Inactive Google Redirect and Audio/Internet Connection randomly Stopping
Discussion in 'Malware and Virus Removal Archive' started by wealthymike, 2010/09/25.
  1. 2010/09/26
    Update your Java version: http://java.com/en/download/index.jsp
    Now, we need to remove old Java installations...
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    I'm not sure, if you're aware, that you have Actual Keylogger (http://www.fatwallet.com/redirect/b...m/securityadvisor/pest/pest.aspx?id=453097488) installed on your computer:
    We're about to remove it.
    I strongly suggest, you change all your passwords.
    Run OTL
      :OTL
      PRC - [2005/07/08 21:55:20 | 000,522,752 | ---- | M] (Actual Spy Software) -- C:\Program Files\AKProg\AKProg.exe
      MOD - [2005/07/07 22:22:20 | 000,018,944 | ---- | M] () -- C:\Program Files\AKProg\hkdll.dll
      MOD - [2005/06/17 12:48:56 | 000,020,480 | ---- | M] () -- C:\Program Files\AKProg\hprog.dll
      O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Main present
      O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
      O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
      O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
      [6 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
      [1 C:\WINDOWS\System32\drivers\*.tmp files -> C:\WINDOWS\System32\drivers\*.tmp -> ]
      [1 C:\Documents and Settings\Sampson\Desktop\*.tmp files -> C:\Documents and Settings\Sampson\Desktop\*.tmp -> ]
      [2010/09/25 22:56:48 | 000,000,718 | ---- | M] () -- C:\WINDOWS\System\akstart.lnk
      [2010/09/17 13:25:04 | 000,000,788 | -HS- | C] () -- C:\WINDOWS\System\actualspystart.lnk
      [2010/04/16 21:42:01 | 000,005,396 | -HS- | C] () -- C:\Documents and Settings\Sampson\Local Settings\Application Data\1508699692
      [2010/04/16 21:42:01 | 000,005,396 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\1508699692
      [2010/04/14 06:19:30 | 000,001,164 | -HS- | C] () -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Fm8hV5
      [2010/04/14 06:19:30 | 000,001,164 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\Fm8hV5
      [2010/04/10 12:48:46 | 000,016,488 | -HS- | C] () -- C:\Documents and Settings\Sampson\Local Settings\Application Data\Sn5p4E4Q
      [2010/04/10 07:47:04 | 000,016,508 | -HS- | C] () -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Sn5p4E4Q
      [2010/04/10 07:47:04 | 000,016,488 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\Sn5p4E4Q
      [2010/01/10 08:00:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SecTaskMan
      @Alternate Data Stream - 103 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Last scans....
    Download Security Check from HERE, and save it to your Desktop.
    * Double-click SecurityCheck.exe
    * Follow the onscreen instructions inside of the black box.
    * A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    Download Temp File Cleaner (TFC)
    Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • IMPORTANT! UN-check Remove found threats
    • Click Start
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Click on Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  2. 2010/09/30
    Are you still out there?
