Fatal Execution Engine error (0x7927e03e)
Discussion in 'Windows XP' started by Eleanor316, 2006/03/06.
  1. 2006/03/06
    Eleanor316
    Eleanor316 Well-Known Member Thread Starter
    Windows XP SP1
    NAV scan & AdAware scan revealed no problems. Windows XP updates done
    When attempting to download drivers from a Gateway site I get this error message
    and can't download drivers. Have searched BBS and knowledge bases -unable to find a solution.
    I need to download new drivers as both my CD-ROM and Cd-RW drives apparently have corrupted drivers, but that's a whole other problem.
    Please help
  2. 2006/03/07
    This is a .NET error.
    So I suggest you uninstall/reinstall Microsoft .NET
    You can get it from Windows Update.
    Eleanor316
    Do I really need Microsoft.net? What would happen if I uninstalled and didn't re-install it?
  5. 2006/03/07
    Not necessarily, but there are some programs which now require .Net to function. If you uninstall .Net and have a program which requires it you should get a popup dialogue advising that .Net is required.
  6. 2006/03/07
    Eleanor316
    Tried to uninstall MS.net - couldn't do it. Also couldn't install the update for Ms.Net. I've given up on it. Thanks anyway.
  7. 2006/03/08
    skeet6961
    skeet6961 Inactive
    install sp2
