Resolved Ethernet Splitter Question
Discussion in 'Networking (Hardware & Software)' started by James Martin, 2010/06/01.
  1. 2010/06/07
    Scott Smith
    Scott Smith Inactive Alumni
    Those are private addresses. It doesnt matter if you put it up on a billboard out in front of your house.
    They are non routable addresses on the internet.
    If it starts with a 192. or a 10. you can post it all you want.
    Any of those switches will work.
    I like to stick with Netgear or Dlink but that's just me.
  2. 2010/06/07
    Hi James, I've been intrigued by your Post. I have a Thompson Wireless Modem V7 Model: TH-TG585V7 supplied by Telecom NZ which is ADSL2 capable. It has 4 Ethernet connectors - embedded firewall and I have 5 computers currently able to surf the web.
    I have an Excel 4 connector ethernet switch which allows me to connect a total of 7 computers to the Internet at once.
    I also have a USB 2.0 Host link which enables me to transfer files an data between two computers. Link:http://www.digitus.info/pt/productos/accessories/?c=1216&p=3597
    Total cost of this equipment was less than $200.00NZD.
    This was a simple hook up that an old fuddy duddy like me was able to work out. I'm throwing this in as food for thought. Cheers Neil.:D
    ps. My laptop runs with wireless Lan PCMCIA adapter through the same Thompson Modem.;)
    James Martin likes this.
    Paulfmco
    Paulfmco Inactive
    Just my .02; you might get better internet performance by using OpenDNS servers @208.67.222.222 primary,and 208.67.220.220 secondary as opposed to the Bell South servers you list above
  5. 2010/06/08
    James Martin
    James Martin Geek Member Thread Starter
    Thanks, I ordered the Dlink for 19.99.
    I guess I'll have to roundup a cable here somewhere. Maybe the local mom & pop computer repair store has a few used ones in stock.
    Many thanks for your help, too!
  6. 2010/06/08
    James Martin
    Thanks, retired. I'll have a lot to learn about networking.
    I'll study up on this.
  7. 2010/06/08
    James Martin
    Is that listed under Connection Configuration in the Expert mode?
    All I see now is (Primary) 0.0.0.0 and (Secondary) 0.0.0.0
  8. 2010/06/08
    Scott Smith
    James,
    I wish you were closer. I throw away patch cords I have so many. :D
    I just shake my head when I walk in places like Best Buy and they get 13 bucks for a patch cord. I pay 99 cents for 3' patch cords with boots.
  9. 2010/06/08
    James Martin
    I learned a long time ago to look for used parts in good condition, or check with nearest mom & pop computer store for screws, IDE cables, etc.
    I have a friend who paid about 40.00 for a USB printer cable (not recently), after I found a multi-pack for 6.00 at Sam's Club. Needless to say, he returned the Best Buy cable.
    Rose's discount store has some computer cables made by Philips. I bought a USB extension cord there for only 3.00. I had previously purchased a similar unbranded cord at Dollar Tree, but the transfer rates were poor.
  10. 2010/06/09
    James Martin
    Sorry, I don't fully understand what you are saying, much less how to do it.
  11. 2010/06/11
    James Martin
    Ok, my Dlink switch came in today, so after I hooked up everything I figured out how to change servers. Not sure if it made much of a difference, but the download speeds at PC Pitstop were a tad higher.
    Networking these two computers together is harder than I thought it would be. I'm still searching for a clear cut tutorial to walk me through it.
  12. 2010/06/11
  13. 2010/06/11
    James Martin
    Thanks retired. I stumbled upon that site just before you responded.
    Out of confusion I created two different network (groups?). One on my PC, and one on the second PC.
    I can see both work groups on each computer, but I am getting access denied errors on each machine. How can I remove / delete these groups and start over?
  14. 2010/06/11
  15. 2010/06/11
    James Martin
    Thanks again retired. :)
    I managed to fix the unwanted network group issues for now, and after adding a couple of trusted zones to Zone Alarm I am now able to access shared files and folders in both PCs. :D Still, I would like to access more than just those folders.
    How does mapping a network drive play into this? Am I supposed to use this feature to access a partition, or do I just grant access rights to the same?
  16. 2010/06/11
    Need a bit more help with this one James. Hopefully someone with more expertise will answer your question. Neil.
  17. 2010/06/12
    On any computer, right click a folder and select Sharing Tab. You can share any directory you want. By default the only folders that get shared are the Shared Documents folders.
  18. 2010/06/13
    James Martin
    Right.
    Seems simple enough, but I am intrigued about mapping a drive (or folder I guess). I hope to find some interesting articles on the subject.
  19. 2010/06/13
    Mapping a drive is simple having a network share "appear" as a drive in My Computer. You have a C:\ and each mapped drive shows up as successive drive letters.
    Mapping a network drive
  20. 2010/06/13
    James Martin
    At first I was going to use the wizard setting to *not* share folders & printers, and then I was going to find certain folders and share them by changing their properties...however, I was warned that going this route might jeopardize my computer's security.
    Why the warning? If I am going to share folders, should I use the wizard for this, or does it matter?
  21. 2010/06/16
    James Martin
    ***bump***
    I have marked this thread as resolved, but if anyone wants to answer my last question then that's fine.
    Many thanks to all!
