Solved Ebay log-in asking for credit card info.
Discussion in 'Malware and Virus Removal Archive' started by a1b2c3, 2010/03/26.
  1. 2010/03/30
    a1b2c3
    a1b2c3 Inactive Thread Starter
    It's still bring up the same page asking for personal financial information.
  2. 2010/03/30
    What browser/version do you use?
    Did you try another browser to see, if same thing happens?
    a1b2c3
    Using internet explorer 8. I havent tried another browser. But I've open ebay on another computer with no problem.
    I was wondering what spyware, malware, antivirus you use on your computer?
  5. 2010/03/30
    On different Windows installations, I use combinations of Avast, Avira and Comodo, plus Malwarebytes and Superantispyware.
    I just noticed something....
    Download and save HelpAsst_mebroot_fix.exe to your desktop.
    • Close all open programs.
    • Double click HelpAsst_mebroot_fix.exe to run it.
    • Pay attention to the running tool.
    • If the tool detects mbr infection, please allow it to run mbr -f and shutdown your computer. To do so, type Y and press Enter.
    • After restart, wait 5 minutes, then go Start>Run, copy and paste the following command in the run box then hit Enter:
      • helpasst -mbrt
    • When it completes, a log will open.
    • Please post the contents of that log.
    IMPORTANT!
    If the tool does NOT detect any mbr infection and completes, proceed with the following...
    • Click Start>Run and copy and paste the following command, then hit Enter:
      • mbr -f
    • Repeat the above step one more time
    • Now shut down the computer (do not restart, but shut it down), wait 5 minutes then start it back up.
    • Wait another 5 minutes, then click Start>Run and copy and paste the following command, then hit Enter.
      • helpasst -mbrt
    **Important note to Dell users - fixing the mbr may prevent access the the Dell Restore Utility, which allows you to press a key on startup and revert your computer to a factory delivered state. There are a couple of known fixes for said condition, though the methods are somewhat advanced. If you are unwilling to take such a risk, you should not allow the tool to execute mbr -f nor execute the command manually, and you will either need to restore your computer to a factory state or allow your computer to remain having an infected mbr (the latter not recommended).
  6. 2010/03/30
    a1b2c3
    C:\Documents and Settings\Eric.E-6BBAC174EFC44\Desktop\HelpAsst_mebroot_fix.exe
    Tue 03/30/2010 at 21:14:40.17
    HelpAssistant account was found to be Active ~ attempting to de-activate
    Full Name Remote Desktop Help Assistant Account
    Account active Yes
    Local Group Memberships *Administrators
    HelpAssistant successfully set Inactive
    ~~ Checking for termsrv32.dll ~~
    termsrv32.dll present! ~ attempting to remove
    Remove on reboot: C:\WINDOWS\system32\termsrv32.dll
    ~~ Checking firewall ports ~~
    backing up DomainProfile\GloballyOpenPorts\List registry key
    closing rogue ports
    HKLM\~\services\sharedaccess\parameters\firewallpolicy\domainprofile\globallyopenports\list
    "65533:TCP "=-
    "52344:TCP "=-
    "2479:TCP "=-
    "4227:TCP "=-
    "3389:TCP "=-
    "1771:TCP "=-
    "3246:TCP "=-
    "2233:TCP "=-
    "2966:TCP "=-
    "1662:TCP "=-
    "1824:TCP "=-
    "6786:TCP "=-
    "6787:TCP "=-
    "7864:TCP "=-
    "7865:TCP "=-
    "9161:TCP "=-
    "9162:TCP "=-
    "5584:TCP "=-
    "9668:TCP "=-
    "5973:TCP "=-
    "5974:TCP "=-
    backing up StandardProfile\GloballyOpenPorts\List registry key
    closing rogue ports
    HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\globallyopenports\list
    "6786:TCP "=-
    "6787:TCP "=-
    "7864:TCP "=-
    "7865:TCP "=-
    "9162:TCP "=-
    "9161:TCP "=-
    "65533:TCP "=-
    "52344:TCP "=-
    "5584:TCP "=-
    "9668:TCP "=-
    "3389:TCP "=-
    "5973:TCP "=-
    "5974:TCP "=-
    HelpAssistant profile found in registry ~ backing up and removing S-1-5-21-1454471165-854245398-725345543-1000
    HelpAssistant profile directory exists at C:\Documents and Settings\HelpAssistant ~ attempting to remove
    ~ All C:\Documents and Settings\HelpAssistant files successfully removed ~
    ~~ Checking mbr ~~
    mbr infection detected! ~ running mbr -f
    Stealth MBR rootkit/Mebroot/Sinowal detector 0.3.7 by Gmer, http://www.gmer.net
    device: opened successfully
    user: MBR read successfully
    kernel: MBR read successfully
    detected MBR rootkit hooks:
    \Driver\atapi -> 0x89ac8bf0
    NDIS: Motorola Wireless PCI Adapter WPCI810G -> SendCompleteHandler -> 0x899a3330
    Warning: possible MBR rootkit infection !
    copy of MBR has been found in sector 0x01D1A4F79
    malicious code @ sector 0x01D1A4F7C !
    PE file found in sector at 0x01D1A4F92 !
    MBR rootkit infection detected ! Use: "mbr.exe -f" to fix.
    original MBR restored successfully !
    user & kernel MBR OK
    Use "Recovery Console" command "fixmbr" to clear infection !
    Status check on Tue 03/30/2010 at 21:29:15.65
    Account active No
    ~~ Checking mbr ~~
    called modules: ntkrnlpa.exe CLASSPNP.SYS disk.sys atapi.sys hal.dll pciide.sys PCIIDEX.SYS
    termsrv32.dll not found
    HKEY_LOCAL_MACHINE\system\currentcontrolset\services\termservice\parameters
    ServiceDll REG_EXPAND_SZ %systemroot%\System32\termsrv.dll
    ~~ Checking profile list ~~
    No HelpAssistant profile in List
    ~~ Checking for HelpAssistant directories ~~
    none found
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\domainprofile\GloballyOpenPorts\List]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    ~~ EOF ~~
  7. 2010/03/30
    How is eBay doing?
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    2. Close any open browsers.
      • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
      NOTE1. If Combofix asks you to install Recovery Console, please allow it.
      • Close any open browsers.
      • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    6. Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
    a1b2c3 likes this.
  8. 2010/03/30
    a1b2c3
    ComboFix 10-03-29.04 - Eric 03/30/2010 21:53:54.5.1 - x86
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.3062.2655 [GMT -5:00]
    Running from: c:\documents and settings\Eric.E-6BBAC174EFC44\Desktop\ComboFix.exe
    AV: Spyware Doctor with AntiVirus *On-access scanning disabled* (Updated) {D3C23B96-C9DC-477F-8EF1-69AF17A6EFF6}
    ((((((((((((((((((((((((( Files Created from 2010-02-28 to 2010-03-31 )))))))))))))))))))))))))))))))
    2010-03-31 02:39 . 2010-01-22 14:56 149456 ----a-w- c:\windows\SGDetectionTool.dll
    2010-03-31 02:39 . 2010-01-22 14:56 165840 ----a-w- c:\windows\PCTBDRes.dll
    2010-03-31 02:39 . 2010-01-22 14:56 1652688 ----a-w- c:\windows\PCTBDCore.dll
    2010-03-31 02:39 . 2010-01-22 14:55 767952 ----a-w- c:\windows\BDTSupport.dll
    2010-03-31 02:39 . 2009-10-28 06:36 1152444 ----a-w- c:\windows\UDB.zip
    2010-03-31 02:39 . 2008-11-26 17:08 131 ----a-w- c:\windows\IDB.zip
    2010-03-31 02:39 . 2010-02-05 14:17 233136 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
    2010-03-31 02:39 . 2010-03-10 16:36 217032 ----a-w- c:\windows\system32\drivers\PCTCore.sys
    2010-03-31 02:39 . 2009-11-23 18:54 88040 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
    2010-03-31 02:38 . 2010-02-05 14:25 70408 ----a-w- c:\windows\system32\drivers\pctplsg.sys
    2010-03-31 02:38 . 2010-03-31 02:52 -------- d-----w- c:\program files\Spyware Doctor
    2010-03-31 02:38 . 2010-03-31 02:39 -------- d-----w- c:\program files\Common Files\PC Tools
    2010-03-31 02:38 . 2010-03-31 02:38 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\PC Tools
    2010-03-31 02:14 . 2010-03-31 02:14 -------- d-----w- C:\HelpAsst_backup
    2010-03-29 22:21 . 2010-03-29 22:21 -------- d-----w- c:\program files\ESET
    2010-03-28 22:39 . 2010-01-07 21:07 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    2010-03-28 22:39 . 2010-03-28 22:39 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
    2010-03-28 22:39 . 2010-01-07 21:07 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
    2010-03-27 05:51 . 2010-03-27 05:51 -------- d-----w- c:\program files\Trend Micro
    2010-03-25 22:24 . 2010-03-25 22:24 -------- d--h--w- c:\windows\PIF
    2010-03-24 23:24 . 2010-03-24 23:28 -------- dc-h--w- c:\windows\ie8
    2010-03-23 22:47 . 2010-03-23 22:47 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Local Settings\Application Data\Threat Expert
    2010-03-23 22:39 . 2010-03-31 02:38 -------- d-----w- c:\documents and settings\All Users.WINDOWS\Application Data\PC Tools
    2010-03-23 22:38 . 2010-03-31 02:52 -------- d---a-w- c:\documents and settings\All Users.WINDOWS\Application Data\TEMP
    2010-03-23 22:05 . 2010-03-23 22:05 161296 ----a-w- c:\windows\system32\drivers\tmcomm.sys
    2010-03-21 01:08 . 2010-03-21 01:08 -------- d-----w- c:\program files\Defender Pro
    2010-03-10 18:04 . 2009-10-23 15:28 3558912 -c----w- c:\windows\system32\dllcache\moviemk.exe
    2010-03-06 23:38 . 2010-03-06 23:38 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\InstallShield
    2010-03-06 18:07 . 2010-03-06 18:07 -------- d-----w- c:\windows\system32\wbem\Repository
    2010-03-05 14:24 . 2010-03-05 14:24 -------- d-sh--w- c:\documents and settings\Administrator.E-6BBAC174EFC44\IETldCache
    2010-03-31 02:52 . 2010-01-15 19:23 -------- d-----w- c:\program files\PeerBlock
    2010-03-31 02:50 . 2009-04-01 12:05 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\DNA
    2010-03-31 02:20 . 2009-04-01 12:05 -------- d-----w- c:\program files\DNA
    2010-03-30 12:17 . 2009-10-12 11:48 -------- d-----w- c:\program files\Unlocker
    2010-03-27 04:02 . 2008-02-18 16:52 -------- d-----w- c:\program files\LimeWire
    2010-03-27 03:59 . 2008-08-21 03:36 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\LimeWire
    2010-03-27 03:59 . 2009-03-28 20:52 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\Vso
    2010-03-25 22:39 . 2008-08-19 19:09 52256 ----a-w- c:\documents and settings\Eric.E-6BBAC174EFC44\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    2010-03-25 22:38 . 2009-01-24 16:09 -------- d-----w- c:\program files\Common Files\AVSMedia
    2010-03-25 22:38 . 2009-01-24 16:09 -------- d-----w- c:\program files\AVS4YOU
    2010-03-24 00:48 . 2008-04-27 21:16 -------- d-----w- c:\documents and settings\Eric\Application Data\Move Networks
    2010-02-27 06:25 . 2008-09-01 13:41 -------- d-----w- c:\program files\CCleaner
    2010-02-26 03:38 . 2008-09-21 03:08 -------- d-----w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\Corel
    2010-02-26 03:37 . 2008-09-21 03:08 900 --sha-w- c:\windows\system32\KGyGaAvL.sys
    2010-02-24 15:16 . 2009-10-03 06:37 181632 ------w- c:\windows\system32\MpSigStub.exe
    2010-02-20 21:54 . 2010-02-20 21:54 -------- d-----w- c:\documents and settings\All Users.WINDOWS\Application Data\ThumbnailCache4R
    2010-02-18 10:35 . 2010-02-18 10:35 -------- d-----w- c:\documents and settings\Administrator.E-6BBAC174EFC44\Application Data\FaxCtr
    2010-01-07 00:38 . 2009-03-28 20:52 47360 ----a-w- c:\windows\system32\drivers\pcouffin.sys
    2010-01-07 00:38 . 2009-03-28 20:52 47360 ----a-w- c:\documents and settings\Eric.E-6BBAC174EFC44\Application Data\pcouffin.sys
    2009-12-31 16:50 . 2004-08-10 11:00 353792 ----a-w- c:\windows\system32\drivers\srv.sys
    ((((((((((((((((((((((((((((( SnapShot@2010-03-27_07.00.37 )))))))))))))))))))))))))))))))))))))))))
    + 2010-03-31 02:21 . 2010-03-31 02:21 16384 c:\windows\Temp\Perflib_Perfdata_778.dat
    "BitTorrent DNA "= "c:\program files\DNA\btdna.exe" [2009-11-11 323392]
    "PeerBlock "= "c:\program files\PeerBlock\peerblock.exe" [2009-09-28 1524824]
    "IgfxTray "= "c:\windows\system32\igfxtray.exe" [2006-07-22 98304]
    "Persistence "= "c:\windows\system32\igfxpers.exe" [2006-07-22 81920]
    "ISUSPM Startup "= "c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe" [2006-10-03 221184]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2009-10-31 149280]
    "TkBellExe "= "c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-12-19 185872]
    "SigmatelSysTrayApp "= "stsystra.exe" [2006-03-20 282624]
    [hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
    "{56F9679E-7826-4C84-81F3-532071A8BCC5} "= "c:\program files\Windows Desktop Search\MSNLNamespaceMgr.dll" [2009-05-25 304128]
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users.WINDOWS^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
    path=c:\documents and settings\All Users.WINDOWS\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
    backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users.WINDOWS^Start Menu^Programs^Startup^Windows Search.lnk]
    path=c:\documents and settings\All Users.WINDOWS\Start Menu\Programs\Startup\Windows Search.lnk
    backup=c:\windows\pss\Windows Search.lnkCommon Startup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
    2009-12-11 21:57 948672 ----a-r- c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
    2009-12-22 07:57 35760 ----a-w- c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
    2008-04-14 10:42 15360 ------w- c:\windows\system32\ctfmon.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ehTray]
    2005-08-05 19:56 64512 ----a-w- c:\windows\ehome\ehtray.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\FaxCenterServer]
    2008-06-13 16:00 320168 ----a-w- c:\program files\Lexmark Fax Solutions\fm3032.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HotKeysCmds]
    2006-07-22 01:50 86016 ----a-w- c:\windows\system32\hkcmd.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IgfxTray]
    2006-07-22 01:48 98304 ----a-w- c:\windows\system32\igfxtray.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISUSPM Startup]
    2006-10-03 18:35 221184 ----a-w- c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISUSScheduler]
    2006-10-03 18:37 81920 ----a-w- c:\program files\Common Files\InstallShield\UpdateService\issch.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lxdxamon]
    2008-06-13 16:04 16040 ----a-w- c:\program files\Lexmark 3600-4600 Series\lxdxamon.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lxdxmon.exe]
    2008-06-13 16:04 668328 ----a-w- c:\program files\Lexmark 3600-4600 Series\lxdxmon.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Persistence]
    2006-07-22 01:47 81920 ----a-w- c:\windows\system32\igfxpers.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
    2009-11-11 05:08 417792 ----a-w- c:\program files\QuickTime\QTTask.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TkBellExe]
    2008-12-19 03:47 185872 ----a-w- c:\program files\Common Files\Real\Update_OB\realsched.exe
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\Program Files\\DNA\\btdna.exe "=
    "c:\\Program Files\\Malwarebytes' Anti-Malware\\mbam.exe "=
    "c:\\Program Files\\CCleaner\\CCleaner.exe "=
    "c:\\WINDOWS\\system32\\lxdxcoms.exe "=
    "c:\\Program Files\\Lexmark 3600-4600 Series\\lxdxmon.exe "=
    "c:\\WINDOWS\\system32\\lxdxcfg.exe "=
    "c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdxpswx.exe "=
    "c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdxtime.exe "=
    "c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdxjswx.exe "=
    "c:\\Program Files\\Java\\jre6\\bin\\javaw.exe "=
    "c:\\Program Files\\Messenger\\msmsgs.exe "=
    "c:\\Program Files\\Lexmark 3600-4600 Series\\frun.exe "=
    "c:\\WINDOWS\\system32\\sessmgr.exe "=
    R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [3/30/2010 9:39 PM 217032]
    R2 Browser Defender Update Service;Browser Defender Update Service;c:\program files\Spyware Doctor\BDT\BDTUpdateService.exe [3/30/2010 9:39 PM 112592]
    R2 lxdx_device;lxdx_device;c:\windows\system32\lxdxcoms.exe -service --> c:\windows\system32\lxdxcoms.exe -service [?]
    R3 pbfilter;pbfilter;c:\program files\PeerBlock\pbfilter.sys [1/15/2010 2:23 PM 14424]
    S0 TfFsMon;TfFsMon;c:\windows\system32\drivers\TfFsMon.sys --> c:\windows\system32\drivers\TfFsMon.sys [?]
    S0 TfSysMon;TfSysMon;c:\windows\system32\drivers\TfSysMon.sys --> c:\windows\system32\drivers\TfSysMon.sys [?]
    S2 lxdxCATSCustConnectService;lxdxCATSCustConnectService;c:\windows\system32\spool\drivers\w32x86\3\lxdxserv.exe [10/21/2009 7:48 PM 98984]
    S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [3/30/2010 9:38 PM 366840]
    S3 TfNetMon;TfNetMon;\??\c:\windows\system32\drivers\TfNetMon.sys --> c:\windows\system32\drivers\TfNetMon.sys [?]
    *NewlyCreated* - BROWSER_DEFENDER_UPDATE_SERVICE
    *NewlyCreated* - SDAUXSERVICE
    *NewlyCreated* - SDCORESERVICE
    *Deregistered* - PCTSDInjDriver32
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
    HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
    uStart Page = hxxp://www.yahoo.com/
    Trusted Zone: download.com
    MSConfigStartUp-UnlockerAssistant - c:\program files\Unlocker\UnlockerAssistant.exe
    Rootkit scan 2010-03-30 22:00
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    [HKEY_USERS\S-1-5-21-1454471165-854245398-725345543-1003\Software\Microsoft\SystemCertificates\AddressBook*]
    @Allowed: (Read) (RestrictedCode)
    [HKEY_USERS\S-1-5-21-1454471165-854245398-725345543-1003\Software\Policies\Microsoft\SystemCertificates\AddressBook*]
    @Allowed: (Read) (S-1-5-21-1454471165-854245398-725345543-1003)
    - - - - - - - > 'explorer.exe'(1340)
    c:\windows\system32\WININET.dll
    c:\windows\system32\ieframe.dll
    c:\windows\system32\webcheck.dll
    c:\windows\system32\WPDShServiceObj.dll
    c:\windows\system32\PortableDeviceTypes.dll
    c:\windows\system32\PortableDeviceApi.dll
    Completion time: 2010-03-30 22:02:35
    ComboFix-quarantined-files.txt 2010-03-31 03:02
    ComboFix2.txt 2010-03-28 01:49
    ComboFix3.txt 2010-03-28 00:49
    ComboFix4.txt 2010-03-27 17:37
    ComboFix5.txt 2010-03-31 02:53
    Pre-Run: 215,620,251,648 bytes free
    Post-Run: 215,795,904,512 bytes free
    - - End Of File - - B26918B0C61F46631F3394D72E386107
    Scan saved at 10:18:05 PM, on 3/30/2010
    MSIE: Internet Explorer v8.00 (8.00.6001.18702)
    C:\WINDOWS\system32\csrss.exe
    C:\WINDOWS\system32\igfxpers.exe
    C:\Program Files\Java\jre6\bin\jusched.exe
    C:\WINDOWS\stsystra.exe
    C:\Program Files\Spyware Doctor\pctsTray.exe
    C:\Program Files\DNA\btdna.exe
    C:\Program Files\PeerBlock\peerblock.exe
    C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe
    C:\WINDOWS\eHome\ehSched.exe
    C:\WINDOWS\system32\lxdxcoms.exe
    C:\Program Files\Spyware Doctor\pctsAuxs.exe
    C:\Program Files\Spyware Doctor\pctsSvc.exe
    C:\WINDOWS\System32\wltrysvc.exe
    C:\WINDOWS\System32\bcmwltry.exe
    C:\WINDOWS\ehome\mcrdsvc.exe
    C:\WINDOWS\system32\SearchIndexer.exe
    C:\WINDOWS\system32\dllhost.exe
    C:\WINDOWS\System32\alg.exe
    C:\WINDOWS\system32\SearchProtocolHost.exe
    C:\WINDOWS\system32\SearchFilterHost.exe
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    C:\WINDOWS\system32\wbem\wmiprvse.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
    O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
    O2 - BHO: Browser Defender BHO - {2A0F3D1B-0909-4FF4-B272-609CCE6054E7} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll
    O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
    O3 - Toolbar: PC Tools Browser Guard - {472734EA-242A-422B-ADF8-83D1E48CC825} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
    O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe "
    O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
    O4 - HKLM\..\Run: [ISTray] "C:\Program Files\Spyware Doctor\pctsTray.exe "
    O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe "
    O4 - HKCU\..\Run: [PeerBlock] C:\Program Files\PeerBlock\peerblock.exe
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
    O15 - Trusted Zone: *.download.com
    O16 - DPF: {01A88BB1-1174-41EC-ACCB-963509EAE56B} (SysProWmi Class) - http://support.dell.com/systemprofiler/SysPro.CAB
    O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - http://appldnld.apple.com.edgesuite.net/content.info.apple.com/QuickTime/qtactivex/qtplugin.cab
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/win...ls/en/x86/client/wuweb_site.cab?1220267475953
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1220268559562
    O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} (OnlineScanner Control) - http://download.eset.com/special/eos/OnlineScanner.cab
    O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - http://cdn2.zone.msn.com/binFramework/v10/ZPAFramework.cab102118.cab
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
    O16 - DPF: {F773E7B2-62A9-4524-9109-87D2F0BEFAA4} (ChessControl Class) - http://zone.msn.com/bingame/zpagames/zpa_kqrp.cab56961.cab
    O23 - Service: ArcSoft Connect Daemon (ACDaemon) - Unknown owner - C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe (file missing)
    O23 - Service: Browser Defender Update Service - Threat Expert Ltd. - C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Roxio\Roxio MyDVD DE\InstallShield\Driver\1050\Intel 32\IDriverT.exe
    O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
    O23 - Service: lxdxCATSCustConnectService - Lexmark International, Inc. - C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\\lxdxserv.exe
    O23 - Service: lxdx_device - - C:\WINDOWS\system32\lxdxcoms.exe
    O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
    O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
    O23 - Service: stllssvr - Unknown owner - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe (file missing)
    O23 - Service: WLTRYSVC - Unknown owner - C:\WINDOWS\System32\wltrysvc.exe
    End of file - 7086 bytes
  9. 2010/03/30
    a1b2c3
    Oh yeah. No more ebay problem!
  10. 2010/03/30
    Excellent!
    Uninstall Combofix:
    Go Start > Run [Vista users, go Start> "Start search"]
    Type in:
    Combofix /Uninstall
    Note the space between the "Combofix" and the "/Uninstall "
    Click OK (Vista users - press Enter).
    Restart computer.
    Verify your Java version here: http://www.java.com/en/download/installed.jsp
    Update, if necessary.
    Uninstall all previous Java versions, through Add\Remove (Programs & Features in Vista).
    When done....
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
  11. 2010/03/31
    a1b2c3
    My computer is free of the ebay problem and is running faster than it's run in a long time.
    Thank you for your time, help and expertise! It's greatly appreciated!
  12. 2010/03/31
    You're very welcome :)
    Stay safe :)
