Solved Fake anti-virus scan and cant start applications
Discussion in 'Malware and Virus Removal Archive' started by ldaoust, 2012/01/11.
  1. 2012/01/12
    ldaoust
    ldaoust Inactive Thread Starter
    SecurityCheck
    Results of screen317's Security Check version 0.99.24
    Windows XP Service Pack 3 x86
    Internet Explorer 8
    Antivirus/Firewall Check:
    Windows Firewall Enabled!
    Microsoft Security Essentials
    Antivirus up to date!
    Anti-malware/Other Utilities Check:
    Spybot - Search & Destroy
    Windows Defender
    Windows Defender Signatures
    CCleaner (remove only)
    Java(TM) 6 Update 30
    Java(TM) 6 Update 7
    Java 2 Runtime Environment, SE v1.4.2
    Out of date Java installed!
    Adobe Flash Player 11.1.102.55
    Mozilla Firefox (x86 en-US..)
    Mozilla Thunderbird (2.0.0) Thunderbird Out of Date!
    Process Check:
    objlist.exe by Laurent
    Windows Defender MSMpEng.exe
    Microsoft Security Essentials msseces.exe
    Louis Daoust Desktop Virus & Spyware Tools Scan Tools\SecurityCheck.exe
    Microsoft Security Client Antimalware MsMpEng.exe
    ``````````End of Log````````````
  2. 2012/01/12
    ldaoust
    Farbar
    Farbar Service Scanner
    Ran by Louis Daoust (administrator) on 12-01-2012 at 09:29:17
    Microsoft Windows XP Professional Service Pack 3 (X86)
    Boot Mode: Normal
    Internet Services:
    Connection Status:
    Localhost is accessible.
    LAN connected.
    Google IP is accessible.
    Yahoo IP is accessible.
    Windows Firewall:
    Firewall Disabled Policy:
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "EnableFirewall "=DWORD:0
    System Restore:
    System Restore Disabled Policy:
    Security Center:
    Windows Update:
    File Check:
    C:\WINDOWS\system32\dhcpcsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\afd.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\netbt.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\tcpip.sys => MD5 is legit
    C:\WINDOWS\system32\Drivers\ipsec.sys => MD5 is legit
    C:\WINDOWS\system32\dnsrslvr.dll => MD5 is legit
    C:\WINDOWS\system32\ipnathlp.dll => MD5 is legit
    C:\WINDOWS\system32\netman.dll => MD5 is legit
    C:\WINDOWS\system32\wbem\WMIsvc.dll => MD5 is legit
    C:\WINDOWS\system32\srsvc.dll => MD5 is legit
    C:\WINDOWS\system32\Drivers\sr.sys => MD5 is legit
    C:\WINDOWS\system32\wscsvc.dll => MD5 is legit
    C:\WINDOWS\system32\wuauserv.dll => MD5 is legit
    C:\WINDOWS\system32\qmgr.dll => MD5 is legit
    C:\WINDOWS\system32\es.dll => MD5 is legit
    C:\WINDOWS\system32\cryptsvc.dll => MD5 is legit
    C:\WINDOWS\system32\svchost.exe => MD5 is legit
    C:\WINDOWS\system32\rpcss.dll => MD5 is legit
    C:\WINDOWS\system32\services.exe => MD5 is legit
    Extra List:
    Gpc(6) IPSec(4) NetBT(5) Tcpip(3) VPCNetS2(9)
    0x080000000400000001000000020000000300000005000000060000000700000009000000
    IpSec Tag value is correct.
    **** End of log ****
    ldaoust
    About to start ESET...will take sometime to finish.
  5. 2012/01/12
    ldaoust
    Eset
    C:\Documents and Settings\Louis Daoust\My Documents\23yiT0mQF.exe a variant of Win32/Kryptik.YRJ trojan cleaned by deleting - quarantined
    C:\Download\a-um2623.zip probably a variant of Win32/Agent.CYTJOWE trojan deleted - quarantined
    C:\Qoobox\Quarantine\C\WINDOWS\system32\Drivers\mrxsmb.sys.vir a variant of Win32/Rootkit.Kryptik.HD trojan cleaned by deleting - quarantined
  6. 2012/01/12
    Uninstall:
    Java(TM) 6 Update 7
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. (Windows XP only) Run defrag at your convenience.
    11. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    12. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    13. Please, let me know, how your computer is doing.
  7. 2012/01/12
    ldaoust
    Not sure how to uninstall 'Java(TM) 6 Update 7' as it is not showing up in 'Add/Remove Programs'.
    OTL
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Default User
    User: dhebert
    User: INFO01-A
    User: ldaoust
    User: LocalService
    User: Louis Daoust
    ->Temp folder emptied: 33294 bytes
    ->Temporary Internet Files folder emptied: 14073716 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 19667255 bytes
    ->Google Chrome cache emptied: 0 bytes
    ->Flash cache emptied: 456 bytes
    User: NetworkService
    ->Temp folder emptied: 5752 bytes
    User: postgres
    Windows Temp folder emptied: 4595 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 32.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: dhebert
    User: INFO01-A
    User: ldaoust
    User: LocalService
    User: Louis Daoust
    User: postgres
    [EMPTYJAVA]
    User: Administrator
    User: All Users
    User: Default User
    User: dhebert
    User: INFO01-A
    User: ldaoust
    User: LocalService
    User: Louis Daoust
    User: postgres
    Total Java Files Cleaned = 0.00 mb
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.31.0 log created on 01122012_150744
  8. 2012/01/12
    Leave it alone then.
  9. 2012/01/12
    ldaoust
    ok and thank you very much again for your help!
    Computer seems to be doing ok.
    After a reboot I seem to always get a crash of 'jusched.exe' (java updater). I was not having this issue before. I guess I can deactivate it, but is there a better cure for that ? (uninstall/re-install ?)
  10. 2012/01/12
