Hard Drives , SATA and SATA 2
Discussion in 'PC Hardware' started by TerryFox, 2008/06/21.
  1. 2008/07/07
    chas berlin
    chas berlin Inactive
    I feel better knowing it's not as big a difference as I had thought. :)
    I'm now considering a 250 GB drive, that is slower than the 750 GB, for my OS.
    But again, I'm still in the throws of what to do, as this gets back to the partitions vs 2 drives question. :confused:
  2. 2008/07/07
    chas berlin
    Pete, BTW, The 750 GB has a 32 MG cache and is SATA NCQ (don't know what this is), and the 250 GB has a 16 MG cache and is SATA 3.0 G/b's.
    From what you just said I assume there is little difference between the two?
    I expect the larger cache will produce the most gains though.
    Of course these will both be limited by my SATA 1 motherboard. :(
    Christer, thx for pointing out my error.
    I really wasn't reading it right, now was I? :eek:
    SATA NCQ - Native Command Queuing - note it can actually slow the drive down due to increased latency.
    The most important software on a computer is the OS which is constantly in use once booted up. Although you are limited to SATA 1 in your board (check that the drive is backwards compatible - some have jumpers to set SATA 1) I would go for the increased cache as this is operational regardless of the interface. Are the spindle speeds both the same - faster is better for access, may be not so good for longevity :)
  5. 2008/07/07
    Christer
    Christer Geek Member Staff
    chas,
    I wasn't pointing any fingers, it was an honest question. SATA-3 (or whatever the professionals want us to call it) has been advertized but to the best of my knowledge, has not been released. I could be wrong, hence the question.
    Christer
  6. 2008/07/07
    chas berlin
    Can this be turned off, so as not to slow things down?
    I don't have a clue about the compatibility.
    For the record, I used to build machines as a sideline, but when it comes to software and such, I'm pretty lame.
    The drives are both 7200. I can't find anything that says yea or nay.
    Here's a link http://www.seagate.com/ww/v/index.j...0f43110VgnVCM100000f5ee0a0aRCRD&reqPage=Model
    can you tell if it's backward compatible?
  7. 2008/07/07
    chas berlin
    Christer, I didn't take it as anything more than an sincere question.
    Since I'm not knowledgeable, or up to date, in this arena I could easily be wrong.
  8. 2008/07/08
    From the Support > Installation tab in the URL ypu posted ....
    Re. NCQ I don't know, but we are talking milliseconds here.
  9. 2008/07/08
    chas berlin
    OK, here it comes...
    I assume I want to force SATA 150MB/s? :confused:
    OK it was obvious but, lower your gun, pls.
    Ooops, I forgot you're not American, so you're not carrying one!
  10. 2008/07/08
    chas berlin
    Pete, I just looked at the tab you referenced.
    I had no idea it had info on it. Thought it was just a support number. :eek:
  11. 2008/07/08
    Rockster2U
    Rockster2U Geek Member
    A couple of comments.
    Yes, there are distinct differences between PATA, SATA I and SATA II drives - look at all the previous posts and the way speed can be quantified. However, it's time for a reality check. Assuming similar platter speeds and caches, most of us would be very hard pressed to recognize any differences in speed or performance between them unless benchmarking software is used.
    Yes, SATA II drives are supposed to be backwards compatable to SATA I. As has been stated, some SATA II drives can be jumpered to force SATA I. However, not all SATA I motherboards will recognize a SATA II drive. I hope this issue is behind us in 2008 but just for the record, there are exceptions.
  12. 2008/07/08
    chas berlin
    Yeow!
    Now you're scaring me. :eek:
    I guess I'll find out tomorrow.
