Resolved Firefox navigation issue
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Lukeno1, 2011/02/06.
  1. 2011/02/06
    Lukeno1
    Lukeno1 Well-Known Member Thread Starter
    After Lunascape's update has rendered it with amnesia and left it unable to reload the previous session's tabs, I'm back using FF. However, when opening a new tab and attempting to go to a webpage, pressing Enter does absolutely nothing whatsoever, apart from close the quick-search dialogue. However, pressing enter in the link bar in an existing tab with a webpage open, or the search bar, always works.
    Any ideas as to what the hell is going on? :D I have version 3.6.13.
  2. 2011/02/06
    I suggest contacting Lunascape support or their forums.
    Also, try installing the earlier Lunascape version, it appears its update made changes that altered your existing browsers.
    You could also try uninstalling and reinstalling FF.
    Lukeno1
    Well, I've fixed Lunascape by reverting to an older version and disabling auto-update.
    Is there a way to disable the auto-update in Google Chrome? anyway, this issue is resolved.
  5. 2011/02/09
    Please mark this post as "resolved ".
    re Chrome:
    Chrome update has several locations that may be turned OFF: Windows Services, registry locations.
  6. 2011/02/09
    Lukeno1
    It had already been marked as resolved xD and OK, thanks for the info on Chrome. :)
