DMP File: Help me decode
Discussion in 'Windows XP' started by sigma69pi, 2010/11/29.
  1. 2010/11/29
    sigma69pi
    sigma69pi Inactive Thread Starter
    What am I looking at?
    Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
    Loading Dump File [C:\Documents and Settings\wallacsm\Desktop\DMp\Mini112910-03.dmp]
    Symbol search path is: C:\websymbols\Debug 2
    Executable search path is:
    Unable to load image ntoskrnl.exe, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ntoskrnl.exe
    Windows 2000 Kernel Version 2195 (Service Pack 4) MP (2 procs) Free x86 compatible
    Machine Name:
    Kernel base = 0x80400000 PsLoadedModuleList = 0x80485b00
    Debug session time: Mon Nov 29 17:37:05.619 2010 (UTC - 6:00)
    System Uptime: not available
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck D1, {14, 2, 0, f2080875}
    Unable to load image ADM9X.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ADM9X.sys
    *** ERROR: Module load completed but symbols could not be loaded for ADM9X.sys
    Probably caused by : ADM9X.sys ( ADM9X+875 )
    Followup: MachineOwner
    0: kd> !analyze -v
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: 00000014, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: f2080875, address which referenced memory
    Debugging Details:
    READ_ADDRESS: unable to read from 80484220
    unable to read from 80483ea4
    unable to read from 80483e34
    unable to read from 8047a7d8
    unable to read from 80483e38
    unable to read from 80483ea8
    unable to read from 8047a7dc
    unable to read from 80483f80
    unable to read from 80484224
    00000014
    CURRENT_IRQL: 2
    FAULTING_IP:
    ADM9X+875
    f2080875 ?? ???
    CUSTOMER_CRASH_COUNT: 3
    DEFAULT_BUCKET_ID: INTEL_CPU_MICROCODE_ZERO
    BUGCHECK_STR: 0xD1
    LAST_CONTROL_TRANSFER: from 00000000 to 8046b12c
    STACK_TEXT:
    80475e00 00000000 00000000 8552f0a8 8552f30c nt!RtlInitStackTraceDataBaseEx+0xa1
    STACK_COMMAND: .bugcheck ; kb
    FOLLOWUP_IP:
    ADM9X+875
    f2080875 ?? ???
    SYMBOL_NAME: ADM9X+875
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: ADM9X
    IMAGE_NAME: ADM9X.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 3d92c1b7
    FAILURE_BUCKET_ID: 0xD1_ADM9X+875
  2. 2010/11/30
    markmadras
    markmadras Banned
    As with most crash dumps it is not always obvious what the problem is, this one does suggest a driver issue but it could also be caused by a faulty memory module.
    Could you please complete your system details so we can all see what PC and type of system we are dealing with.
    Could you include a bit of history concerning the crashes, how often they happen, what software you use when it happens, and anything else that may help us to narrow down the cause. Also tell us if there have been any other problems occuring.
    aciid
    aciid Inactive
    Hi,
    Adm9x.sys refers to a network-card linked to ADMtek. Most likely a built-in network card, but might also be an extra card.
    0x00000014, is a system error referring to that a driver is trying to access a device/unit that is not available. Thus accessing invalid memory, and therefore giving you a BSOD.
    If you can still use the system, uninstall your motherboards drivers (If you have a built-in network card). Otherwise uninstall the network card, and see if the BSOD still appears. If you can't access the system regularly, run SafeMode without networking.
    Admin. likes this.
  5. 2010/11/30
    sigma69pi
    The system is still usable. I have uninstalled and reinstalled the driver for the network card. I will watch it over night and let you know if there are any additional problems.
    Thanks everybody for the help!
