer and then what steps to take. I was never able to fully reinstall XP on his primary Seagate drive, so that one doesn't have a workable operating system.
  6. 2013/10/16
    Barry
    By the way, his computer has a floppy drive and USB ports for my flash drive, along with his CDROM, if those would be helpful.
  7. 2013/10/16
    Good work!
    Now, the drive you put XP on, was that done while it was connected to his computer? If so, set that drive as Master and install it in his comp, don't connect the other drive yet.
    I strongly suggest a clean install, meaning boot from the XP CD, delete the existing partitions, create a new partition and install XP newly. Then reinstall all 3rd party software.
    When finished, shut down, install the other drive as a slave to be used for whatever, e.g. backups, data storage, multimedia, etc. If that drive has a failed XP install on it then copy data to the other drive temporarily, format the drive & move the data back. (don't copy operating system files, just copy needed & wanted files) You can actually format the Seagate on your comp while connected by that adapter.
    On XP installs with 2 drive I always move My Documents to the second drive, that way if the operating system drive fails the data is intact on the other drive.
  8. 2013/10/16
    Barry
    I continue to get "Non-System disk or disk error" when I attempt to access any drive or CDROM. The backup with the OS didn’t show up in the bios, so I was stuck with working with the primary without an OS. I finally got it to boot to the CDROM and attempted to install XP. Unfortunately, that resulted in the same BSOD that brought me here originally: ***STOP: 0X0000007B (0XF789E640, 0XC0000034, 0X00000000, 0X00000000) Something doesn’t mesh anymore since the CMOS checksum error, even though I replaced the battery. I’m wondering if I need to run some tests on the mobo to see if that or the RAM has been affected somehow. What do I do now?
  9. 2013/10/17
    Barry
    Tony, I don't think you would have ever guessed what my problem is, but I think I have finally found it. Strange as it may seem, the "\" key on his keyboard was jammed down. Things seem to work fine, once I took a knife to it and put it back where it is supposed to be. I have no idea how or when that might have happened, but I am able to start up the computer on his backup drive. Tomorrow, I'll hopefully reinstall XP on his primary drive and see if everything works well together. I'll keep you informed, but I'm hoping that was the only problem. The BSOD is a hardware code, and the keyboard is a piece of hardware. Let's keep our fingers crossed that this is it. Maybe you can explain to me how this could have happened.
  10. 2013/10/17
    That's a very rare find!
    Perhaps some food or dirt got in there. I've seen some sticky keyboards over the years. Keep us informed...
  11. 2013/10/17
    Barry
    I was too optimistic. Apparently, I did something while the key was jammed that prevents the boot from directing to the right place. I think it continues to direct it to the small drive I removed, and it won't allow me to change directions. I went into recovery console and did fixmbr and bootcfg /rebuild. It notices all the operating system partitions, yet I can't seem to get it to direct correctly to allow for the full installation of XP. It only works till the first restart, and then I get the BSOD, again. What now?
  12. 2013/10/17
    Boot to the bios and look for a setting re AHCI and set it to IDE. If cannot find such a setting, set the bios to its defaults & exit. Boot again to bios and set to boot from CDROM first.
    Only put one drive in the comp and make sure it's set as master. When booting from the xp cd, delete all existing partitions on the drive, create a new partition and then proceed with the installation.
  13. 2013/10/17
    Barry
    There is no ACHI for my AMD system. Sometimes the bios detects the hard drive and sometimes it doesn't, but I'm getting the message of "Non-System disk or disk error" again. When I do get into the recovery console and fixmbr, it just jumps to the next prompt and doesn't seem to do anything.
    OK, I was able to start the install again, after I went into recovery console and designated a default boot (bootcfg /default). Unfortunately, when the computer restarted, after following your instructions, the old boot window appeared, and that doesn't allow me to choose before opening a Windows that always leads to the BSOD. What now?
  14. 2013/10/17
    Barry
    OK, this time I deleted and reinstalled and formatted my first 2 partitions on the drive, and it appears to be loading XP properly. I'll report back after XP is fully installed.
  15. 2013/10/17
    Barry
    It's perfect. No more problems and no loss of any files. Thanks for your help.
  16. 2013/10/17
    You're welcome, and very well done!
  17. 2013/10/17
    Barry
    I was never crazy about his keyboard, but he liked it, as it matched his blue case. Thanks again.
