Resolved GPU problems NV4_disp.dll plus 0x0000008E
Discussion in 'Windows XP' started by nevross, 2010/08/04.
  1. 2010/08/21
  2. 2010/08/22
    nevross
    nevross Inactive Thread Starter
    Actually the problem is not resolved. I was merely testing another card to prove that its probably not the windows software. I still need to resolve the problem relating to the 470gtx card.
    Problem with your card then. If the card is under warranty, demand a replacement.
  5. 2010/09/07
    nevross
    Sorry I thought I had replied. card has been replaced, no difference. Done everything even changed the memory not change.
  6. 2010/09/07
    Power supply ? Can you swap it to test it ?
  7. 2010/09/08
    nevross
    Good thought, but I have already tried that. Very weird problem....
  8. 2010/09/09
    Two (ultimate) suggestions:
    1. Reformat & reinstall Windows. If you then still get the same problem that leaves you with
    2. Choose another video card
  9. 2010/09/09
    nevross
    I have done the former. Clean Windows install and then the Nvidia drivers only.
    I think your suggestion of another card is apt.....
  10. 2010/09/16
    nevross
    Many thanks for all the help & suggestions. I think I have found the solution. I have a Gigabyte motherboard and when it was installed one of the utils was an energy saver. I was unaware this had installed. I suspect that because my GPU is quite power hungry & this enegy saver software is not working properly it reduces the energy at the wrong time. A lesser GPU doesn't have the same problem as it doesn't need as much power. Doen't explain why Windows 7 is not so sensitive, but time will tell. Better now I have uninstalled the E/save.
  11. 2010/09/16
    Thanks for posting back.
    Who would have thought that a little utility would turn out to be a show stopper :eek:
    In fact most of us would not have even looked/asked for it. How embarrassing.
  12. 2010/09/17
    Definitely firs time I have heard of this, something to keep in mind :eek:
