Resolved Firefox bookmarks and sync question
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by basketcase, 2022/06/22.
  1. 2022/06/22
    basketcase Contributing Member
    basketcase Well-Known Member Thread Starter
    I've been using Firefox for so long, and have moved it to a different computer so many times that I've lost track of which unit I started with.
    So how does one determine which computer is the dominate computer when using Firefox?
    Earlier this year I retired and want to clean up the installation and the bookmarks and then sync it to my laptop so they are a mirror of each other.
    Thanks in advance!
  2. 2022/06/22
    Click the three little - that are over the top of one another near the top right. Go to Help, About FF and it will tell you what version you have. It updates pretty regular.
    Under > Help > More Troubleshooting info > Update History > might show when you first started it.
    As MrBill stated, it will update if it's been set originally to Download and Update Auto.
    My FF is currently on Version 101.0.1 (64bit).
    MrBill likes this.
  5. 2022/06/23
    Christer
    Christer Geek Member Staff
    I believe that basketcase wants to know about syncing bookmarks. I asked a similar question a while back. Check out this old thread:
    Firefox Sync
  6. 2022/06/23
    Thanks to all for the feedback.
    And this one gets at the meat of the question -
    Christer likes this.
