Excel Sum Function Not Working Correctly
Discussion in 'Other PC Software' started by rtstanley, 2004/08/04.
  1. 2004/08/04
    rtstanley
    rtstanley Inactive Thread Starter
    81
    Raleigh, NC
    Computer Experience:
    Intermediate
    Are there any Excel experts out there that would like to have a look?
    I have rows and columns. If I add the columns up manually in a formula (e.g. A1+A2+A3+A4+A5, etc) the result is correct. However, if I use the SUM function (e.g. =SUM(A1:A5), the results are not correct. I have the same sort of problem when summing rows. Please HELP! Looks like an excel bug to me. I would be happy to send a small excel file to someone if they care to take a look. Thanks as always!
  2. 2004/08/05
    ReggieB
    ReggieB Inactive Alumni
    608
    Worcs. UK
    Unabashed deviant
    Which version of Excel? I can't believe that such a commonly used function would fail so obviously - I think it is probably something wrong with your installation or coruption in the sheet.
    merlin
    merlin Inactive
    206
    par
    Strange ! Do the cells you add have different decimal sizes, different numerical sizes ? Have you any "automate" options set ? Are the fields
    you add up on the same worksheet/workbook ?
    regards
  5. 2004/08/05
    merlin
    merlin Inactive
    206
    par
    Just had another thought on this.
    If you set a cell to =Sum(A1:A4) - is correct ?
    Or =Sum(A2:A5) is OK ? and so on ... (A4:A5) ....
    Trying to see if a cell is corrupted ...
    regards
  6. 2004/08/05
    ReggieB
    608
    Worcs. UK
    Unabashed deviant
    Nice direction you're going in Merlin. If the cells are different formats you may get some odd results - especially if one is a date or time.
    Following on from Merlin, Copy the cells you are adding up. Then right click in an empty area of sheet and select "Paste Special ". Select to paste values only. Then try to sum the pasted values. What do you get then?
    Also just create a line of five cells and put a "1" in each cell. Then SUM those cells. Do you get 5? If not there's something wrong with your Excel install.
    SUM is a function - just a predefined function as opposed to user define function. It is possible it has become corupted. If so a reinstall of Office might fix it. If that doesn't it is a case of tracking down the root template, deleting that and reinstalling I think.
  7. 2004/08/06
    rtstanley
    81
    Raleigh, NC
    Intermediate
    I figured out my problem. I had actually created another spreadsheet from a text file (comma delimited). As I stepped through the excel screens, I inadvertently set one of the column formats as text only. When you cut-n-paste this into another spreadsheet, it "looks" like numbers in the cells - but excel treats the cell as text. If you double-click each cell, then hit carriage return, the cell converts to number (actually general).
    Sorry for wasting some of your time. I love this usergroup.
  8. 2004/08/07
    merlin
    merlin Inactive
    206
    par
    Hi, pleased you solved the problem and thanks for posting back.
    No need to be sorry about wasting anyone's time - it was a problem,
    it got solved and we are all the wiser !
    regards
