Solved Generic Host Process for Win32 has encountered a problem
Discussion in 'Malware and Virus Removal Archive' started by biggazdixon, 2011/05/01.
  1. 2011/05/03
    biggazdixon
    biggazdixon Well-Known Member Thread Starter
    Good morning.
    Today I can see a log on my desktop from Rkill that I never saw yesterday.
    This log file is located at C:\rkill.log.
    Please post this only if requested to by the person helping you.
    Otherwise you can close this log when you wish.
    Rkill was run on 02/05/2011 at 21:43:05.
    Operating System: Microsoft Windows XP
    Processes terminated by Rkill or while it was running:
    Rkill completed on 02/05/2011 at 21:43:45.
    I have downloaded the broni file and will follow your instructions now. Assuming I can get into safe mode.
  2. 2011/05/03
    biggazdixon
    I cannot start my machine in safe mode. I choose the option and see a blck screen with what seems to be a list of drivers that it is loading but then I get a blue screen as before saying INVALID_WORK_QUEUE_ITEM.
    I realise that it's around midnight where you are so I suspect you will not reply for some time. I am going away on business overnight so will probably not be able to do anything else for around 48 hours, although I'm not leaving for about 5 hours, but if I can get internet access then I can at least read any new posts.
    Thanks again
    biggazdixon
    Out of desperation and just in case I did something wrong last night I ran Rkill again this morning and got this log:
    Rkill was run on 03/05/2011 at 9:03:39.
    C:\WINDOWS\system32\taskmgr.exe
    Rkill completed on 03/05/2011 at 9:03:41.
    Rkill completed on 03/05/2011 at 9:03:55.
    Then I double clicked the broni file you told me to download and I got an error message saying that some installation files are corrupt and to download a fresh copy of Combofix.
    I will do nothing else now until I hear back from you. Promise.
  5. 2011/05/03
    We'll need to reset your MBR, which seems to infected by a rootkit, but before we go there, I'd like to see two more logs...
    Download Bootkit Remover to your Desktop.
    • You then need to extract the remover.exe file from the RAR using a program capable of extracing RAR compressed files. If you don't have an extraction program, you can use 7-Zip: http://www.7-zip.org/
    • After extracing remover.exe to your Desktop, double-click on remover.exe to run the program (Vista/7 users,right click on remover.exe and click Run As Administrator).
    • It will show a Black screen with some data on it.
    • Right click on the screen and click Select All.
    • Press CTRL+C
    • Open a Notepad and press CTRL+V
    • Post the output back here.
    Please download Rootkit Unhooker from one of the following links and save it to your desktop.
    In order to use this tool if you downloaded from either of the second two links, you will need to extract the RKUnhookerLE.exe file using a program capable of extracing ZIP and RAR compressed files. If you don't have an extraction program, you can downlaod, install and use the free 7-zip utility.
    • Double-click on RKUnhookerLE.exe to start the program.
      Vista/Windows 7 users right-click and select Run As Administrator.
    • Click the Report tab, then click Scan.
    • Check Drivers, Stealth, and uncheck the rest.
    • Click OK.
    • Wait until it's finished and then go to File > Save Report.
    • Save the report to your Desktop.
    • Copy and paste the contents of the report into your next reply.
    -- Note: You may get this warning...just ignore it, click OK and continue: "Rootkit Unhooker has detected a parasite inside itself! It is recommended to remove parasite, okay? ".
  6. 2011/05/04
    biggazdixon
    I also have an external hard drive and a USB key, should these be plugged in while I do any scans?
  7. 2011/05/04
    For now, leave them alone.
  8. 2011/05/04
    biggazdixon
    For some reason the Ctrl +V does nothing but copy and paste straight to here gives this:
    Bootkit Remover
    (c) 2009 eSage Lab
    www.esagelab.com
    Program version: 1.2.0.0
    OS Version: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    System volume is \\.\C:
    \\.\C: -> \\.\PhysicalDrive0 at offset 0x00000000`04e71400
    Size Device Name MBR Status
    73 GB \\.\PhysicalDrive0 Controlled by rootkit!
    Boot code on some of your physical disks is hidden by a rootkit.
    To disinfect the master boot sector, use the following command:
    remover.exe fix <device_name>
    To inspect the boot code manually, dump the master boot sector:
    remover.exe dump <device_name> [output_file]
    Done;
    Press any key to quit...
    I will do the RK unhooker next
  9. 2011/05/04
    You did fine.
    Next log, please.
  10. 2011/05/04
    biggazdixon
    RkU Version: 3.8.388.590, Type LE (SR2)
    OS Name: Windows XP
    Version 5.1.2600 (Service Pack 3)
    Number of processors #2
    >Drivers
    0x804D7000 C:\WINDOWS\system32\ntkrnlpa.exe 2154496 bytes (Microsoft Corporation, NT Kernel & System)
    0x804D7000 PnpManager 2154496 bytes
    0x804D7000 RAW 2154496 bytes
    0x804D7000 WMIxWDM 2154496 bytes
    0xBF800000 Win32k 1859584 bytes
    0xBF800000 C:\WINDOWS\System32\win32k.sys 1859584 bytes (Microsoft Corporation, Multi-User Win32 Driver)
    0xF69A4000 C:\WINDOWS\system32\DRIVERS\w39n51.sys 1433600 bytes (Intel® Corporation, Intel® Wireless LAN Driver)
    0xF6B3E000 C:\WINDOWS\system32\DRIVERS\ialmnt5.sys 1368064 bytes (Intel Corporation, Intel Graphics Miniport Driver)
    0xAA610000 C:\WINDOWS\system32\drivers\sthda.sys 1114112 bytes (SigmaTel, Inc., NDRC)
    0xAA4BD000 C:\WINDOWS\system32\DRIVERS\HSF_DPV.sys 1036288 bytes (Conexant Systems, Inc., HSF_DP driver)
    0xBF077000 C:\WINDOWS\System32\ialmdd5.DLL 925696 bytes (Intel Corporation, DirectDraw(R) Driver for Intel(R) Graphics Technology)
    0xAA40D000 C:\WINDOWS\system32\DRIVERS\HSF_CNXT.sys 720896 bytes (Conexant Systems, Inc., HSF_CNXT driver)
    0xF81B5000 Ntfs.sys 577536 bytes (Microsoft Corporation, NT File System Driver)
    0xF0AE2000 C:\WINDOWS\System32\Drivers\wdf01000.sys 462848 bytes (Microsoft Corporation, Kernel Mode Driver Framework Runtime)
    0xA9D47000 C:\WINDOWS\system32\DRIVERS\mrxsmb.sys 458752 bytes (Microsoft Corporation, Windows NT SMB Minirdr)
    0xA9DB7000 C:\WINDOWS\system32\drivers\RapportBuka.sys 393216 bytes (Trusteer Ltd., RapportBuka)
    0xF0B67000 C:\WINDOWS\system32\DRIVERS\update.sys 385024 bytes (Microsoft Corporation, Update Driver)
    0xF826E000 mfehidk.sys 380928 bytes (McAfee, Inc., McAfee Link Driver)
    0xA9EC8000 C:\WINDOWS\system32\DRIVERS\tcpip.sys 364544 bytes (Microsoft Corporation, TCP/IP Protocol Driver)
    0xA99CF000 C:\WINDOWS\system32\DRIVERS\srv.sys 360448 bytes (Microsoft Corporation, Server driver)
    0xF6920000 C:\WINDOWS\system32\DRIVERS\rixdptsk.sys 311296 bytes (REDC, RICOH XD SM Driver)
    0xF0BC5000 C:\WINDOWS\system32\drivers\mfefirek.sys 307200 bytes (McAfee, Inc., McAfee Core Firewall Engine Driver)
    0xBF159000 C:\WINDOWS\System32\ATMFD.DLL 290816 bytes (Adobe Systems Incorporated, Windows NT OpenType/Type 1 Font Driver)
    0xA8706000 C:\WINDOWS\System32\Drivers\HTTP.sys 266240 bytes (Microsoft Corporation, HTTP Protocol Stack)
    0xBF042000 C:\WINDOWS\System32\ialmdev5.DLL 217088 bytes (Intel Corporation, Component GHAL Driver)
    0xAA5BA000 C:\WINDOWS\system32\DRIVERS\HSFHWAZL.sys 204800 bytes (Conexant Systems, Inc., HSF_HWAZL WDM driver)
    0xF68F1000 C:\WINDOWS\system32\DRIVERS\SynTP.sys 192512 bytes (Synaptics, Inc., Synaptics Touchpad Driver)
    0xF8345000 ACPI.sys 188416 bytes (Microsoft Corporation, ACPI Driver for NT)
    0xA9BF2000 C:\WINDOWS\system32\DRIVERS\mrxdav.sys 184320 bytes (Microsoft Corporation, Windows NT WebDav Minirdr)
    0xF8188000 NDIS.sys 184320 bytes (Microsoft Corporation, NDIS 5.1 wrapper driver)
    0xA9E40000 C:\WINDOWS\system32\DRIVERS\rdbss.sys 176128 bytes (Microsoft Corporation, Redirected Drive Buffering SubSystem Driver)
    0xA9E17000 C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys 167936 bytes (Trusteer Ltd., RapportPG)
    0xF6B02000 C:\WINDOWS\system32\DRIVERS\HDAudBus.sys 163840 bytes (Windows (R) Server 2003 DDK provider, High Definition Audio Bus Driver v1.0a)
    0xA9E8D000 C:\WINDOWS\system32\DRIVERS\netbt.sys 163840 bytes (Microsoft Corporation, MBT Transport driver)
    0xA629B000 C:\WINDOWS\system32\DRIVERS\ipnat.sys 155648 bytes (Microsoft Corporation, IP Network Address Translator)
    0xF5512000 C:\WINDOWS\system32\drivers\mfeavfk.sys 147456 bytes (McAfee, Inc., Anti-Virus File System Filter Driver)
    0xAA5EC000 C:\WINDOWS\system32\drivers\portcls.sys 147456 bytes (Microsoft Corporation, Port Class (Class Driver for Port/Miniport Devices))
    0xF6980000 C:\WINDOWS\system32\DRIVERS\USBPORT.SYS 147456 bytes (Microsoft Corporation, USB 1.1 & 2.0 Port Driver)
    0xF68CE000 C:\WINDOWS\system32\DRIVERS\ks.sys 143360 bytes (Microsoft Corporation, Kernel CSA Library)
    0xA9E6B000 C:\WINDOWS\System32\drivers\afd.sys 139264 bytes (Microsoft Corporation, Ancillary Function Driver for WinSock)
    0xBF020000 C:\WINDOWS\System32\ialmdnt5.dll 139264 bytes (Intel Corporation, Controller Hub for Intel Graphics Driver)
    0x806E5000 ACPI_HAL 134400 bytes
    0x806E5000 C:\WINDOWS\system32\hal.dll 134400 bytes (Microsoft Corporation, Hardware Abstraction Layer DLL)
    0xF82DD000 fltmgr.sys 131072 bytes (Microsoft Corporation, Microsoft Filesystem Filter Manager)
    0xF8315000 ftdisk.sys 126976 bytes (Microsoft Corporation, FT Disk Driver)
    0xF816E000 Mup.sys 106496 bytes (Microsoft Corporation, Multiple UNC Provider driver)
    0xA9D00000 C:\WINDOWS\system32\dla\tfsnudf.sys 102400 bytes (Sonic Solutions, Drive Letter Access Component)
    0xA9CE7000 C:\WINDOWS\system32\dla\tfsnudfa.sys 102400 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF82FD000 atapi.sys 98304 bytes (Microsoft Corporation, IDE/ATAPI Port Driver)
    0xA9D2F000 C:\WINDOWS\System32\Drivers\dump_atapi.sys 98304 bytes
    0xF8242000 KSecDD.sys 94208 bytes (Microsoft Corporation, Kernel Security Support Provider Interface)
    0xF5547000 C:\WINDOWS\system32\DRIVERS\ndiswan.sys 94208 bytes (Microsoft Corporation, MS PPP Framing Driver (Strong Encryption))
    0xA8867000 C:\WINDOWS\system32\drivers\mfeapfk.sys 90112 bytes (McAfee, Inc., Access Protection Filter Driver)
    0xA9D19000 C:\WINDOWS\system32\dla\tfsnifs.sys 90112 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF8259000 drvmcdb.sys 86016 bytes (Sonic Solutions, Device Driver)
    0xA9BB5000 C:\WINDOWS\system32\drivers\wdmaud.sys 86016 bytes (Microsoft Corporation, MMSYSTEM Wave/Midi API mapper)
    0xF555E000 C:\WINDOWS\system32\DRIVERS\mfendisk.sys 81920 bytes (McAfee, Inc., McAfee NDIS Intermediate Driver)
    0xF696C000 C:\WINDOWS\system32\DRIVERS\sdbus.sys 81920 bytes (Microsoft Corporation, SecureDigital Bus Driver)
    0xF6B2A000 C:\WINDOWS\system32\DRIVERS\VIDEOPRT.SYS 81920 bytes (Microsoft Corporation, Video Port Driver)
    0xF0B53000 C:\WINDOWS\system32\DRIVERS\zte_mf651_dc_enum.sys 81920 bytes (ZTE, DC Class Enumerator Driver)
    0xA9F21000 C:\WINDOWS\system32\DRIVERS\ipsec.sys 77824 bytes (Microsoft Corporation, IPSec Driver)
    0xA9EB5000 C:\WINDOWS\system32\drivers\mfetdi2k.sys 77824 bytes (McAfee, Inc., Anti-Virus Mini-Firewall Driver)
    0xBF000000 C:\WINDOWS\System32\drivers\dxg.sys 73728 bytes (Microsoft Corporation, DirectX Graphics Driver)
    0xF82CB000 sr.sys 73728 bytes (Microsoft Corporation, System Restore Filesystem Filter Driver)
    0xF8334000 pci.sys 69632 bytes (Microsoft Corporation, NT Plug and Play PCI Enumerator)
    0xF5536000 C:\WINDOWS\system32\DRIVERS\psched.sys 69632 bytes (Microsoft Corporation, MS QoS Packet Scheduler)
    0xF10CB000 C:\WINDOWS\System32\Drivers\Cdfs.SYS 65536 bytes (Microsoft Corporation, CD-ROM File System Driver)
    0xF8674000 C:\WINDOWS\system32\DRIVERS\cdrom.sys 65536 bytes (Microsoft Corporation, SCSI CD-ROM Driver)
    0xF8514000 C:\WINDOWS\system32\DRIVERS\nic1394.sys 65536 bytes (Microsoft Corporation, IEEE1394 Ndis Miniport and Call Manager)
    0xF84E4000 ohci1394.sys 65536 bytes (Microsoft Corporation, 1394 OpenHCI Port Driver)
    0xEBAB0000 C:\WINDOWS\system32\DRIVERS\arp1394.sys 61440 bytes (Microsoft Corporation, IP/1394 Arp Client)
    0xEBB00000 C:\WINDOWS\system32\drivers\drmk.sys 61440 bytes (Microsoft Corporation, Microsoft Kernel DRM Descrambler Filter)
    0xF8684000 C:\WINDOWS\system32\DRIVERS\redbook.sys 61440 bytes (Microsoft Corporation, Redbook Audio Filter Driver)
    0xEEAF2000 C:\WINDOWS\system32\drivers\sysaudio.sys 61440 bytes (Microsoft Corporation, System Audio WDM Filter)
    0xEBAF0000 C:\WINDOWS\system32\DRIVERS\usbhub.sys 61440 bytes (Microsoft Corporation, Default Hub Driver for USB)
    0xF84F4000 C:\WINDOWS\system32\DRIVERS\1394BUS.SYS 57344 bytes (Microsoft Corporation, 1394 Bus Device Driver)
    0xBF012000 C:\WINDOWS\System32\ialmrnt5.dll 57344 bytes (Intel Corporation, Controller Hub for Intel Graphics Driver)
    0xF84D4000 RapportKELL.sys 57344 bytes (Trusteer Ltd., RapportKE)
    0xF5472000 C:\WINDOWS\system32\DRIVERS\WDFLDR.SYS 57344 bytes (Microsoft Corporation, Kernel Mode Driver Framework Loader)
    0xF84B4000 C:\WINDOWS\system32\DRIVERS\CLASSPNP.SYS 53248 bytes (Microsoft Corporation, SCSI Class System Dll)
    0xF8644000 C:\WINDOWS\system32\DRIVERS\i8042prt.sys 53248 bytes (Microsoft Corporation, i8042 Port Driver)
    0xEBAA0000 C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\26169\RapportCerberus_26169.sys 53248 bytes (Trusteer Ltd., RapportCerberus)
    0xF76C8000 C:\WINDOWS\system32\DRIVERS\rasl2tp.sys 53248 bytes (Microsoft Corporation, RAS L2TP mini-port/call-manager driver)
    0xF8634000 C:\WINDOWS\system32\DRIVERS\rimsptsk.sys 53248 bytes (REDC, RICOH MS Driver)
    0xF8494000 VolSnap.sys 53248 bytes (Microsoft Corporation, Volume Shadow Copy Driver)
    0xF8624000 C:\WINDOWS\system32\DRIVERS\bcm4sbxp.sys 49152 bytes (Broadcom Corporation, Broadcom Corporation NDIS 5.1 ethernet driver)
    0xA9197000 C:\WINDOWS\system32\drivers\cfwids.sys 49152 bytes (McAfee, Inc., McAfee Personal Firewall IDS Plugin)
    0xF76D8000 C:\WINDOWS\system32\DRIVERS\raspptp.sys 49152 bytes (Microsoft Corporation, Peer-to-Peer Tunneling Protocol)
    0xF0E77000 C:\WINDOWS\System32\Drivers\Fips.SYS 45056 bytes (Microsoft Corporation, FIPS Crypto Driver)
    0xF8654000 C:\WINDOWS\system32\DRIVERS\imapi.sys 45056 bytes (Microsoft Corporation, IMAPI Kernel Driver)
    0xA898F000 C:\WINDOWS\system32\drivers\mfebopk.sys 45056 bytes (McAfee, Inc., Buffer Overflow Protection Driver)
    0xF8484000 MountMgr.sys 45056 bytes (Microsoft Corporation, Mount Manager)
    0xF7708000 C:\WINDOWS\system32\DRIVERS\raspppoe.sys 45056 bytes (Microsoft Corporation, RAS PPPoE mini-port/call-manager driver)
    0xF469C000 C:\WINDOWS\system32\drivers\drvnddm.sys 40960 bytes (Sonic Solutions, Device Driver Manager)
    0xF8474000 isapnp.sys 40960 bytes (Microsoft Corporation, PNP ISA Bus Driver)
    0xEBB30000 C:\WINDOWS\System32\Drivers\NDProxy.SYS 40960 bytes (Microsoft Corporation, NDIS Proxy)
    0xF84C4000 PxHelp20.sys 40960 bytes (Sonic Solutions, Px Engine Device Driver for Windows 2000/XP)
    0xF5482000 C:\WINDOWS\system32\DRIVERS\termdd.sys 40960 bytes (Microsoft Corporation, Terminal Server Driver)
    0xF8664000 C:\WINDOWS\System32\Drivers\AFS2K.SYS 36864 bytes (Oak Technology Inc., Audio File System)
    0xF84A4000 disk.sys 36864 bytes (Microsoft Corporation, PnP Disk Driver)
    0xA941F000 C:\WINDOWS\system32\FsUsbExDisk.SYS 36864 bytes
    0xF8614000 C:\WINDOWS\system32\DRIVERS\intelppm.sys 36864 bytes (Microsoft Corporation, Processor Device Driver)
    0xF8594000 C:\WINDOWS\system32\DRIVERS\msgpc.sys 36864 bytes (Microsoft Corporation, MS General Packet Classifier)
    0xEBAD0000 C:\WINDOWS\system32\DRIVERS\netbios.sys 36864 bytes (Microsoft Corporation, NetBIOS interface driver)
    0xF54E2000 C:\WINDOWS\System32\Drivers\Normandy.SYS 36864 bytes (RKU Driver)
    0xF1DA5000 C:\WINDOWS\system32\dla\tfsncofs.sys 36864 bytes (Sonic Solutions, Drive Letter Access Component)
    0xEBAE0000 C:\WINDOWS\system32\DRIVERS\wanarp.sys 36864 bytes (Microsoft Corporation, MS Remote Access and Routing ARP Driver)
    0xECF87000 C:\WINDOWS\System32\Drivers\Modem.SYS 32768 bytes (Microsoft Corporation, Modem Device Driver)
    0xEB983000 C:\WINDOWS\System32\Drivers\Npfs.SYS 32768 bytes (Microsoft Corporation, NPFS Driver)
    0xF884C000 C:\WINDOWS\system32\DRIVERS\usbehci.sys 32768 bytes (Microsoft Corporation, EHCI eUSB Miniport Driver)
    0xF86F4000 C:\WINDOWS\system32\DRIVERS\PCIIDEX.SYS 28672 bytes (Microsoft Corporation, PCI IDE Bus Driver Extension)
    0xF8854000 C:\WINDOWS\system32\DRIVERS\rimmptsk.sys 28672 bytes (REDC, RICOH MMC Driver)
    0xAA061000 C:\WINDOWS\system32\dla\tfsnboio.sys 28672 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF886C000 C:\WINDOWS\System32\Drivers\GEARAspiWDM.sys 24576 bytes (GEAR Software Inc., CD DVD Filter)
    0xF8864000 C:\WINDOWS\system32\DRIVERS\kbdclass.sys 24576 bytes (Microsoft Corporation, Keyboard Class Driver)
    0xF885C000 C:\WINDOWS\system32\DRIVERS\mouclass.sys 24576 bytes (Microsoft Corporation, Mouse Class Driver)
    0xEB99B000 C:\WINDOWS\system32\drivers\ssrtln.sys 24576 bytes (Sonic Solutions, Shared Driver Component)
    0xF8844000 C:\WINDOWS\system32\DRIVERS\usbuhci.sys 24576 bytes (Microsoft Corporation, UHCI USB Miniport Driver)
    0xEB993000 C:\WINDOWS\System32\drivers\vga.sys 24576 bytes (Microsoft Corporation, VGA/Super VGA Video Driver)
    0xF87F4000 C:\WINDOWS\system32\DRIVERS\AegisP.sys 20480 bytes (Meetinghouse Data Communications, IEEE 802.1X Protocol Driver)
    0xF1E3F000 C:\WINDOWS\system32\DRIVERS\LVPr2Mon.sys 20480 bytes (-, -)
    0xEB98B000 C:\WINDOWS\System32\Drivers\Msfs.SYS 20480 bytes (Microsoft Corporation, Mailslot driver)
    0xF2738000 C:\WINDOWS\system32\DRIVERS\omci.sys 20480 bytes (Dell Inc, OMCI Device Driver)
    0xF86FC000 PartMgr.sys 20480 bytes (Microsoft Corporation, Partition Manager)
    0xF2748000 C:\WINDOWS\system32\DRIVERS\ptilink.sys 20480 bytes (Parallel Technologies, Inc., Parallel Technologies DirectParallel IO Library)
    0xF2740000 C:\WINDOWS\system32\DRIVERS\raspti.sys 20480 bytes (Microsoft Corporation, PTI DirectParallel(R) mini-port/call-manager driver)
    0xF8804000 C:\WINDOWS\system32\DRIVERS\TDI.SYS 20480 bytes (Microsoft Corporation, TDI Wrapper)
    0xF11A5000 C:\WINDOWS\System32\watchdog.sys 20480 bytes (Microsoft Corporation, Watchdog Driver)
    0xED62B000 C:\WINDOWS\SYSTEM32\DRIVERS\APPDRV.SYS 16384 bytes (Dell Inc, App Support Driver)
    0xF8890000 C:\WINDOWS\system32\DRIVERS\BATTC.SYS 16384 bytes (Microsoft Corporation, Battery Class Driver)
    0xF8948000 C:\WINDOWS\system32\DRIVERS\CmBatt.sys 16384 bytes (Microsoft Corporation, Control Method Battery Driver)
    0xF4670000 C:\WINDOWS\system32\DRIVERS\mssmbios.sys 16384 bytes (Microsoft Corporation, System Management BIOS Driver)
    0xA9FAD000 C:\WINDOWS\system32\DRIVERS\ndisuio.sys 16384 bytes (Microsoft Corporation, NDIS User mode I/O Driver)
    0xEEF7A000 C:\WINDOWS\system32\DRIVERS\packet.sys 16384 bytes (SingleClick Systems, SCS NDIS 5.0 Auto IP Protocol Driver)
    0xEE880000 C:\WINDOWS\system32\DRIVERS\s24trans.sys 16384 bytes (Intel Corporation, Intel WLAN Packet Driver)
    0xF814A000 C:\WINDOWS\system32\dla\tfsnopio.sys 16384 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF8888000 C:\WINDOWS\system32\BOOTVID.dll 12288 bytes (Microsoft Corporation, VGA Boot Driver)
    0xF888C000 compbatt.sys 12288 bytes (Microsoft Corporation, Composite Battery Driver)
    0xF4664000 C:\WINDOWS\System32\drivers\Dxapi.sys 12288 bytes (Microsoft Corporation, DirectX API Driver)
    0xF1380000 C:\WINDOWS\System32\Drivers\i2omgmt.SYS 12288 bytes (Microsoft Corporation, I2O Utility Filter)
    0x830BA000 C:\WINDOWS\system32\KDCOM.DLL 12288 bytes (Microsoft Corporation, Kernel Debugger HW Extension DLL)
    0xA9A3F000 C:\WINDOWS\system32\DRIVERS\mdmxsdk.sys 12288 bytes (Conexant, Diagnostic Interface DRIVER)
    0xF72D4000 C:\WINDOWS\system32\DRIVERS\ndistapi.sys 12288 bytes (Microsoft Corporation, NDIS 3.0 connection wrapper driver)
    0xF14B9000 C:\WINDOWS\system32\DRIVERS\rasacd.sys 12288 bytes (Microsoft Corporation, RAS Automatic Connection Driver)
    0xF8944000 C:\WINDOWS\system32\DRIVERS\wmiacpi.sys 12288 bytes (Microsoft Corporation, Windows Management Interface for ACPI)
    0xEE85C000 C:\WINDOWS\System32\drivers\ws2ifsl.sys 12288 bytes (Microsoft Corporation, Winsock2 IFS Layer)
    0xA9FC5000 C:\WINDOWS\System32\Drivers\ASCTRM.SYS 8192 bytes (Windows (R) 2000 DDK provider, TR Manager)
    0xAA02D000 C:\WINDOWS\System32\Drivers\Beep.SYS 8192 bytes (Microsoft Corporation, BEEP Driver)
    0xAA00B000 C:\WINDOWS\System32\Drivers\dump_WMILIB.SYS 8192 bytes
    0xAA02F000 C:\WINDOWS\System32\Drivers\Fs_Rec.SYS 8192 bytes (Microsoft Corporation, File System Recognizer Driver)
    0xAA029000 C:\WINDOWS\System32\Drivers\mnmdd.SYS 8192 bytes (Microsoft Corporation, Frame buffer simulator)
    0xAA027000 C:\WINDOWS\System32\DRIVERS\RDPCDD.sys 8192 bytes (Microsoft Corporation, RDP Miniport)
    0xF89A4000 C:\WINDOWS\system32\drivers\sscdbhk5.sys 8192 bytes (Sonic Solutions, Shared Driver Component)
    0xF8A04000 C:\WINDOWS\system32\DRIVERS\swenum.sys 8192 bytes (Microsoft Corporation, Plug and Play Software Device Enumerator)
    0xAA007000 C:\WINDOWS\system32\dla\tfsnpool.sys 8192 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF8976000 C:\WINDOWS\System32\Drivers\USBD.SYS 8192 bytes (Microsoft Corporation, Universal Serial Bus Driver)
    0xF8974000 C:\WINDOWS\system32\DRIVERS\WMILIB.SYS 8192 bytes (Microsoft Corporation, WMILIB WMI support library Dll)
    0xF8B95000 C:\WINDOWS\system32\DRIVERS\audstub.sys 4096 bytes (Microsoft Corporation, AudStub Driver)
    0xF8BA2000 C:\WINDOWS\System32\drivers\dxgthk.sys 4096 bytes (Microsoft Corporation, DirectX Graphics Driver Thunk)
    0xF1240000 C:\WINDOWS\System32\Drivers\Null.SYS 4096 bytes (Microsoft Corporation, NULL Driver)
    0xF8A3C000 pciide.sys 4096 bytes (Microsoft Corporation, Generic PCI IDE Bus Driver)
    0xF1484000 C:\WINDOWS\system32\dla\tfsndrct.sys 4096 bytes (Sonic Solutions, Drive Letter Access Component)
    0xF1485000 C:\WINDOWS\system32\dla\tfsndres.sys 4096 bytes (Sonic Solutions, Drive Letter Access Component)
    !!!!!!!!!!!Hidden driver: 0x8316D33B ?_empty_? 3269 bytes
    >Stealth
    0xF82FD000 WARNING: suspicious driver modification [atapi.sys::0x8316D33B]
    0x035A0000 Hidden Image-->VMC.ConnectionServicesInterface.dll [ EPROCESS 0xFF8825C8 ] PID: 2196, 118784 bytes
    0x013F0000 Hidden Image-->VMC.BaseServices.DataAccessor.dll [ EPROCESS 0xFF8825C8 ] PID: 2196, 176128 bytes
    0x03540000 Hidden Image-->VMC.BaseServices.Platform.dll [ EPROCESS 0xFF8825C8 ] PID: 2196, 233472 bytes
    0x010D0000 Hidden Image-->VMC.WindowsService.Messaging.dll [ EPROCESS 0xFF8825C8 ] PID: 2196, 36864 bytes
    0x01030000 Hidden Image-->VMC.WindowsService.Core.dll [ EPROCESS 0xFF8825C8 ] PID: 2196, 77824 bytes
  11. 2011/05/04
    OK, it's time to reset your MBR.
    Restart computer
    When you reboot you will see an option to boot into the Recovery Console or the normal Windows installation (if you don't see Recovery Console option, it may be not installed on your computer; in that case see Option 1, or 2 below)
    You have to use the up/down arrows to choose the Recovery Console. Then press Enter but you only have 2 seconds by default.
    If you find this hard to do then you can go into Control Panel, System, Advanced, Startup and Recovery, Settings. Where it says Time to Display List of Operating Systems, change it to 10 or more seconds. OK Then reboot.
    You should get a black screen with a C:\> prompt. Type with an Enter after each line:
    fixmbr
    (If it asks you if you are sure then say "Y ".)
    exit
    Reboot computer.
    Post fresh Bootkit Remover log.
    **Important note to Dell users - fixing the MBR may prevent access to the Dell Restore Utility, which allows you to press a key on startup and revert your computer to a factory delivered state. If this is Dell computer, let me know before proceeding.
    Option 1.
    • You'll need to find your Windows XP installation disk.
    • Insert the Windows XP CD into the CD-ROM drive, then restart your computer.
    • If prompted, click any options that are required to start the computer from the CD-ROM drive.
    • When the Welcome to Setup screen appears, press R to start the Recovery Console.
    Option 2.
    If you don't have Windows CD...
    Download Windows Recovery Console: http://www.thecomputerparamedic.com/files/rc.iso
    Download, and install free Imgburn: http://www.imgburn.com/index.php?act=download
    Using Imgburn, burn rc.iso to a CD.
    Boot to the CD...let it finish loading.
    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  12. 2011/05/04
    biggazdixon
    This is a Dell computor. Also, I remember the Recovery Console being created as part of one of the previous stages so it is on here.
  13. 2011/05/04
    Well, we have a "catch 22" here.
    Bootkit Remover reports:
    Since no other tools seem to be working, the only way to get rid of a rootkit is to reset MBR, which in case of Dell will prevent you from accessing recovery partition.
    There are ways to restore that access later, but they're not easy.
    We can try one more way to remove that rootkit, but before we go there....do you have recovery disks for your computer?
  14. 2011/05/04
    biggazdixon
    I have a Dell CD which is labelled as Drivers and Utilities, Already Installed on your Computer. Contents: Device Drivers, Diagnostics and Utilities. I have nothing else.
  15. 2011/05/04
    OK, that's not recovery disk.
    Let's try one more option....
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Click the Scan All Users checkbox.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    atapi.sys
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  16. 2011/05/04
    biggazdixon
    I've had to split this report into 2 because there were too many characters.
    OTL logfile created on: 05/05/2011 00:31:50 - Run 1
    OTL by OldTimer - Version 3.2.22.3 Folder = C:\Documents and Settings\Gary Dixon\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
    502.00 Mb Total Physical Memory | 118.00 Mb Available Physical Memory | 24.00% Memory free
    1.00 Gb Paging File | 0.00 Gb Available in Paging File | 41.00% Paging File free
    Paging file location(s): C:\pagefile.sys 756 1512 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 52.68 Gb Total Space | 16.67 Gb Free Space | 31.64% Space Free | Partition Type: NTFS
    Drive D: | 17.21 Gb Total Space | 16.49 Gb Free Space | 95.84% Space Free | Partition Type: NTFS
    Computer Name: GARYDIXON | User Name: Gary Dixon | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2011/05/05 00:05:51 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\OTL.exe
    PRC - [2011/03/09 13:30:08 | 000,247,728 | ---- | M] (TomTom) -- C:\Program Files\TomTom HOME 2\TomTomHOMERunner.exe
    PRC - [2011/03/09 13:30:08 | 000,092,592 | ---- | M] (TomTom) -- C:\Program Files\TomTom HOME 2\TomTomHOMEService.exe
    PRC - [2011/02/16 15:49:08 | 000,088,176 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
    PRC - [2010/11/12 15:17:32 | 000,188,136 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe
    PRC - [2010/11/12 15:17:32 | 000,141,792 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe
    PRC - [2010/10/03 22:43:16 | 001,266,920 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\RapportService.exe
    PRC - [2010/10/03 22:43:16 | 000,767,208 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe
    PRC - [2010/09/04 13:09:24 | 000,171,168 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\McAfee\SystemCore\mcshield.exe
    PRC - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
    PRC - [2009/04/07 09:39:44 | 000,233,472 | ---- | M] (Teruten) -- C:\WINDOWS\system32\FsUsbExService.Exe
    PRC - [2008/05/15 18:45:26 | 000,356,864 | ---- | M] (Avid Technology, Inc.) -- C:\WINDOWS\system32\M-AudioTaskBarIcon.exe
    PRC - [2008/04/14 01:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2008/03/13 20:08:58 | 000,024,576 | ---- | M] (Vodafone) -- C:\Program Files\Vodafone\Vodafone Mobile Connect\Bin\VMCService.exe
    PRC - [2008/02/08 19:32:32 | 000,036,864 | ---- | M] (Logitech) -- C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe
    PRC - [2007/08/27 18:12:28 | 001,082,664 | ---- | M] (SingleClick Systems) -- C:\Program Files\Dell Network Assistant\ezi_hnm2.exe
    PRC - [2007/08/27 16:36:34 | 000,111,912 | ---- | M] (SingleClick Systems) -- C:\Program Files\Dell Network Assistant\hnm_svc.exe
    PRC - [2006/11/15 23:03:36 | 000,109,344 | ---- | M] (Logitech Inc.) -- c:\Program Files\Common Files\Logitech\LVMVFM\LVPrcSrv.exe
    PRC - [2006/11/15 23:01:52 | 000,244,512 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\Logitech\LComMgr\LVComSX.exe
    PRC - [2006/11/15 22:58:40 | 000,746,520 | ---- | M] () -- C:\Program Files\Logitech\QuickCam10\QuickCam10.exe
    PRC - [2006/11/15 22:57:20 | 000,171,544 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\Logishrd\LQCVFX\COCIManager.exe
    PRC - [2006/10/31 02:03:48 | 000,284,184 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\Logitech\LComMgr\Communications_Helper.exe
    PRC - [2006/09/21 13:45:38 | 000,026,112 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Real\RealPlayer\realplay.exe
    PRC - [2006/06/29 12:13:32 | 001,032,192 | ---- | M] (Dell Inc) -- C:\Program Files\Dell\QuickSet\quickset.exe
    PRC - [2006/06/29 12:12:34 | 000,376,832 | ---- | M] (Dell Inc.) -- C:\Program Files\Dell\QuickSet\NicConfigSvc.exe
    PRC - [2006/05/01 09:34:00 | 000,262,217 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Intel\Wireless\Bin\WLKEEPER.exe
    PRC - [2006/05/01 09:28:26 | 000,602,182 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\iFrmewrk.exe
    PRC - [2006/05/01 09:28:06 | 000,667,718 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\ZCfgSvc.exe
    PRC - [2006/05/01 09:26:14 | 000,397,381 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\Dot1XCfg.exe
    PRC - [2006/03/24 23:30:44 | 000,282,624 | ---- | M] (SigmaTel, Inc.) -- C:\WINDOWS\stsystra.exe
    PRC - [2005/02/23 15:57:24 | 000,057,344 | ---- | M] (Creative Technology Ltd) -- C:\Program Files\Creative\Mixer\CTSVolFE.exe
    PRC - [2005/01/27 01:02:00 | 000,086,016 | ---- | M] () -- C:\Program Files\Dell\Media Experience\DMXLauncher.exe
    PRC - [2003/04/06 02:06:58 | 000,028,672 | ---- | M] (Hewlett-Packard) -- C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpotdd01.exe
    PRC - [2000/05/19 22:54:06 | 000,087,040 | ---- | M] (Lotus Development Corporation) -- C:\Lotus\organize\EasyClip.exe
    MOD - [2011/05/05 00:05:51 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\OTL.exe
    MOD - [2011/04/08 16:56:28 | 000,018,176 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee\SiteAdvisor\sahook.dll
    MOD - [2010/10/03 22:43:42 | 000,431,336 | ---- | M] (Trusteer Ltd.) -- C:\Program Files\Trusteer\Rapport\bin\rooksbas.dll
    MOD - [2010/08/23 17:12:02 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
    MOD - [2008/02/08 19:32:15 | 000,024,613 | ---- | M] (BackWeb) -- C:\Documents and Settings\Gary Dixon\Local Settings\Temp\IadHide5.dll
    MOD - [2006/11/15 23:03:24 | 000,092,960 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\Logitech\LVMVFM\LVPrcInj.dll
    SRV - File not found [On_Demand | Stopped] -- -- (AppMgmt)
    SRV - [2011/03/09 13:30:08 | 000,092,592 | ---- | M] (TomTom) [Auto | Running] -- C:\Program Files\TomTom HOME 2\TomTomHOMEService.exe -- (TomTomHOMEService)
    SRV - [2011/02/16 15:49:08 | 000,088,176 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\SiteAdvisor\McSACore.exe -- (McAfee SiteAdvisor Service)
    SRV - [2010/11/12 15:17:32 | 000,188,136 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe -- (mfefire)
    SRV - [2010/11/12 15:17:32 | 000,141,792 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe -- (mfevtp)
    SRV - [2010/10/07 21:34:28 | 000,364,216 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
    SRV - [2010/10/03 22:43:16 | 000,767,208 | ---- | M] (Trusteer Ltd.) [Auto | Running] -- C:\Program Files\Trusteer\Rapport\bin\RapportMgmtService.exe -- (RapportMgmtService)
    SRV - [2010/09/04 13:09:24 | 000,171,168 | ---- | M] () [Unknown | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe -- (McShield)
    SRV - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McProxy)
    SRV - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNASvc)
    SRV - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNaiAnn)
    SRV - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (mcmscsvc)
    SRV - [2010/03/10 11:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McMPFSvc)
    SRV - [2009/04/07 09:39:44 | 000,233,472 | ---- | M] (Teruten) [Auto | Running] -- C:\WINDOWS\system32\FsUsbExService.Exe -- (FsUsbExService)
    SRV - [2008/04/07 09:17:30 | 000,430,592 | ---- | M] (Nokia.) [On_Demand | Stopped] -- C:\Program Files\PC Connectivity Solution\ServiceLayer.exe -- (ServiceLayer)
    SRV - [2008/03/13 20:08:58 | 000,024,576 | ---- | M] (Vodafone) [Auto | Running] -- C:\Program Files\Vodafone\Vodafone Mobile Connect\Bin\VMCService.exe -- (VMCService)
    SRV - [2007/08/27 16:36:34 | 000,111,912 | ---- | M] (SingleClick Systems) [Auto | Running] -- C:\Program Files\Dell Network Assistant\hnm_svc.exe -- (hnmsvc)
    SRV - [2006/11/15 23:05:40 | 000,101,152 | ---- | M] (Logitech Inc.) [Auto | Stopped] -- C:\Program Files\Common Files\Logitech\SrvLnch\SrvLnch.exe -- (LVSrvLauncher)
    SRV - [2006/11/15 23:03:36 | 000,109,344 | ---- | M] (Logitech Inc.) [Auto | Running] -- c:\Program Files\Common Files\Logitech\LVMVFM\LVPrcSrv.exe -- (LVPrcSrv)
    SRV - [2006/06/29 12:12:34 | 000,376,832 | ---- | M] (Dell Inc.) [Auto | Running] -- C:\Program Files\Dell\QuickSet\NicConfigSvc.exe -- (NICCONFIGSVC)
    SRV - [2006/05/01 09:34:00 | 000,262,217 | ---- | M] (Intel(R) Corporation) [Auto | Running] -- C:\Program Files\Intel\Wireless\Bin\WLKEEPER.exe -- (WLANKEEPER) Intel(R)
    DRV - [2011/05/02 11:49:20 | 000,057,144 | ---- | M] (Trusteer Ltd.) [Kernel | System | Running] -- C:\Documents and Settings\All Users\Application Data\Trusteer\Rapport\store\exts\RapportCerberus\26169\RapportCerberus_26169.sys -- (RapportCerberus_26169)
    DRV - [2010/11/12 15:17:32 | 000,386,840 | ---- | M] (McAfee, Inc.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\mfehidk.sys -- (mfehidk)
    DRV - [2010/11/12 15:17:32 | 000,313,288 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfefirek.sys -- (mfefirek)
    DRV - [2010/11/12 15:17:32 | 000,152,960 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeavfk.sys -- (mfeavfk)
    DRV - [2010/11/12 15:17:32 | 000,095,600 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfeapfk.sys -- (mfeapfk)
    DRV - [2010/11/12 15:17:32 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendiskmp)
    DRV - [2010/11/12 15:17:32 | 000,088,544 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendisk)
    DRV - [2010/11/12 15:17:32 | 000,084,264 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mferkdet.sys -- (mferkdet)
    DRV - [2010/11/12 15:17:32 | 000,084,072 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\mfetdi2k.sys -- (mfetdi2k)
    DRV - [2010/11/12 15:17:32 | 000,055,840 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\cfwids.sys -- (cfwids)
    DRV - [2010/11/12 15:17:32 | 000,052,104 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mfebopk.sys -- (mfebopk)
    DRV - [2010/10/03 22:43:44 | 000,169,320 | ---- | M] (Trusteer Ltd.) [Kernel | System | Running] -- C:\Program Files\Trusteer\Rapport\bin\RapportPG.sys -- (RapportPG)
    DRV - [2010/10/03 22:43:44 | 000,059,240 | ---- | M] (Trusteer Ltd.) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\RapportKELL.sys -- (RapportKELL)
    DRV - [2010/03/04 11:32:15 | 000,390,528 | ---- | M] (Trusteer Ltd.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\RapportBuka.sys -- (RapportBuka)
    DRV - [2009/11/06 13:59:46 | 000,085,248 | ---- | M] (ZTE) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\zte_mf651_cdc_acm.sys -- (zte_mf651_cdc_acm)
    DRV - [2009/11/06 13:59:46 | 000,049,920 | ---- | M] (ZTE) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\zte_mf651_cdc_ecm.sys -- (zte_mf651_cdc_ecm)
    DRV - [2009/11/06 13:59:44 | 000,080,128 | ---- | M] (ZTE) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\zte_mf651_dc_enum.sys -- (zte_mf651_dc_enum)
    DRV - [2009/11/06 13:59:44 | 000,009,856 | ---- | M] (ZTE) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\zte_mf651_cpo.sys -- (zte_mf651_cpo)
    DRV - [2009/04/07 09:39:44 | 000,036,608 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\FsUsbExDisk.Sys -- (FsUsbExDisk)
    DRV - [2009/01/09 15:25:34 | 000,101,376 | ---- | M] (Huawei Technologies Co., Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ewusbmdm.sys -- (hwdatacard)
    DRV - [2008/01/08 12:55:36 | 000,135,944 | ---- | M] (Avid Technology, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mausbftu.sys -- (MAUSBRI)
    DRV - [2007/09/17 15:53:26 | 000,021,632 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\pccsmcfd.sys -- (pccsmcfd)
    DRV - [2007/08/29 15:50:48 | 000,039,168 | ---- | M] (Frontier Design Group, LLC) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\US122Wdm.sys -- (Us122WdmService)
    DRV - [2007/08/29 15:50:34 | 000,018,304 | ---- | M] (Frontier Design Group) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\US122DL.sys -- (US122DL)
    DRV - [2007/08/29 15:50:02 | 000,131,968 | ---- | M] (Frontier Design Group, LLC) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\US122.sys -- (US122)
    DRV - [2007/07/03 16:58:20 | 000,106,792 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\sscdmdm.sys -- (sscdmdm)
    DRV - [2007/07/03 16:57:24 | 000,011,944 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\sscdmdfl.sys -- (sscdmdfl)
    DRV - [2007/07/03 16:54:24 | 000,080,552 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\sscdbus.sys -- (sscdbus) SAMSUNG USB Composite Device driver (WDM)
    DRV - [2007/02/01 17:24:42 | 000,075,776 | R--- | M] (Prolific Technology Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ser2pl.sys -- (Ser2pl)
    DRV - [2006/12/18 18:01:20 | 000,012,672 | ---- | M] (SingleClick Systems) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\packet.sys -- (Packet)
    DRV - [2006/11/15 23:03:12 | 000,024,736 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LVPr2Mon.sys -- (LVPr2Mon)
    DRV - [2006/11/15 23:02:50 | 001,962,912 | ---- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LVMVdrv.sys -- (LVMVDrv)
    DRV - [2006/11/15 23:00:56 | 001,678,368 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Lvckap.sys -- (LVcKap)
    DRV - [2006/11/11 04:48:00 | 000,040,352 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LVUSBSta.sys -- (LVUSBSta)
    DRV - [2006/11/11 04:43:49 | 000,487,328 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LV561AV.SYS -- (PID_0928) Logitech QuickCam Express(PID_0928)
    DRV - [2006/10/25 03:54:00 | 000,396,192 | R--- | M] (TASCAM) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tascusb2.sys -- (TASCAM_US122144)
    DRV - [2006/10/25 03:54:00 | 000,019,904 | R--- | M] (TASCAM) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tscusb2a.sys -- (TASCAM_US122L_WDM)
    DRV - [2006/10/25 03:54:00 | 000,010,752 | R--- | M] (TASCAM) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tscusb2m.sys -- (TASCAM_US122L_MIDI)
    DRV - [2006/09/28 05:56:20 | 000,172,401 | ---- | M] (Roland Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Rdwm1046.sys -- (RDID1046)
    DRV - [2006/09/21 13:45:41 | 000,008,552 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\asctrm.sys -- (ASCTRM)
    DRV - [2006/05/01 09:52:02 | 000,013,568 | ---- | M] (Intel Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\s24trans.sys -- (s24trans)
    DRV - [2006/04/26 23:13:04 | 001,429,632 | ---- | M] (Intel® Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\w39n51.sys -- (w39n51) Intel(R)
    DRV - [2006/03/24 23:34:30 | 001,156,648 | ---- | M] (SigmaTel, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\sthda.sys -- (STHDA)
    DRV - [2006/01/10 12:07:58 | 000,004,864 | ---- | M] (GTek Technologies Ltd.) [Kernel | On_Demand | Stopped] -- C:\Program Files\Dell Support\GTAction\triggers\DSproct.sys -- (DSproct)
    DRV - [2005/10/14 15:40:18 | 000,307,968 | ---- | M] (REDC) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rixdptsk.sys -- (rismxdp)
    DRV - [2005/10/14 15:40:18 | 000,051,328 | ---- | M] (REDC) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rimsptsk.sys -- (rimsptsk)
    DRV - [2005/10/14 15:40:18 | 000,028,544 | ---- | M] (REDC) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rimmptsk.sys -- (rimmptsk)
    DRV - [2005/08/12 17:50:46 | 000,016,128 | ---- | M] (Dell Inc) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\APPDRV.SYS -- (APPDRV)
    DRV - [2005/08/05 16:32:16 | 000,045,312 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\bcm4sbxp.sys -- (bcm4sbxp)
    DRV - [2005/07/22 03:02:12 | 001,035,008 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_DPV.sys -- (HSF_DPV)
    DRV - [2005/07/22 03:01:08 | 000,201,600 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSFHWAZL.sys -- (HSFHWAZL)
    DRV - [2005/07/22 03:01:00 | 000,717,952 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
    DRV - [2004/10/08 02:16:04 | 000,035,840 | ---- | M] (Oak Technology Inc.) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\AFS2K.SYS -- (AFS2K)
    DRV - [2004/06/09 09:29:56 | 000,006,977 | ---- | M] (Gteko Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\DDMI2.sys -- (SDDMI2)
    DRV - [2004/02/13 16:46:00 | 000,017,153 | ---- | M] (Dell Inc) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\omci.sys -- (omci)
    DRV - [2003/11/11 14:09:48 | 000,057,372 | R--- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ftser2k.sys -- (FTSER2K)
    DRV - [2003/11/11 14:09:32 | 000,024,177 | R--- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ftdibus.sys -- (FTDIBUS)
    DRV - [2000/06/16 16:12:00 | 000,017,784 | ---- | M] (Syncrosoft Hard- und Software GmbH) [Kernel | Auto | Stopped] -- C:\WINDOWS\System32\drivers\NSynas32.sys -- (Nsynas32)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,CustomSearch = http://uk.red.clientapps.yahoo.com/...s/*http://uk.docs.yahoo.com/info/bt_side.html
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Page_URL = www.google.co.uk/ig/dell?hl=en&client=dell-usuk&channel=uk&ibd=0060921
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = http://www.google.com/ie
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Start Page = www.google.co.uk/ig/dell?hl=en&client=dell-usuk&channel=uk&ibd=0060921
    IE - HKU\.DEFAULT\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = www.google.co.uk/ig/dell?hl=en&client=dell-usuk&channel=uk&ibd=0060921
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = 127.0.0.1;*.local
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = 192.168.2.180:8080
    IE - HKU\S-1-5-18\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = www.google.co.uk/ig/dell?hl=en&client=dell-usuk&channel=uk&ibd=0060921
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = 127.0.0.1;*.local
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = 192.168.2.180:8080
    IE - HKU\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = www.google.co.uk/ig/dell?hl=en&client=dell-usuk&channel=uk&ibd=0060921
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://www.google.com
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Google
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultURL = http://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.com/ie
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\..\URLSearchHook: {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - Reg Error: Key error. File not found
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = 127.0.0.1;*.local
    IE - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = 192.168.2.180:8080
    ========== FireFox ==========
    FF - prefs.js..extensions.enabledItems: MapShare-status@tomtom.com:1.7.1
    FF - prefs.js..extensions.enabledItems: baseTheme@tomtom.com:1.0.2
    FF - HKLM\software\mozilla\Firefox\extensions\\{23fcfd51-4958-4f00-80a3-ae97e717ed8b}: C:\Program Files\DivX\DivX Plus Web Player\firefox\html5video [2011/03/21 11:22:29 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Firefox\extensions\\{6904342A-8307-11DF-A508-4AE2DFD72085}: C:\Program Files\DivX\DivX Plus Web Player\firefox\wpa [2011/03/21 11:22:29 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Firefox\extensions\\{B7082FAA-CB62-4872-9106-E42DD88EDE45}: C:\Program Files\McAfee\SiteAdvisor [2011/05/02 15:59:58 | 000,000,000 | ---D | M]
    [2008/08/09 20:51:16 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Gary Dixon\Application Data\Mozilla\Extensions
    [2008/08/09 20:51:16 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Gary Dixon\Application Data\Mozilla\Extensions\home2@tomtom.com
    [2011/03/28 08:13:27 | 000,000,000 | ---D | M] (Map status indicator) -- C:\PROGRAM FILES\TOMTOM HOME 2\XUL\EXTENSIONS\MAPSHARE-STATUS@TOMTOM.COM
    Hosts file not found
    O2 - BHO: (Adobe PDF Reader Link Helper) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (DivX Plus Web Player HTML5 <video>) - {326E768D-4182-46FD-9C16-1449A49795F4} - C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll (DivX, LLC)
    O2 - BHO: (DivX HiQ) - {593DDEC6-7468-4cdd-90E1-42DADAA222E9} - C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll (DivX, LLC)
    O2 - BHO: (DriveLetterAccess) - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll (Sonic Solutions)
    O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20101210083627.dll (McAfee, Inc.)
    O2 - BHO: (Skype add-on for Internet Explorer) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.6209.1142\swg.dll (Google Inc.)
    O2 - BHO: (McAfee SiteAdvisor BHO) - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
    O3 - HKLM\..\Toolbar: (McAfee SiteAdvisor Toolbar) - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
    O3 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\..\Toolbar\WebBrowser: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
    O4 - HKLM..\Run: [CTSVolFE.exe] C:\Program Files\Creative\Mixer\CTSVolFE.exe (Creative Technology Ltd)
    O4 - HKLM..\Run: [Dell QuickSet] C:\Program Files\Dell\QuickSet\quickset.exe (Dell Inc)
    O4 - HKLM..\Run: [DivXUpdate] C:\Program Files\DivX\DivX Update\DivXUpdate.exe ()
    O4 - HKLM..\Run: [DMXLauncher] C:\Program Files\Dell\Media Experience\DMXLauncher.exe ()
    O4 - HKLM..\Run: [IntelWireless] C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe (Intel Corporation)
    O4 - HKLM..\Run: [IntelZeroConfig] C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe (Intel Corporation)
    O4 - HKLM..\Run: [LogitechCommunicationsManager] C:\Program Files\Common Files\Logitech\LComMgr\Communications_Helper.exe (Logitech Inc.)
    O4 - HKLM..\Run: [LogitechQuickCamRibbon] C:\Program Files\Logitech\QuickCam10\QuickCam10.exe ()
    O4 - HKLM..\Run: [LVCOMSX] C:\Program Files\Common Files\Logitech\LComMgr\LVComSX.exe (Logitech Inc.)
    O4 - HKLM..\Run: [M-Audio Taskbar Icon] C:\WINDOWS\system32\M-AudioTaskBarIcon.exe (Avid Technology, Inc.)
    O4 - HKLM..\Run: [mcui_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
    O4 - HKLM..\Run: [MobileConnect] C:\Program Files\Vodafone\Vodafone Mobile Connect\Bin\MobileConnect.exe (Vodafone)
    O4 - HKLM..\Run: [MSKDetectorExe] C:\Program Files\McAfee\SpamKiller\MSKDetct.exe (McAfee, Inc.)
    O4 - HKLM..\Run: [NPSStartup] File not found
    O4 - HKLM..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe (RealNetworks, Inc.)
    O4 - HKLM..\Run: [SigmatelSysTrayApp] C:\WINDOWS\stsystra.exe (SigmaTel, Inc.)
    O4 - HKLM..\Run: [UserFaultCheck] File not found
    O4 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006..\Run: [eyeBeam SIP Client] File not found
    O4 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006..\Run: [LDM] C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe (Logitech)
    O4 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006..\Run: [TomTomHOME.exe] C:\Program Files\TomTom HOME 2\TomTomHOMERunner.exe (TomTom)
    O4 - HKU\.DEFAULT..\RunOnce: [] File not found
    O4 - HKU\S-1-5-18..\RunOnce: [] File not found
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Dell Network Assistant.lnk = C:\WINDOWS\Installer\{0240BDFB-2995-4A3F-8C96-18D41282B716}\Icon0240BDFB3.exe ()
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\hpoddt01.exe.lnk = C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpotdd01.exe (Hewlett-Packard)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Logitech Desktop Messenger.lnk = C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LDMConf.exe (Logitech)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Lotus Organizer EasyClip.lnk = C:\Lotus\organize\EasyClip.exe (Lotus Development Corporation)
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableStatusMessages = 0
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 149
    O7 - HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 149
    O7 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKU\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D183CA64F05FDD98.dll (Google Inc.)
    O9 - Extra Button: Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O9 - Extra 'Tools' menuitem : Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
    O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} http://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab (Facebook Photo Uploader 5 Control)
    O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab (Reg Error: Key error.)
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab (Reg Error: Key error.)
    O16 - DPF: {5F8469B4-B055-49DD-83F7-62B522420ECC} http://upload.facebook.com/controls/FacebookPhotoUploader.cab (Facebook Photo Uploader Control)
    O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab (Facebook Photo Uploader 5 Control)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_23-windows-i586.cab (Java Plug-in 1.6.0_23)
    O16 - DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} http://java.sun.com/update/1.5.0/jinstall-1_5_0_06-windows-i586.cab (Reg Error: Key error.)
    O16 - DPF: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_23-windows-i586.cab (Java Plug-in 1.6.0_23)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_23-windows-i586.cab (Java Plug-in 1.6.0_23)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: Microsoft XML Parser for Java file://C:\WINDOWS\Java\classes\xmldso.cab (Reg Error: Key error.)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.254
    O18 - Protocol\Handler\bw+0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw+0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw-0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw00 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw00s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw-0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw10 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw10s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw20 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw20s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw30 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw30s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw40 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw40s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw50 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw50s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw60 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw60s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw70 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw70s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw80 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw80s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw90 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bw90s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwa0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwa0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwb0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwb0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwc0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwc0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwd0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwd0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwe0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwe0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwf0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwf0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwfile-8876480 {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwg0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwg0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwh0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwh0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwi0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwi0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwj0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwj0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwk0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwk0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwl0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwl0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwm0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwm0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwn0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwn0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwo0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwo0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwp0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwp0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwq0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwq0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwr0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwr0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bws0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bws0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwt0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwt0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwu0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwu0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwv0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwv0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bww0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bww0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwx0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwx0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwy0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwy0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwz0 {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\bwz0s {d6db5713-1974-4f8f-a560-59224f39ad98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\dssrequest {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
    O18 - Protocol\Handler\offline-8876480 {D6DB5713-1974-4F8F-A560-59224F39AD98} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll (Logitech)
    O18 - Protocol\Handler\sacore {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
    O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files\Common Files\Skype\Skype4COM.dll (Skype Technologies)
    O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O18 - Protocol\Filter\application/x-internet-signup {A173B69A-1F9B-4823-9FDA-412F641E65D6} - C:\Program Files\Tiscali\Tiscali Internet\dlls\tiscalifilter.dll ()
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O24 - Desktop WallPaper: C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2004/08/10 13:04:08 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O37 - HKLM\...com [@ = comfile] -- "%1" %*
    NetSvcs: 6to4 - File not found
    NetSvcs: AppMgmt - File not found
    NetSvcs: Ias - File not found
    NetSvcs: Iprip - File not found
    NetSvcs: Irmon - File not found
    NetSvcs: NWCWorkstation - File not found
    NetSvcs: Nwsapagent - File not found
    NetSvcs: WmdmPmSp - File not found
    Drivers32: msacm.ac3filter - C:\WINDOWS\System32\ac3filter.acm ()
    Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
    Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
    Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
    Drivers32: MSVideo - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
    Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
    Drivers32: vidc.DIVX - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
    Drivers32: vidc.dvsd - C:\WINDOWS\System32\mcdvd_32.dll (MainConcept)
    Drivers32: VIDC.I420 - C:\WINDOWS\System32\lvcodec2.dll (Logitech Inc.)
    Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
    Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
    Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
    Drivers32: vidc.mjpg - C:\WINDOWS\System32\mcmjpg32.dll (MainConcept)
    Drivers32: vidc.XVID - C:\WINDOWS\System32\xvidvfw.dll ()
    Drivers32: vidc.yv12 - C:\WINDOWS\System32\DivX.dll (DivX, Inc.)
  17. 2011/05/04
    biggazdixon
    biggazdixon Well-Known Member Thread Starter
    2nd half:
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point (69819349141028864)
    ========== Files/Folders - Created Within 30 Days ==========
    [2011/05/05 00:05:48 | 000,580,608 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\OTL.exe
    [2011/05/04 23:10:44 | 000,083,968 | ---- | C] (eSage Lab) -- C:\Documents and Settings\Gary Dixon\Desktop\remover.exe
    [2011/05/04 22:49:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\McAfee
    [2011/05/03 10:06:46 | 000,000,000 | ---D | C] -- C:\32788R22FWJFW
    [2011/05/02 21:45:56 | 000,000,000 | --SD | C] -- C:\ComboFix
    [2011/05/02 17:56:33 | 000,000,000 | RHSD | C] -- C:\cmdcons
    [2011/05/02 17:50:33 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
    [2011/05/02 17:50:33 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
    [2011/05/02 17:50:33 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
    [2011/05/02 17:50:33 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
    [2011/05/02 17:49:55 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2011/05/02 17:49:06 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2011/05/02 16:53:59 | 001,377,112 | ---- | C] (Kaspersky Lab ZAO) -- C:\Documents and Settings\Gary Dixon\Desktop\TDSSKiller.exe
    [2011/05/01 18:17:28 | 000,446,464 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\TFC.exe
    [2011/05/01 13:05:34 | 000,339,968 | ---- | C] (Trusteer Ltd.) -- C:\WINDOWS\System32\RapportBuka.dll
    [2011/04/29 12:44:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\Trusteer
    [2011/04/28 18:39:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Application Data\ElevatedDiagnostics
    [2011/04/28 18:31:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Windows PowerShell 1.0
    [2011/04/28 18:30:17 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\windowspowershell
    [2011/04/27 11:52:27 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Sun
    [2011/04/27 11:50:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Adobe
    [2011/04/26 10:23:30 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Macromedia
    [2011/04/26 10:22:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Adobe
    [2011/04/14 09:01:18 | 000,000,000 | ---D | C] -- C:\D1_32
    [2011/04/10 17:59:56 | 000,000,000 | --SD | C] -- C:\Documents and Settings\Gary Dixon\My Documents\My Shapes
    [2011/04/10 17:59:34 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\Thinstall
    [2011/04/10 17:59:34 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Application Data\Thinstall
    [2011/04/10 17:58:20 | 000,000,000 | ---D | C] -- C:\Program Files\Microsoft Visio 2007 Portable
    [2011/04/10 10:14:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\My Documents\GSpot271a
    [2011/04/09 16:03:33 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Application Data\Smaart
    [2011/04/09 16:00:36 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Smaart 6
    [2011/04/08 10:17:38 | 000,059,240 | ---- | C] (Trusteer Ltd.) -- C:\WINDOWS\System32\drivers\RapportKELL.sys
    [2011/04/07 15:19:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\My Documents\OneNote Notebooks
    [2011/04/07 15:16:02 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Microsoft Office
    [2011/04/07 15:11:51 | 000,000,000 | ---D | C] -- C:\Program Files\Microsoft.NET
    [2011/04/07 15:08:32 | 000,000,000 | ---D | C] -- C:\WINDOWS\SHELLNEW
    [2011/04/07 15:07:56 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\Microsoft Help
    [2011/04/07 15:07:10 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Microsoft Help
    [2011/04/07 15:06:25 | 000,000,000 | RH-D | C] -- C:\MSOCache
    ========== Files - Modified Within 30 Days ==========
    [2011/05/04 23:09:24 | 000,133,632 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\RKUnhookerLE.EXE
    [2011/05/04 23:08:50 | 000,039,605 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\bootkit_remover.rar
    [2011/05/04 22:53:39 | 000,002,333 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Dell Network Assistant.lnk
    [2011/05/04 22:51:08 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2011/05/04 22:50:47 | 000,000,884 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2011/05/04 22:49:01 | 000,000,880 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2011/05/04 22:48:48 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2011/05/04 22:48:47 | 526,843,904 | -HS- | M] () -- C:\hiberfil.sys
    [2011/05/03 07:25:20 | 000,169,350 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\broni.com
    [2011/05/02 21:39:45 | 001,006,778 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\rkill.scr
    [2011/05/02 17:56:45 | 000,000,327 | RHS- | M] () -- C:\boot.ini
    [2011/05/02 15:40:26 | 001,263,721 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\tdsskiller.zip
    [2011/05/02 09:55:40 | 000,625,664 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\dds.scr
    [2011/05/02 09:55:05 | 000,080,384 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\MBRCheck.exe
    [2011/05/01 19:03:38 | 000,301,568 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\qzrmvojf.exe
    [2011/05/01 18:17:28 | 000,446,464 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\TFC.exe
    [2011/05/01 13:05:35 | 000,339,968 | ---- | M] (Trusteer Ltd.) -- C:\WINDOWS\System32\RapportBuka.dll
    [2011/05/01 12:53:38 | 000,000,527 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\GHundo.bat
    [2011/05/01 12:51:00 | 000,000,712 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\GHremoval.bat
    [2011/04/29 17:18:13 | 000,000,664 | ---- | M] () -- C:\WINDOWS\System32\d3d9caps.dat
    [2011/04/28 18:33:04 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
    [2011/04/15 08:59:54 | 000,282,128 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2011/04/14 23:12:39 | 000,445,938 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2011/04/14 23:12:39 | 000,072,978 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2011/04/14 20:57:05 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
    [2011/04/14 13:19:52 | 000,018,140 | ---- | M] () -- C:\bar.emf
    [2011/04/10 18:08:46 | 000,000,822 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\Shortcut to Microsoft Office Visio 2007.exe.lnk
    [2011/04/09 16:00:38 | 000,000,670 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\Smaart 6.lnk
    [2011/04/09 09:20:10 | 000,139,776 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2011/04/07 15:32:57 | 000,000,376 | ---- | M] () -- C:\WINDOWS\ODBC.INI
    [2011/04/07 15:19:45 | 000,000,947 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Start Menu\Programs\Startup\OneNote 2007 Screen Clipper and Launcher.lnk
    [2011/05/04 23:09:18 | 000,133,632 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\RKUnhookerLE.EXE
    [2011/05/04 23:08:42 | 000,039,605 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\bootkit_remover.rar
    [2011/05/03 07:25:17 | 000,169,350 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\broni.com
    [2011/05/02 21:39:40 | 001,006,778 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\rkill.scr
    [2011/05/02 17:56:44 | 000,000,211 | ---- | C] () -- C:\Boot.bak
    [2011/05/02 17:56:36 | 000,260,272 | RHS- | C] () -- C:\cmldr
    [2011/05/02 17:50:33 | 000,256,512 | ---- | C] () -- C:\WINDOWS\PEV.exe
    [2011/05/02 17:50:33 | 000,098,816 | ---- | C] () -- C:\WINDOWS\sed.exe
    [2011/05/02 17:50:33 | 000,089,088 | ---- | C] () -- C:\WINDOWS\MBR.exe
    [2011/05/02 17:50:33 | 000,080,412 | ---- | C] () -- C:\WINDOWS\grep.exe
    [2011/05/02 17:50:33 | 000,068,096 | ---- | C] () -- C:\WINDOWS\zip.exe
    [2011/05/02 15:40:24 | 001,263,721 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\tdsskiller.zip
    [2011/05/02 09:55:34 | 000,625,664 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\dds.scr
    [2011/05/02 09:54:54 | 000,080,384 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\MBRCheck.exe
    [2011/05/01 19:03:35 | 000,301,568 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\qzrmvojf.exe
    [2011/05/01 13:54:22 | 000,000,527 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\GHundo.bat
    [2011/05/01 13:54:18 | 000,000,712 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\GHremoval.bat
    [2011/04/26 10:24:53 | 000,000,664 | ---- | C] () -- C:\WINDOWS\System32\d3d9caps.dat
    [2011/04/12 13:22:20 | 000,018,140 | ---- | C] () -- C:\bar.emf
    [2011/04/10 18:08:46 | 000,000,822 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\Shortcut to Microsoft Office Visio 2007.exe.lnk
    [2011/04/09 16:50:02 | 000,237,568 | ---- | C] () -- C:\WINDOWS\System32\glut32.dll
    [2011/04/09 16:00:38 | 000,000,670 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Desktop\Smaart 6.lnk
    [2011/04/07 15:19:45 | 000,000,947 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Start Menu\Programs\Startup\OneNote 2007 Screen Clipper and Launcher.lnk
    [2011/03/15 09:28:24 | 000,819,200 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
    [2011/03/15 09:28:23 | 000,180,224 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
    [2010/09/21 19:55:47 | 000,070,671 | ---- | C] () -- C:\WINDOWS\Huawei ModemsUninstall.exe
    [2010/07/15 17:31:58 | 004,648,960 | ---- | C] () -- C:\WINDOWS\System32\ls9-qt-mt336.dll
    [2010/01/27 13:16:08 | 000,466,944 | ---- | C] () -- C:\WINDOWS\System32\RemoveDevice.dll
    [2010/01/09 16:22:41 | 000,007,258 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\N360BUOptions.ini
    [2009/12/14 17:10:10 | 000,050,420 | -H-- | C] () -- C:\WINDOWS\System32\mlfcache.dat
    [2009/11/24 12:33:21 | 000,176,235 | ---- | C] () -- C:\WINDOWS\System32\Primomonnt.dll
    [2009/08/20 12:07:40 | 000,110,592 | ---- | C] () -- C:\WINDOWS\System32\FsUsbExDevice.Dll
    [2009/08/20 12:07:40 | 000,036,608 | ---- | C] () -- C:\WINDOWS\System32\FsUsbExDisk.Sys
    [2009/08/20 12:06:29 | 000,002,528 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Application Data\$_hpcst$.hpc
    [2009/07/31 02:58:42 | 000,000,314 | ---- | C] () -- C:\WINDOWS\primopdf.ini
    [2009/01/27 09:57:25 | 000,000,056 | -H-- | C] () -- C:\WINDOWS\System32\ezsidmv.dat
    [2009/01/16 15:36:07 | 000,020,458 | ---- | C] () -- C:\WINDOWS\hpoins01.dat.temp
    [2009/01/16 15:36:07 | 000,016,622 | ---- | C] () -- C:\WINDOWS\hpomdl01.dat.temp
    [2009/01/13 16:16:51 | 000,020,458 | ---- | C] () -- C:\WINDOWS\hpoins01.dat
    [2009/01/13 16:16:51 | 000,016,622 | ---- | C] () -- C:\WINDOWS\hpomdl01.dat
    [2008/12/28 18:42:01 | 000,000,027 | ---- | C] () -- C:\WINDOWS\REDSHIFT.INI
    [2008/03/07 17:43:56 | 000,084,734 | R--- | C] () -- C:\Documents and Settings\All Users\Application Data\DeviceManager.xml.rc4
    [2008/03/07 14:47:30 | 000,020,270 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\DeviceInstaller.xml
    [2008/02/18 14:25:26 | 000,031,862 | ---- | C] () -- C:\WINDOWS\System32\RdCi1046.dll
    [2008/02/18 14:25:26 | 000,004,088 | ---- | C] () -- C:\WINDOWS\System32\RD3T1046.DAT
    [2008/02/08 19:34:06 | 000,042,594 | R--- | C] () -- C:\WINDOWS\System32\lvcoinst.ini
    [2008/02/08 19:32:24 | 000,118,784 | R--- | C] () -- C:\WINDOWS\bwUnin-7.2.0.157-8876480SL.exe
    [2008/02/03 17:28:00 | 000,000,032 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\ezsid.dat
    [2007/10/25 17:26:10 | 000,005,632 | ---- | C] () -- C:\WINDOWS\System32\drivers\StarOpen.sys
    [2007/10/10 07:57:29 | 000,000,859 | ---- | C] () -- C:\WINDOWS\{0240BDFB-2995-4A3F-8C96-18D41282B716}_WiseFW.ini
    [2007/08/04 19:33:09 | 000,032,768 | ---- | C] () -- C:\WINDOWS\System32\instlsp.exe
    [2007/08/04 19:03:04 | 000,000,002 | ---- | C] () -- C:\WINDOWS\msoffice.ini
    [2007/06/21 17:39:04 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Application Data\wklnhst.dat
    [2007/06/08 18:02:25 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\YCRWin32.dll
    [2007/06/08 17:59:40 | 000,006,550 | ---- | C] () -- C:\WINDOWS\jautoexp.dat
    [2007/03/12 17:20:33 | 000,000,056 | RHS- | C] () -- C:\WINDOWS\System32\3F6769B316.sys
    [2006/11/15 23:03:12 | 000,024,736 | ---- | C] () -- C:\WINDOWS\System32\drivers\LVPr2Mon.sys
    [2006/11/15 23:00:56 | 001,678,368 | ---- | C] () -- C:\WINDOWS\System32\drivers\Lvckap.sys
    [2006/11/01 17:08:24 | 000,000,092 | R--- | C] () -- C:\WINDOWS\System32\ftdiun2k.ini
    [2006/10/19 13:32:36 | 000,000,133 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\fusioncache.dat
    [2006/10/06 12:15:25 | 000,000,088 | RHS- | C] () -- C:\WINDOWS\System32\16B369673F.sys
    [2006/10/04 11:17:18 | 000,000,023 | ---- | C] () -- C:\WINDOWS\hw32a4.ini
    [2006/10/04 11:17:18 | 000,000,018 | ---- | C] () -- C:\WINDOWS\win32a4.ini
    [2006/10/04 10:54:23 | 000,015,840 | ---- | C] () -- C:\WINDOWS\System32\machnm1.exe
    [2006/10/04 10:14:24 | 000,139,776 | ---- | C] () -- C:\Documents and Settings\Gary Dixon\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2006/09/28 16:17:25 | 000,000,193 | ---- | C] () -- C:\WINDOWS\mswine.ini
    [2006/09/28 15:51:22 | 000,001,344 | ---- | C] () -- C:\WINDOWS\System32\odbcinst.ini
    [2006/09/28 15:49:02 | 000,445,952 | ---- | C] () -- C:\WINDOWS\System32\RepODBC.DLL
    [2006/09/28 15:49:02 | 000,027,136 | ---- | C] () -- C:\WINDOWS\System32\RepRC.DLL
    [2006/09/28 15:37:26 | 000,091,648 | ---- | C] () -- C:\WINDOWS\System32\Mros416.dll
    [2006/09/28 15:05:44 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2006/09/27 15:29:08 | 000,006,580 | -HS- | C] () -- C:\WINDOWS\System32\KGyGaAvL.sys
    [2006/09/21 13:55:43 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
    [2006/09/21 13:44:50 | 000,000,335 | ---- | C] () -- C:\WINDOWS\nsreg.dat
    [2006/09/21 13:42:37 | 000,712,704 | ---- | C] () -- C:\WINDOWS\System32\DellSystemRestore.dll
    [2006/09/21 13:40:04 | 000,000,138 | ---- | C] () -- C:\WINDOWS\wininit.ini
    [2006/09/21 13:35:50 | 000,000,004 | -H-- | C] () -- C:\Documents and Settings\All Users\Application Data\QSLLPSVCShare
    [2006/09/21 13:08:56 | 000,049,152 | ---- | C] () -- C:\WINDOWS\setpwrcg.exe
    [2006/09/21 13:08:46 | 000,016,480 | ---- | C] () -- C:\WINDOWS\System32\rixdicon.dll
    [2006/09/21 13:08:42 | 000,000,474 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
    [2006/05/19 20:49:28 | 004,198,400 | ---- | C] () -- C:\WINDOWS\System32\pm5d-qt-mt333.dll
    [2006/05/19 20:49:24 | 001,265,664 | ---- | C] () -- C:\WINDOWS\System32\pm5d_widgets.dll
    [2006/05/19 20:49:24 | 000,077,824 | ---- | C] () -- C:\WINDOWS\System32\pm5d_utilities.dll
    [2006/05/19 20:49:24 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\pm5d_transport.dll
    [2006/05/19 20:49:22 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\pm5d_memapi.dll
    [2006/05/19 20:49:22 | 000,036,864 | ---- | C] () -- C:\WINDOWS\System32\pm5d_qtoptserver.dll
    [2006/05/19 20:49:20 | 000,659,456 | ---- | C] () -- C:\WINDOWS\System32\pm5d_console.dll
    [2006/04/07 15:02:48 | 004,198,400 | ---- | C] () -- C:\WINDOWS\System32\m7cl-qt-mt333.dll
    [2006/04/07 15:02:48 | 001,310,720 | ---- | C] () -- C:\WINDOWS\System32\m7cl_widgets.dll
    [2006/04/07 15:02:48 | 000,765,952 | ---- | C] () -- C:\WINDOWS\System32\m7cl_console.dll
    [2006/04/07 15:02:48 | 000,077,824 | ---- | C] () -- C:\WINDOWS\System32\m7cl_utilities.dll
    [2006/04/07 15:02:48 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\m7cl_memapi.dll
    [2006/04/07 15:02:48 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\m7cl_transport.dll
    [2006/04/07 15:02:48 | 000,036,864 | ---- | C] () -- C:\WINDOWS\System32\m7cl_qtoptserver.dll
    [2005/04/09 17:04:54 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
    [2005/03/07 18:54:16 | 004,628,480 | ---- | C] () -- C:\WINDOWS\System32\smh-qt-mt333.dll
    [2004/08/10 13:12:05 | 000,000,780 | ---- | C] () -- C:\WINDOWS\orun32.ini
    [2004/08/10 13:07:31 | 000,002,048 | --S- | C] () -- C:\WINDOWS\bootstat.dat
    [2004/08/10 13:02:15 | 000,021,640 | ---- | C] () -- C:\WINDOWS\System32\emptyregdb.dat
    [2004/08/10 13:01:18 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
    [2004/08/10 12:57:52 | 000,004,324 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
    [2004/08/10 12:57:15 | 000,282,128 | ---- | C] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2004/08/10 12:51:21 | 000,004,569 | ---- | C] () -- C:\WINDOWS\System32\secupd.dat
    [2004/08/10 12:51:20 | 000,445,938 | ---- | C] () -- C:\WINDOWS\System32\perfh009.dat
    [2004/08/10 12:51:20 | 000,272,128 | ---- | C] () -- C:\WINDOWS\System32\perfi009.dat
    [2004/08/10 12:51:20 | 000,072,978 | ---- | C] () -- C:\WINDOWS\System32\perfc009.dat
    [2004/08/10 12:51:20 | 000,028,626 | ---- | C] () -- C:\WINDOWS\System32\perfd009.dat
    [2004/08/10 12:51:18 | 000,004,627 | ---- | C] () -- C:\WINDOWS\System32\oembios.dat
    [2004/08/10 12:51:17 | 013,107,200 | ---- | C] () -- C:\WINDOWS\System32\oembios.bin
    [2004/08/10 12:51:16 | 000,000,741 | ---- | C] () -- C:\WINDOWS\System32\noise.dat
    [2004/08/10 12:51:13 | 000,014,336 | ---- | C] () -- C:\WINDOWS\System32\msdmo(2).dll
    [2004/08/10 12:51:12 | 000,673,088 | ---- | C] () -- C:\WINDOWS\System32\mlang.dat
    [2004/08/10 12:51:11 | 000,046,258 | ---- | C] () -- C:\WINDOWS\System32\mib.bin
    [2004/08/10 12:51:05 | 000,218,003 | ---- | C] () -- C:\WINDOWS\System32\dssec.dat
    [2004/08/10 12:50:56 | 000,059,904 | ---- | C] () -- C:\WINDOWS\System32\devenum(2).dll
    [2004/08/10 12:50:56 | 000,001,804 | ---- | C] () -- C:\WINDOWS\System32\dcache.bin
    [1999/03/10 09:23:00 | 000,222,928 | ---- | C] () -- C:\WINDOWS\System32\lobas09.dll
    [1999/03/02 09:23:00 | 000,033,040 | ---- | C] () -- C:\WINDOWS\System32\dbmsspxn.dll
    [1999/03/02 09:23:00 | 000,028,944 | ---- | C] () -- C:\WINDOWS\System32\dbmssocn.dll
    [1998/07/16 19:44:54 | 000,161,792 | ---- | C] () -- C:\WINDOWS\System32\loor813.dll
    [1998/07/14 18:37:42 | 000,168,448 | ---- | C] () -- C:\WINDOWS\System32\loinf13.dll
    [1998/07/14 18:36:12 | 000,180,224 | ---- | C] () -- C:\WINDOWS\System32\loinf913.dll
    [1998/07/14 17:48:32 | 000,135,680 | ---- | C] () -- C:\WINDOWS\System32\lotxt13.dll
    [1998/07/10 19:54:28 | 000,163,328 | ---- | C] () -- C:\WINDOWS\System32\losyb13.dll
    [1998/07/10 19:36:40 | 000,321,024 | ---- | C] () -- C:\WINDOWS\System32\lobas13.dll
    [1998/07/01 18:51:46 | 000,142,848 | ---- | C] () -- C:\WINDOWS\System32\loor713.dll
    [1998/07/01 18:44:24 | 000,114,688 | ---- | C] () -- C:\WINDOWS\System32\lodb213.dll
    [1998/07/01 17:55:38 | 000,147,968 | ---- | C] () -- C:\WINDOWS\System32\loss613.dll
    [1998/07/01 17:54:04 | 000,121,344 | ---- | C] () -- C:\WINDOWS\System32\loidp13.dll
    [1998/07/01 17:43:14 | 000,305,152 | ---- | C] () -- C:\WINDOWS\System32\lodbf13.dll
    [1998/07/01 17:40:10 | 000,346,112 | ---- | C] () -- C:\WINDOWS\System32\loflt13.dll
    [1998/06/10 21:08:40 | 000,015,120 | ---- | C] () -- C:\WINDOWS\System32\Reputil.dll
    [1998/04/27 09:23:00 | 006,150,961 | ---- | C] () -- C:\WINDOWS\System32\jre116.exe
    [1998/01/13 21:52:30 | 000,047,104 | ---- | C] () -- C:\WINDOWS\System32\lotrn13.dll
    [1997/11/14 09:23:00 | 000,031,008 | ---- | C] () -- C:\WINDOWS\System32\ivtrn09.dll
    [1997/02/02 09:23:00 | 000,000,058 | ---- | C] () -- C:\WINDOWS\loss613.ini
    [1997/02/02 09:23:00 | 000,000,058 | ---- | C] () -- C:\WINDOWS\loss09.ini
    [1996/11/17 01:37:00 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\HLINKPRX.DLL
    [1996/07/09 09:23:00 | 000,000,038 | ---- | C] () -- C:\WINDOWS\loidp13.ini
    [1996/01/15 19:12:14 | 000,128,448 | ---- | C] () -- C:\WINDOWS\System32\loss09.dll
    [1994/04/07 09:23:00 | 000,000,462 | ---- | C] () -- C:\WINDOWS\lodbf13.ini
    [2010/10/17 15:52:17 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Birdstep Technology
    [2009/10/08 11:29:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Media
    [2009/08/20 12:40:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PC Suite
    [2007/05/28 20:45:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SingleClick Systems
    [2009/10/07 11:14:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Smaart
    [2011/05/04 22:56:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
    [2010/01/14 10:27:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Trusteer
    [2007/12/01 15:18:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
    [2008/12/26 17:42:39 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Vodafone
    [2009/03/13 18:26:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{00D89592-F643-4D8D-8F0F-AFAE0F14D4C3}
    [2010/05/28 17:29:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{429CAD59-35B1-4DBC-BB6D-1DB246563521}
    [2009/12/04 18:35:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
    [2009/04/17 17:31:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
    [2010/02/26 09:08:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Default User\Application Data\Trusteer
    [2011/04/28 15:56:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\BitTorrent
    [2011/03/21 11:25:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\DDMSettings
    [2011/03/17 16:38:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Downloaded Installations
    [2011/04/28 18:39:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\ElevatedDiagnostics
    [2010/07/06 20:20:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\GARMIN
    [2011/03/02 15:13:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\GetRightToGo
    [2006/09/28 14:54:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Leadertech
    [2009/02/06 14:22:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Mp3tag
    [2009/08/20 12:39:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\PC Suite
    [2011/04/21 13:46:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\PrimoPDF
    [2009/08/20 12:06:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Samsung
    [2011/04/09 16:03:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Smaart
    [2006/09/28 15:39:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Steinberg
    [2011/04/10 17:59:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Thinstall
    [2011/03/17 16:04:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\TiMax2
    [2008/08/09 20:51:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\TomTom
    [2010/01/14 10:33:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Trusteer
    [2007/12/01 15:18:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Viewpoint
    [2006/09/28 16:05:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Visio
    [2008/12/26 17:44:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Gary Dixon\Application Data\Vodafone
    [2010/01/12 17:56:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\SACore
    [2010/01/30 11:30:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Trusteer
    [2008/12/26 17:43:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Vodafone
    [2010/01/18 11:32:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Application Data\Trusteer
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2006/11/28 14:07:10 | 000,007,808 | ---- | M] () -- C:\Act 1.gpk
    [2004/08/10 13:04:08 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
    [2006/09/27 15:18:17 | 000,000,211 | ---- | M] () -- C:\Boot.bak
    [2007/08/13 09:48:11 | 000,006,231 | -H-- | M] () -- C:\cache.dmx
    [2004/08/03 23:00:00 | 000,260,272 | RHS- | M] () -- C:\cmldr
    [2004/08/10 13:04:08 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
    [2006/09/21 13:15:14 | 000,005,642 | RH-- | M] () -- C:\dell.sdr
    [2009/07/15 15:09:19 | 000,000,000 | ---- | M] () -- C:\hpfr3420.xml
    [2009/07/15 15:09:22 | 000,000,502 | ---- | M] () -- C:\hpfr3425.log
    [2006/10/04 12:38:25 | 000,004,128 | ---- | M] () -- C:\INFCACHE.1
    [2004/08/10 13:04:08 | 000,000,000 | -H-- | M] () -- C:\IO.SYS
    [2006/09/21 13:46:25 | 000,000,896 | -H-- | M] () -- C:\IPH.PH
    [2006/11/12 20:23:04 | 000,000,174 | ---- | M] () -- C:\IQ-POINT
    [2010/03/25 09:05:58 | 000,000,147 | ---- | M] () -- C:\LEGO Creator Knights Kingdom Error Log_0.log
    [2011/04/27 11:02:15 | 000,000,109 | ---- | M] () -- C:\mbam-error.txt
    [2004/08/10 13:04:08 | 000,000,000 | -H-- | M] () -- C:\MSDOS.SYS
    [2004/08/04 05:00:00 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
    [2008/11/04 13:01:00 | 000,250,048 | RHS- | M] () -- C:\ntldr
    [2011/05/04 22:48:45 | 792,723,456 | -HS- | M] () -- C:\pagefile.sys
    [2011/05/03 09:03:55 | 000,000,441 | ---- | M] () -- C:\rkill.log
    [2007/11/12 09:05:36 | 000,000,016 | ---- | M] () -- C:\s1d0
    [2007/11/27 08:08:12 | 000,000,016 | ---- | M] () -- C:\s360
    [2007/09/17 14:57:05 | 000,000,000 | ---- | M] () -- C:\s39s
    [2007/09/16 09:26:27 | 000,000,016 | ---- | M] () -- C:\s3jc
    [2007/12/04 13:43:09 | 000,000,016 | ---- | M] () -- C:\s5cs
    [2006/11/09 17:56:08 | 000,000,170 | ---- | M] () -- C:\setup.log
    [2011/05/02 16:54:24 | 000,002,022 | ---- | M] () -- C:\TDSSKiller.2.4.21.0_02.05.2011_16.54.23_log.txt
    [2011/05/02 17:07:34 | 000,002,022 | ---- | M] () -- C:\TDSSKiller.2.4.21.0_02.05.2011_17.07.30_log.txt
    [2011/05/02 17:10:05 | 000,002,022 | ---- | M] () -- C:\TDSSKiller.2.4.21.0_02.05.2011_17.10.00_log.txt
    [2011/05/02 17:11:14 | 000,002,022 | ---- | M] () -- C:\TDSSKiller.2.4.21.0_02.05.2011_17.11.11_log.txt
    [2011/05/02 17:15:42 | 000,002,022 | ---- | M] () -- C:\TDSSKiller.2.4.21.0_02.05.2011_17.15.34_log.txt
    < %systemroot%\Fonts\*.com >
    [2006/04/18 15:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
    [2006/06/29 14:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
    [2006/04/18 15:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
    [2006/06/29 14:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2004/08/10 13:03:42 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    [2008/07/06 13:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
    [2007/04/09 13:23:54 | 000,028,552 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\mdippr.dll
    [2006/10/26 19:56:12 | 000,033,104 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\msonpppr.dll
    [2008/07/06 11:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    [2007/11/23 18:45:33 | 000,001,626 | -H-- | M] () -- C:\Documents and Settings\Gary Dixon\Application Data\Microsoft\LastFlashConfig.WFC
    < %PROGRAMFILES%\*.* >
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    [2004/08/10 12:56:48 | 000,094,208 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
    [2004/08/10 12:56:46 | 000,634,880 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
    [2004/08/10 12:56:46 | 000,872,448 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    [2009/12/01 10:14:28 | 000,000,272 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2006/09/27 15:18:48 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\Gary Dixon\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    [2004/08/10 13:08:38 | 000,000,079 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf
    < %USERPROFILE%\Desktop\*.exe >
    [2011/03/25 14:26:43 | 002,661,254 | ---- | M] (Alexander Vigovsky ) -- C:\Documents and Settings\Gary Dixon\Desktop\ac3filter_1_63b.exe
    [2004/01/06 13:33:04 | 001,578,496 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\DCX-Remote.exe
    [2009/11/24 11:39:46 | 007,744,980 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\FreewarePrimoPDF.exe
    [2009/01/03 18:23:49 | 000,607,640 | ---- | M] (Sun Microsystems, Inc.) -- C:\Documents and Settings\Gary Dixon\Desktop\jre-6u11-windows-i586-p-iftw.exe
    [2007/09/14 18:34:24 | 000,907,624 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Desktop\MM061A12.EXE
    [2011/05/05 00:05:51 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Gary Dixon\Desktop\OTL.exe
    [2010/09/01 15:33:49 | 000,083,968 | ---- | M] (eSage Lab) -- C:\Documents and Settings\Gary Dixon\Desktop\remover.exe
    [2011/03/10 12:27:50 | 001,377,112 | ---- | M] (Kaspersky Lab ZAO) -- C:\Documents and Settings\Gary Dixon\Desktop\TDSSKiller.exe
    [2010/04/24 14:37:13 | 007,845,512 | ---- | M] (Interactive Frontiers ) -- C:\Documents and Settings\Gary Dixon\Desktop\v1home.exe
    [2011/03/15 09:25:41 | 000,652,794 | ---- | M] (Xvid team ) -- C:\Documents and Settings\Gary Dixon\Desktop\XviD-1.2.2-07062009.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    [2010/10/20 23:23:26 | 000,000,698 | ---- | M] () -- C:\WINDOWS\AppPatch\Custom\{a9264802-8a7a-40fe-a135-5c6d204aed7a}.sdb
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    [2008/08/09 20:48:06 | 018,878,872 | ---- | M] (TomTom International B.V.) -- C:\Documents and Settings\Gary Dixon\My Documents\TomTomHOME2winlatest.exe
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    [2004/08/04 05:00:00 | 000,000,791 | ---- | M] () -- C:\WINDOWS\addins\fxsext.ecf
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2006/09/27 15:18:46 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Gary Dixon\Favorites\Desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    [2011/05/05 00:17:10 | 001,114,112 | ---- | M] () -- C:\Documents and Settings\Gary Dixon\Cookies\index.dat
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    [2008/04/14 01:12:38 | 000,208,896 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\inf\unregmp2.exe
    < %SYSTEMROOT%\Installer\*.exe >
    [2006/07/10 00:42:28 | 000,557,056 | ---- | M] (Intel Corporation) -- C:\WINDOWS\Installer\iProInst.exe
    [8 C:\WINDOWS\Installer\*.tmp files -> C:\WINDOWS\Installer\*.tmp -> ]
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    [2008/04/14 01:11:51 | 000,033,792 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\custsat.dll
    [2004/08/04 01:06:34 | 000,004,821 | ---- | M] () -- C:\Program Files\Messenger\logowin.gif
    [2004/08/04 01:06:34 | 000,007,047 | ---- | M] () -- C:\Program Files\Messenger\lvback.gif
    [2008/05/02 15:01:49 | 000,083,968 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgsc.dll
    [2008/04/13 18:30:28 | 000,180,224 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msgslang.dll
    [2008/04/14 01:12:28 | 001,695,232 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Messenger\msmsgs.exe
    [2004/08/04 01:06:36 | 000,002,882 | ---- | M] () -- C:\Program Files\Messenger\newalert.wav
    [2004/08/04 01:06:36 | 000,006,156 | ---- | M] () -- C:\Program Files\Messenger\newemail.wav
    [2004/08/04 01:06:36 | 000,006,160 | ---- | M] () -- C:\Program Files\Messenger\online.wav
    [2004/08/04 01:06:36 | 000,004,454 | ---- | M] () -- C:\Program Files\Messenger\type.wav
    [2004/08/04 01:06:36 | 000,115,981 | ---- | M] () -- C:\Program Files\Messenger\xpmsgr.chm
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    [2004/08/04 05:00:00 | 000,011,776 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system\regsvr32.exe
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    < MD5 for: ATAPI.SYS >
    [2004/08/04 05:00:00 | 018,738,937 | ---- | M] () .cab file -- C:\i386\sp2.cab:atapi.sys
    [2008/11/04 12:55:54 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\$NtServicePackUninstall$\sp3.cab:atapi.sys
    [2004/08/04 05:00:00 | 018,738,937 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp2.cab:atapi.sys
    [2009/12/01 09:50:53 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:atapi.sys
    [2009/12/01 09:50:53 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:atapi.sys
    [2008/04/13 19:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\ServicePackFiles\i386\atapi.sys
    [2008/04/13 19:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\drivers\atapi.sys
    [2004/08/03 22:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\i386\atapi.sys
    [2004/08/03 22:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\$NtServicePackUninstall$\atapi.sys
    [2004/08/03 22:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\system32\ReinstallBackups\0003\DriverFiles\i386\atapi.sys
    ========== Alternate Data Streams ==========
    @Alternate Data Stream - 124 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:BEB71B81
    < End of report >
  18. 2011/05/04
    biggazdixon
    OTL Extras logfile created on: 05/05/2011 00:31:50 - Run 1
    OTL by OldTimer - Version 3.2.22.3 Folder = C:\Documents and Settings\Gary Dixon\Desktop
    Windows XP Home Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
    502.00 Mb Total Physical Memory | 118.00 Mb Available Physical Memory | 24.00% Memory free
    1.00 Gb Paging File | 0.00 Gb Available in Paging File | 41.00% Paging File free
    Paging file location(s): C:\pagefile.sys 756 1512 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 52.68 Gb Total Space | 16.67 Gb Free Space | 31.64% Space Free | Partition Type: NTFS
    Drive D: | 17.21 Gb Total Space | 16.49 Gb Free Space | 95.84% Space Free | Partition Type: NTFS
    Computer Name: GARYDIXON | User Name: Gary Dixon | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    ========== Shell Spawning ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1 ",%*
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [open] -- %SystemRoot%\Explorer.exe /idlist,%I,%L (Microsoft Corporation)
    Folder [explore] -- %SystemRoot%\Explorer.exe /e,/idlist,%I,%L (Microsoft Corporation)
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    ========== Security Center Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "FirstRunDisabled" = 1
    "UpdatesDisableNotify" = 0
    "AntiVirusOverride" = 1
    "FirewallOverride" = 0
    "AntiVirusDisableNotify" = 0
    "FirewallDisableNotify" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    "DisableMonitoring" = 1
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\SystemRestore]
    "DisableSR" = 0
    "DisableConfig" = 0
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Sr]
    "Start" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SrService]
    "Start" = 2
    ========== Firewall Settings ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts\List]
    "139:TCP" = 139:TCP:*:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:*:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:*:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:*:Enabled:mad:xpsp2res.dll,-22002
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    "EnableFirewall" = 0
    "DoNotAllowExceptions" = 0
    "DisableNotifications" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    "1900:UDP" = 1900:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22007
    "2869:TCP" = 2869:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22008
    "10421:UDP" = 10421:UDP:*:Enabled:SingleClick Discovery Protocol
    "10426:UDP" = 10426:UDP:*:Enabled:SingleClick ICC
    "139:TCP" = 139:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22004
    "445:TCP" = 445:TCP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22005
    "137:UDP" = 137:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22001
    "138:UDP" = 138:UDP:LocalSubNet:Enabled:mad:xpsp2res.dll,-22002
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL
    "C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL
    "C:\Program Files\AOL 9.0\waol.exe" = C:\Program Files\AOL 9.0\waol.exe:*:Enabled:AOL
    "C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe" = C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe:*:Enabled:Logitech Desktop Messenger -- (Logitech)
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\Program Files\Yahoo!\Messenger\ypager.exe" = C:\Program Files\Yahoo!\Messenger\ypager.exe:*:Enabled:Yahoo! Messenger
    "C:\Program Files\Yahoo!\Messenger\YServer.exe" = C:\Program Files\Yahoo!\Messenger\YServer.exe:*:Enabled:Yahoo! FT Server
    "C:\Program Files\Real\RealPlayer\realplay.exe" = C:\Program Files\Real\RealPlayer\realplay.exe:*:Enabled:RealPlayer -- (RealNetworks, Inc.)
    "C:\WINDOWS\system32\dpvsetup.exe" = C:\WINDOWS\system32\dpvsetup.exe:*:Enabled:Microsoft DirectPlay Voice Test -- (Microsoft Corporation)
    "C:\Program Files\Meyer Sound\Compass\Resources\Data\VirtualGalileoDaemon.exe" = C:\Program Files\Meyer Sound\Compass\Resources\Data\VirtualGalileoDaemon.exe:*:Enabled:VirtualGalileoDaemon -- ()
    "C:\Program Files\Samsung\Samsung New PC Studio\npsasvr.exe" = C:\Program Files\Samsung\Samsung New PC Studio\npsasvr.exe:*:Enabled:KTF MUSIC AoD Server -- (PeeringPortal)
    "C:\Program Files\Samsung\Samsung New PC Studio\npsvsvr.exe" = C:\Program Files\Samsung\Samsung New PC Studio\npsvsvr.exe:*:Enabled:KTF MUSIC VoD Server -- (PeeringPortal)
    "C:\Program Files\Dell Network Assistant\ezi_hnm2.exe" = C:\Program Files\Dell Network Assistant\ezi_hnm2.exe:*:Enabled:Dell Network Assistant -- (SingleClick Systems)
    "C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe" = C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe:*:Enabled:McAfee Network Agent
    "C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe" = C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe:*:Enabled:McAfee Shared Service Host -- (McAfee, Inc.)
    "C:\Program Files\BitTorrent\BitTorrent.exe" = C:\Program Files\BitTorrent\BitTorrent.exe:*:Enabled:BitTorrent -- (BitTorrent, Inc.)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{0240BDFB-2995-4A3F-8C96-18D41282B716}" = Dell Network Assistant
    "{028E862D-DEEE-4B28-A053-E62A066393DC}" = ZTE Mobile Connect 4.3.28.4451
    "{06BE8AFD-A8E2-4B63-BAE7-287016D16ACB}" = mSSO
    "{075473F5-846A-448B-BCB3-104AA1760205}" = Sonic RecordNow Data
    "{07A95DCF-6FA1-4DD6-B660-708EF71CA5CB}" = YAMAHA PM5D Editor
    "{09CACAC2-6420-11D3-B0C7-00C04FC2B1B9}" = CAD Drawing Converter
    "{0B5E0886-BC91-4E83-BB29-A664ED8F0285}" = Project Schedules Help
    "{0E2B0B41-7E08-4F9F-B21F-41C4133F43B7}" = mLogView
    "{1206EF92-2E83-4859-ACCB-2048C3CB7DA6}" = Sonic DLA
    "{12729386-3E3C-11D3-8F79-00C04F8DD7E3}" = Foundation technical
    "{158619C3-5EF3-11D3-B0C6-00C04FC2B1B9}" = Process Engineering Help
    "{158619C4-5EF3-11D3-B0C6-00C04FC2B1B9}" = Process Engineering
    "{158619C6-5EF3-11D3-B0C6-00C04FC2B1B9}" = Mechanical Engineering Help
    "{158619C7-5EF3-11D3-B0C6-00C04FC2B1B9}" = Mechanical Engineering
    "{158619C9-5EF3-11D3-B0C6-00C04FC2B1B9}" = Fluid Power Help
    "{158619CA-5EF3-11D3-B0C6-00C04FC2B1B9}" = Fluid Power
    "{158619CB-5EF3-11D3-B0C6-00C04FC2B1B9}" = Facilities Management Help
    "{158619CC-5EF3-11D3-B0C6-00C04FC2B1B9}" = Facilities Management
    "{158619CE-5EF3-11D3-B0C6-00C04FC2B1B9}" = Electrical Engineering Help
    "{158619CF-5EF3-11D3-B0C6-00C04FC2B1B9}" = Electrical Engineering
    "{158619D1-5EF3-11D3-B0C6-00C04FC2B1B9}" = Building Services Help
    "{158619D2-5EF3-11D3-B0C6-00C04FC2B1B9}" = Building Services
    "{158619D3-5EF3-11D3-B0C6-00C04FC2B1B9}" = Building Architecture Help
    "{158619D4-5EF3-11D3-B0C6-00C04FC2B1B9}" = Building Architecture
    "{16C586A1-4ACB-11D3-8662-00C04F8DBAD9}" = Release Notes Technical
    "{172ED890-6982-4CCF-BD23-6949E553B860}" = Save as HTML
    "{18455581-E099-4BA8-BC6B-F34B2F06600C}" = Google Toolbar for Internet Explorer
    "{19B29943-2A85-11D3-8F74-00C04F8DD7E3}" = Solutions
    "{1D3C662A-F6C6-4767-A788-7AA43A9A1317}" = ARTEuro
    "{1D66C1EB-9FC0-4363-A4B9-E44DDCBACD00}" = Organization Charts
    "{1DD81E7D-0D28-4CEB-87B2-C041A4FCB215}" = Rapport
    "{21657574-BD54-48A2-9450-EB03B2C7FC29}" = Sonic MyDVD LE
    "{2318C2B1-4965-11d4-9B18-009027A5CD4F}" = Google Toolbar for Internet Explorer
    "{23FB368F-1399-4EAC-817C-4B83ECBE3D83}" = mProSafe
    "{241957BD-4436-42B1-ADCF-AE18144358D7}" = Office Layout
    "{268FC299-C0BD-4230-9D00-FD7BBB71A2C7}" = Organization Charts Help
    "{26A24AE4-039D-4CA4-87B4-2F83216011FF}" = Java(TM) 6 Update 23
    "{26E1BFB0-E87E-4696-9F89-B467F01F81E5}" = Broadcom Management Programs
    "{2A981294-F14C-4F0F-9627-D793270922F8}" = Bonjour
    "{2D329298-7BDD-476B-8F68-AE3F66EB6F8F}" = Flowcharts
    "{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Sonic Update Manager
    "{3248F0A8-6813-11D6-A77B-00B0D0150060}" = J2SE Runtime Environment 5.0 Update 6
    "{3379BB86-49C2-11D3-80AC-00C04F6B854D}" = Network Diagrams Help
    "{3388E964-4C4F-11D3-9F66-006008A88EC8}" = Microsoft Visio 2000 (IE)
    "{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
    "{35725FBC-A136-4A46-9F29-091759D9BB93}" = MVision
    "{380E3211-4549-42B3-8EE8-2B0561530061}" = Custom Properties Editor
    "{3846E811-639D-4DE1-844B-30491C0A6C0C}" = Dell Support 3.2
    "{390927CA-7D1F-44EB-95FF-FBB4B20822B4}" = Borders and Backgrounds Help
    "{3A71AF7E-705C-40D3-9024-B63C00AB1772}" = Program Files Help
    "{3AD21E47-B172-4A88-9821-21A1C5E031BE}" = Fast Track Ultra
    "{3CE4B14A-47A9-4C4F-9E17-3DCD588D3B1C}" = Studio Manager
    "{3E9D596A-61D4-4239-BD19-2DB984D2A16F}" = mIWA
    "{3F92ABBB-6BBF-11D5-B229-002078017FBF}" = NetWaiting
    "{49D687E5-6784-431B-A0A2-2F23B8CC5A1B}" = mHlpDell
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{4F3B07B2-5E86-11D3-B0C6-00C04FC2B1B9}" = Help_Technical
    "{4F3B07B3-5E86-11D3-B0C6-00C04FC2B1B9}" = Annotations Help
    "{4F3B07B4-5E86-11D3-B0C6-00C04FC2B1B9}" = Custom Patterns
    "{4F3B07B5-5E86-11D3-B0C6-00C04FC2B1B9}" = CAD Drawing Converter Samples
    "{4F3B07B6-5E86-11D3-B0C6-00C04FC2B1B9}" = CAD Drawing Converter Help
    "{51196320-99A0-4737-AE71-5BAF9489A855}" = Database Wizard
    "{536D6172-7453-7569-7465-392E36300409}" = Lotus SmartSuite - English
    "{55B39A89-795A-4E9F-AB38-15AB66125914}" = Borders and Backgrounds
    "{57752979-A1C9-4C02-856B-FBB27AC4E02C}" = QuickTime
    "{58B2B6D3-E5FF-4D16-87AC-52CC5717C7C6}" = Tiscali Internet
    "{5BF5F9C5-E95B-4AFA-94BE-F2A9CA73B61D}" = Apple Mobile Device Support
    "{5BF9AE5B-D635-4BB6-9229-F863B28F9107}" = Graphics Filters
    "{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
    "{60692A39-4C61-11D3-A339-006097B6ECD2}" = Program Files
    "{60692A40-4C61-11D3-A339-006097B6ECD2}" = Visio
    "{60C8D1EA-CB39-44FF-BECA-9B1457898C9B}" = Office Layout Help
    "{62E98CB2-2B1E-4E7D-8C3B-F6E7A3CB14E0}" = Network Diagrams
    "{639B050E-9ADC-44C4-B7FE-BA7DB59D4E4B}" = Forms and Charts
    "{63DB9CCD-2B56-4217-9A3D-507AC78320CA}" = mWMI
    "{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD 5.7
    "{6A4EABDC-B3AA-421D-AB8B-5678293C9235}" = Callouts and Connectors Help
    "{6B9B0C6F-E5FA-4633-A640-AB98A272ECCA}" = Safari
    "{6D52C408-B09A-4520-9B18-475B81D393F1}" = Microsoft Works
    "{6ECB39BD-73C2-44DD-B1A0-898207C58D8B}" = HP Photo and Imaging 2.0 - All-in-One Drivers
    "{7299052b-02a4-4627-81f2-1818da5d550d}" = Microsoft Visual C++ 2005 Redistributable
    "{74F7662C-B1DB-489E-A8AC-07A06B24978B}" = Dell System Restore
    "{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    "{79B499B2-B976-4345-A70D-D16A7738DA1A}" = Meyer Sound Compass 2.1.1
    "{7E84FAC8-C518-40F9-9807-7455301D6D25}" = SamsungConnectivityCableDriver
    "{7F142D56-3326-11D5-B229-002078017FBF}" = Modem Helper
    "{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
    "{8A708DD8-A5E6-11D4-A706-000629E95E20}" = Intel(R) Graphics Media Accelerator Driver
    "{8B928BA1-EDEC-4227-A2DA-DD83026C36F5}" = mPfMgr
    "{8F3C31C5-9C3A-4AA8-8EFA-71290A7AD533}" = TomTom HOME Visual Studio Merge Modules
    "{900B1197-53F5-4F46-A882-2CFFFE2EEDCB}" = Logitech Desktop Messenger
    "{90110409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Professional Edition 2003
    "{90120000-0010-0409-0000-0000000FF1CE}" = Microsoft Software Update for Web Folders (English) 12
    "{90120000-0016-0409-0000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2007
    "{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-0018-0409-0000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2007
    "{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-001B-0409-0000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2007
    "{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-001F-0409-0000-0000000FF1CE}" = Microsoft Office Proof (English) 2007
    "{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-001F-040C-0000-0000000FF1CE}" = Microsoft Office Proof (French) 2007
    "{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-001F-0C0A-0000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2007
    "{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
    "{90120000-002C-0409-0000-0000000FF1CE}" = Microsoft Office Proofing (English) 2007
    "{90120000-006E-0409-0000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2007
    "{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-00A1-0409-0000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2007
    "{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90120000-0115-0409-0000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2007
    "{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{90B0D222-8C21-4B35-9262-53B042F18AF9}" = mPfWiz
    "{91120000-002F-0000-0000-0000000FF1CE}" = Microsoft Office Home and Student 2007
    "{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
    "{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
    "{93D1FE53-905C-4EE7-AE18-4B13AC0069AD}" = Shape Explorer Help
    "{94658027-9F16-4509-BBD7-A59FE57C3023}" = mZConfig
    "{95FCC2AB-5D4C-4E6A-BB96-3A80F20D536A}" = Yamaha LS9 Editor
    "{981029E0-7FC9-4CF3-AB39-6F133621921A}" = Skype Toolbars
    "{9867A917-5D17-40DE-83BA-BEA5293194B1}" = HP Photo and Imaging 2.0 - All-in-One
    "{9CC89556-3578-48DD-8408-04E66EBEF401}" = mXML
    "{9EC41026-8399-47E4-9FE9-CFCCCB71F8C3}" = Property Reporting Wizard
    "{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}" = Microsoft .NET Framework 3.0 Service Pack 2
    "{A637F36B-2B36-11D4-A322-0001020A6A3D}" = LEGO Creator Knights' Kingdom
    "{A71D5E81-B967-43DB-93D7-FD31BFB95748}" = MobileMe Control Panel
    "{A8323532-49A2-4055-B424-EEB547E3D02E}" = Project Schedules
    "{A83C5161-8D05-4651-92B2-078BCB1F8378}" = YAMAHA M7CL Editor
    "{A8544EA1-4AF2-11D3-8F7D-00C04F8DD7E3}" = Program Files Technical
    "{a9264802-8a7a-40fe-a135-5c6d204aed7a}.sdb" = Internet Explorer (Enable DEP)
    "{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
    "{AAD47011-8518-4608-9656-951DA35B587B}" = iTunes
    "{AB708C9B-97C8-4AC9-899B-DBF226AC9382}" = Sonic RecordNow Audio
    "{AC0EE5B0-A8FB-4D0A-AF03-2EDC518F841B}" = Dell Media Experience
    "{AC599724-5755-48C1-ABE7-ABB857652930}" = PC Connectivity Solution
    "{AC76BA86-7AD7-1033-7B44-A81200000003}" = Adobe Reader 8.1.2
    "{B06E51F3-D04E-4898-9700-2E48788D5274}" = Clip Art and Symbols
    "{B12665F4-4E93-4AB4-B7FC-37053B524629}" = Sonic RecordNow Copy
    "{B376402D-58EA-45EA-BD50-DD924EB67A70}" = HP Memories Disc
    "{B7AC5A96-C8BC-431C-B661-27A09781DFA8}" = Wanadoo Europe Installer
    "{B80DA153-D56F-4D80-AC29-CEBC8BB263B9}" = Callouts and Connectors
    "{B9EF1B56-2E87-11D3-80A5-00C04F6B854D}" = Maps
    "{BA04FFF0-F3A5-4D48-BD32-003D7E901178}" = Page Layout Wizard
    "{BBE93891-6608-11d3-9F6A-006008A88EC8}" = Help for Visio 2000 (HTML Help)
    "{BBE93894-6608-11d3-9F6A-006008A88EC8}" = Microsoft Repository
    "{BBE93897-6608-11d3-9F6A-006008A88EC8}" = Visio Technical Core Files
    "{BEF726DD-4037-4214-8C6A-E625C02D2870}" = Logitech Audio Echo Cancellation Component
    "{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}" = Microsoft .NET Framework 2.0 Service Pack 2
    "{C41300B9-185D-475E-BFEC-39EF732F19B1}" = Apple Software Update
    "{C5074CC4-0E26-4716-A307-960272A90040}" = QuickSet
    "{C5E69312-4354-11D3-B0BC-00C04FC2B1B9}" = CAD Drawing Display
    "{c8f38ee3-4204-4fab-bbb7-0d37f47cc71e}" = MATLAB Component Runtime 7.5
    "{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}" = Microsoft .NET Framework 1.1
    "{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
    "{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.2
    "{D2988E9B-C73F-422C-AD4B-A66EBE257120}" = MCU
    "{D2D89191-1BB5-42BF-863D-991347B36641}" = Block Diagrams
    "{D537C817-BF8E-4746-9E1E-E2A67DAECE4E}" = Add-ons
    "{D8CE69B0-9274-4b8c-BA49-0FF6A20A3C65}" = SAMSUNG SYMBIAN USB Download Driver
    "{D982E7B4-4C62-11D3-A339-006097B6ECD2}" = Visio Core Files
    "{DFB8D937-5CC3-4555-9150-90E57459AF00}" = Block Diagrams Help
    "{DFE81EB6-0287-4DFF-AE7D-14E664586905}" = Clip Art and Symbols Help
    "{E2057EE6-A559-40E3-AF8B-437866E0EDA9}" = Flowcharts Help
    "{E43E1F22-3549-11D5-AAEA-0000F4AE6617}" = PM1D Manager
    "{E44BD710-B71A-11d3-9F79-006008A88EC8}" = VBA
    "{E54E90A0-5A93-11D3-9600-00500458AEC8}" = Annotations
    "{E646DCF0-5A68-11D5-B229-002078017FBF}" = Digital Line Detect
    "{E75594A0-B088-4635-B4F6-99654B5DDF96}" = V1 Home 2.0
    "{E7DE3D60-3FB8-11D3-8F79-00C04F8DD7E3}" = Developing Visio Solutions Help
    "{E81667C6-2856-46D6-ABEA-6A2F42166779}" = mCore
    "{E8814A8F-3B06-11D3-8CD7-00C04F72C04D}" = Microsoft Visual Studio Service Pack 3
    "{EA516024-D84D-41F1-814F-83175A6188F2}" = Logitech Video Enumerator
    "{EE6097DD-05F4-4178-9719-D3170BF098E8}" = Apple Application Support
    "{F0BFC7EF-9CF8-44EE-91B0-158884CD87C5}" = mMHouse
    "{F193FC0E-9E18-40FC-A974-509A1BDD240A}" = Samsung New PC Studio
    "{F28D0D4C-D522-43B1-9700-C896A76C6130}" = Maps Help
    "{F6090A17-0967-4A8A-B3C3-422A1B514D49}" = mDrWiFi
    "{F7C0163D-9CD8-4F5F-BAC8-3E45A0000AFF}" = Vodafone Mobile Connect Lite Huawei
    "{FC588207-9B40-4800-92AD-EB4D48FB7726}" = Forms and Charts Help
    "{FC9DEDBD-3610-4D1F-88CB-A6519DCB2154}" = Logitech QuickCam
    "{FCA651F3-5BDA-4DDA-9E4A-5D87D6914CC4}" = mWlsSafe
    "3A5DEFA413DDE699DBA6EBE0A63534ACA524D30F" = Windows Driver Package - Nokia pccsmcfd (10/12/2007 6.85.4.0)
    "6194C28A8F62DD817EA1B918E6E46E806A21B452" = Windows Driver Package - MobileTop (sshpmdm) Modem (02/23/2007 2.5.0.0)
    "65B6FE5418CE28F4D72543FB2D964C3CEC83F161" = Windows Driver Package - MobileTop (sshpusb) USB (02/23/2007 2.5.0.0)
    "AC3File_is1" = AC3File 0.7b
    "AC3Filter_is1" = AC3Filter 1.63b
    "Adobe Acrobat 4.0" = Adobe Acrobat 4.0
    "Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
    "BitTorrent" = BitTorrent
    "CNXT_MODEM_HDAUDIO_VEN_14F1&DEV_2BFA&SUBSYS_14F100C3" = Conexant HDA D110 MDC V.92 Modem
    "CTMBDemo_Audigy" = Sound Blaster Audigy ADVANCED MB Demo
    "DivX Setup.divx.com" = DivX Setup
    "FTDICOMM" = FTDI USB Serial Converter Drivers
    "HOMESTUDENTR" = Microsoft Office Home and Student 2007
    "hp instant support" = hp instant support
    "Huawei Modems" = Huawei modem
    "IDNMitigationAPIs" = Microsoft Internationalized Domain Names Mitigation APIs
    "ie7" = Windows Internet Explorer 7
    "ie8" = Windows Internet Explorer 8
    "InstallShield_{07A95DCF-6FA1-4DD6-B660-708EF71CA5CB}" = YAMAHA PM5D Editor
    "InstallShield_{3CE4B14A-47A9-4C4F-9E17-3DCD588D3B1C}" = YAMAHA Studio Manager
    "InstallShield_{95FCC2AB-5D4C-4E6A-BB96-3A80F20D536A}" = Yamaha LS9 Editor
    "InstallShield_{A83C5161-8D05-4651-92B2-078BCB1F8378}" = YAMAHA M7CL Editor
    "InstallShield_{E75594A0-B088-4635-B4F6-99654B5DDF96}" = V1 Home 2.0
    "InstallShield_{F193FC0E-9E18-40FC-A974-509A1BDD240A}" = Samsung New PC Studio
    "Lotus NotesSQL 2.06 driver" = Lotus NotesSQL 2.06 driver
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes' Anti-Malware
    "Microsoft .NET Framework 1.1 (1033)" = Microsoft .NET Framework 1.1
    "Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
    "Microsoft_Wine_Guide" = Microsoft Wine Guide Version 2.0
    "MIXERLITE" = Mixer
    "Mp3tag" = Mp3tag v2.42
    "MSC" = BT NetProtect Plus
    "NLSDownlevelMapping" = Microsoft National Language Support Downlevel APIs
    "PrimoPDF" = PrimoPDF -- by Nitro PDF Software
    "ProInst" = Intel(R) PROSet/Wireless Software
    "QcDrv" = Logitech® Camera Driver
    "Rapport_msi" = Rapport
    "RealPlayer 6.0" = RealPlayer Basic
    "SAMSUNG Mobile Composite Device" = SAMSUNG Mobile Composite Device Software
    "SAMSUNG Mobile Modem" = SAMSUNG Mobile Modem Driver Set
    "Samsung Mobile Modem Device" = Samsung Mobile Modem Device Software
    "Samsung Mobile phone USB driver" = Samsung Mobile phone USB driver Software
    "SAMSUNG Mobile USB Modem" = SAMSUNG Mobile USB Modem Software
    "SAMSUNG Mobile USB Modem 1.0" = SAMSUNG Mobile USB Modem 1.0 Software
    "SAMSUNG USB Mobile Device" = SAMSUNG USB Mobile Device Software
    "SearchAssist" = SearchAssist
    "Smaart 6_is1" = Smaart 6.1.0.0
    "Sound Cue System 10_is1" = SCS 10.7.5
    "Steinberg Cubase VST 32 5.0r3" = Steinberg Cubase VST 32 5.0r3
    "Steinberg WaveLab v4.0d" = Steinberg WaveLab v4.0d
    "StreetPlugin" = Learn2 Player (Uninstall Only)
    "SynTPDeinstKey" = Synaptics Pointing Device Driver
    "TomTom HOME" = TomTom HOME 2.8.1.2218
    "US-122" = US-122
    "US122 Driver_is1" = US122 Driver 3.40
    "USB_AUDIO_DEusb-audio.deTascam" = US-122L / US-144 driver
    "ViewpointMediaPlayer" = Viewpoint Media Player
    "Wdf01009" = Microsoft Kernel-Mode Driver Framework Feature Pack 1.9
    "WIC" = Windows Imaging Component
    "Windows Media Format Runtime" = Windows Media Format Runtime
    "Windows XP Service Pack" = Windows XP Service Pack 3
    "WinRAR archiver" = WinRAR 4.00 beta 5 (32-bit)
    "Xvid_is1" = Xvid 1.2.2 final uninstall
    "ZTEIcera_4.3.28.4451" = ZTEIcera_4.3.28.4451
    ========== HKEY_USERS Uninstall List ==========
    [HKEY_USERS\S-1-5-21-2592819520-711945795-1137024296-1006\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "MAPP Online Pro" = MAPP Online Pro
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 02/05/2011 17:35:18 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Description = Faulting application svchost.exe, version 5.1.2600.5512, faulting
    module unknown, version 0.0.0.0, fault address 0x001a6f64.
    Error - 02/05/2011 17:58:32 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 03/05/2011 01:47:43 | Computer Name = GARYDIXON | Source = McLogEvent | ID = 5051
    Description = A thread in process C:\Program Files\Common Files\McAfee\SystemCore\mcshield.exe
    took longer than 90000 ms to complete a request. The process will be terminated.
    Thread
    id : 5368 (0x14f8) Thread address : 0x7C90E514 Thread message : Build VSCORE.14.2.0.794
    / 5400.1158 Object being scanned = \Device\HarddiskVolume2\Program Files\Steinberg\Wavelab\WaveLab.exe
    by C:\WINDOWS\Explorer.EXE 4(0)(0) 4(0)(0) 7200(0)(0) 7595(0)(0) 7005(0)(0) 7004(0)(0)
    5006(0)(0) 5004(0)(0)
    Error - 03/05/2011 02:09:33 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 03/05/2011 03:10:19 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 03/05/2011 04:24:06 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 04/05/2011 16:07:00 | Computer Name = GARYDIXON | Source = Application Error | ID = 1004
    Description = Faulting application svchost.exe, version 0.0.0.0, faulting module
    unknown, version 0.0.0.0, fault address 0x00000000.
    Error - 04/05/2011 16:14:04 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 04/05/2011 17:33:30 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    Error - 04/05/2011 17:59:15 | Computer Name = GARYDIXON | Source = Application Error | ID = 1000
    [ OSession Events ]
    Error - 10/04/2011 13:04:57 | Computer Name = GARYDIXON | Source = Microsoft Office 12 Sessions | ID = 7001
    Description = ID: 10, Application Name: Microsoft Office Visio, Application Version:
    12.0.4518.1014, Microsoft Office Version: 12.0.4518.1014. This session lasted 322
    seconds with 300 seconds of active time. This session ended with a crash.
    [ System Events ]
    Error - 04/05/2011 18:01:27 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7011
    Description = Timeout (30000 milliseconds) waiting for a transaction response from
    the Browser service.
    Error - 04/05/2011 18:01:57 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7011
    the BITS service.
    Error - 04/05/2011 18:01:57 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7000
    Description = The Background Intelligent Transfer Service service failed to start
    due to the following error: %%1053
    Error - 04/05/2011 18:02:27 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7011
    the Themes service.
    Error - 04/05/2011 18:02:27 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7000
    Description = The Themes service failed to start due to the following error: %%1053
    Error - 04/05/2011 18:02:57 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7011
    the w32time service.
    Error - 04/05/2011 18:02:57 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7000
    Description = The Windows Time service failed to start due to the following error:
    %%1053
    Error - 04/05/2011 18:02:57 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7032
    Description = The Service Control Manager tried to take a corrective action (Restart
    the service) after the unexpected termination of the Windows Management Instrumentation
    service, but this action failed with the following error: %%1056
    Error - 04/05/2011 18:54:54 | Computer Name = GARYDIXON | Source = Service Control Manager | ID = 7032
    Error - 04/05/2011 18:56:53 | Computer Name = GARYDIXON | Source = DCOM | ID = 10010
    Description = The server {E60687F7-01A1-40AA-86AC-DB1CBF673334} did not register
    with DCOM within the required timeout.
    < End of report >
  19. 2011/05/04
    Download BlitzBlank and save it to your desktop.
    Double click on Blitzblank.exe
    • Click OK at the warning (and take note of it, this is a VERY powerful tool!).
    • Click the Script tab and copy/paste the following text there:
    CopyFile:
    C:\i386\atapi.sys C:\WINDOWS\system32\drivers\atapi.sys
    • Click Execute Now. Your computer will need to reboot in order to replace the files.
    • When done, post the report created by Blitzblank.
      You can find it in the root of the drive, normally C:\
    When done....
    Please download SystemLook from one of the links below and save it to your Desktop.
    Download Mirror #1
    Download Mirror #2
    64-bit users go HERE
    • Double-click SystemLook.exe to run it.
    • Vista\Win 7 users:: Right click on SystemLook.exe, click Run As Administrator
    • Copy the content of the following box into the main textfield:
      :filefind
      atapi.sys
    • Click the Look button to start the scan.
    • When finished, a notepad window will open with the results of the scan. Please post this log in your next reply.
    Note: The log can also be found on your Desktop entitled SystemLook.txt
  20. 2011/05/04
    biggazdixon
    biggazdixon Well-Known Member Thread Starter
    I've run Blitzbank and it's now been on the page saying 'Windows is shutting down... for about 15 mins with no sign of activity. Is this normal?
  21. 2011/05/04
    biggazdixon
    I need to go to bed I'm afraid, I'll see how it has got on in the morning.
