DvD external daul copyier
Discussion in 'PC Hardware' started by bobm735, 2006/01/04.
  1. 2006/01/10
    bobm735
    bobm735 Well-Known Member Thread Starter
    DVD burner
    when I drag and drop a file to Roxio's D&D it tell's me to put a disk in drive E
    well my DVD burner is drive M . So I go into my computer and D&D a small file to the M drive and this is the error message I get.
    Found problems on Disk in drive M do you want to scan disk to try to repair it and I did that nothing is fix
  2. 2006/01/10
    charlesvar
    charlesvar Inactive Alumni
    Hi Bob,
    Is drive E the CD burner?
    Regards - Charles
    charlesvar
    Hi Bob,
    Try doing this with a blank DVD, D&D a file to M with a blank, close it out the way outlined, and lets see if the system can read that.
    Regards - Charles
  5. 2006/01/10
    sparrow
    sparrow Inactive
    HI bobm735,
    As a latecomer to your thread, would like to try to clarify for myself what's happened so far. You got an exrernal DVD writer to move data/programs to another location, a very good idea, You dragged a backup file to the DVD, and now can't access it at your new location? It's a 00000001.rec file? Since you can't read it, it's probably been compressed by the program that made it. If you don't have that program on your present computer, that would explain your problem.
    It appears that the current computer may be confused as to the address of the DVD writer in its system, but you did see the file and have it copied to the HDD, so that's not the main problem. It appears that we can't be much help if you don't know what program you've backed up. What exactly did you back up?
  6. 2006/01/10
    bobm735
    DVD burner
    I D&D to my M drive and it put it on the blank dvd disk I double click on the disk to make sure it was on the disk and it was .
  7. 2006/01/10
    charlesvar
    Is this a file I asked you to create this morning? If so, I think we've narrorwed this down to the problem being the file you brought from Michigan.
    So if you can answer sparrow's question - what was the file and what created it, not how you put it on the DVD - you wrote you used D&D to do that, we'll know a whole lot more.
    Thanks sparrow :)
    Regards - Charles
  8. 2006/01/10
    bobm735
    DVD burner
    yes that was the file you had me create this morning.
    Now the files on the dvd I brought from michigan was just download files my Incredimail back up my notetab files just all my personal folders I just d&d them with Roxcio 7.5 program filled up 3 dvd disk .
  9. 2006/01/11
    sparrow
    sparrow Inactive
    Hi Bob,
    Still trying to clarify where we stand. Can you see the files on any of the DVDs using windows esplorer? On the keyboard: start > run > type explorer > hit enter, and use the mouse to highlight the DVD drive in the left window and look for the files in the right window.
  10. 2006/02/03
    bobm735
    Win XP Home ED. Start up
    I had updated my Roxio from 6.0 to 7.5 I took that off and computer is starting up good now.
    Thank you
